Old 03-01-2023, 08:04 PM   #1
carlythecamaro
carlythecamaro's Avatar
Drives: 2017 Camaro SS
How to get rid of choppy helicopter noise
hello all, my '17 SS has 1 7/8 in long tube headers & corsa extreme axle back. I'm having this issue when I go from low RPMs to higher RPMS, the exhaust makes a choppy sound almost like the sound of a helicopter. Has anyone else had this issue or how to fix it? thanks
carlythecamaro is offline   Reply With Quote
Old 03-01-2023, 08:53 PM   #2
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
Did you just have the exhaust work done? And did you swap the X-Pipe?
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Tuned by: Shane Hinds | Dyno: 510 rwhp 472 rwtq
FlukeSS is offline   Reply With Quote
Old 03-01-2023, 09:47 PM   #3
carlythecamaro
I still have the stock X pipe, my headers & exhaust are after market its also been tuned
Old 03-02-2023, 12:55 AM   #4
Casper the friendly G
Drives: 17' Chevy Kamaro SS 6 speed
please do a video
Casper the friendly G is offline   Reply With Quote
Old 03-02-2023, 06:48 AM   #5
adamjwilson
Drives: 2022 Camaro 2SS A10
I don't have this issue, but I replaced my X-pipe as well.... running 2" TSP headers, x-pipe with high flow cats, and Corsa NPP axle back exhaust. Assume you have NPP exhaust as well? Someone suggested a video which is great. Could you upload that so we can hear?
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods
adamjwilson is offline   Reply With Quote
Old 03-02-2023, 08:16 AM   #6
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Sounds like the AFM valves in the X pipe might be "fluttering". I have read a few others having a similar issue.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 03-05-2023, 03:27 PM   #7
carlythecamaro
Originally Posted by Casper the friendly G View Post
please do a video
http://youtube.com/shorts/m3-JcsPUelw?feature=share
Old 03-05-2023, 03:28 PM   #8
carlythecamaro
Old 03-05-2023, 03:29 PM   #9
carlythecamaro
Old 03-05-2023, 05:03 PM   #10
db2022cs
Drives: 2023 2SS 1LE
I think I had heard this issue in the past from other users. Did this exhaust sound issue happen right after you got it installed? It's possible it's vibrating at a certain frequency and possible hitting something underneath. If you can easily get it in the air, see if the exhaust is close to any cross members or anything and see if may be hitting.
2023 Riverside Blue Metallic 2SS 1LE Camaro
2021 Black Hyundai Veloster N -Sold-
2016 Grey Chevy Volt -Sold-
2018 Blue AWD Kia Stinger GT2 -Sold-
db2022cs is offline   Reply With Quote
Old 03-05-2023, 06:41 PM   #11
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
Are your windows open?
lt4camaro is offline   Reply With Quote
Old 03-06-2023, 07:51 AM   #12
FlukeSS
FlukeSS's Avatar
I was going to suggest that as well, but was hesitant when he said just the headers and axle back. This happened to me but was more noticeable while driving. Not just cold starting. It really does sound like exhaust rattle though.
I guess when they put the axle back on it could cause the mid pipe to rest and rattle against the cross member brace. In my case I replaced the stock x-pipe for after market and the pipe settles and rattles on the cross member brace. Simple fix shimmy the cross member brace if that is the issue.
Old 03-06-2023, 07:59 AM   #13
ShockingZ
Drives: Chevy Camaro ZL1
So longtubes with corsa extreme?? Thats your problem. You need to put the stock NPP back on. This is EVERY SINGLE PERSON that gets long tubes after having a catback/axleback installed and its just too loud and obnoxious. Put the stock NPP back on and sell the corsa stuff.
ShockingZ is offline   Reply With Quote
Old 03-06-2023, 08:11 AM   #14
adamjwilson
Really? That is YOUR preference (and not necessarily OP or others on this thread), and no help to OP to fix the issue. I have the same set up with aftermarket X-pipe, and I enjoy the Corsa NPP exhaust system.
exhaust
