Go Back   Chevrolet Corvette Stingray C7 Forum > Marketplace > Commercial Classifieds Marketplace > Exterior Parts & Accessories
Old 08-25-2015, 09:29 AM   #1
RPIDon
RPIDon's Avatar
Drives: Camaro
Send a message via AIM to RPIDon
RPI Designs APR C7 Z06 Real Carbon Fiber body components
C7 Z06 APR Real Carbon Fiber Body Components
Name:  C7 APR Z06 TRACK SPLITTER.jpg
Name:  c7 z06 apr aero package 811.jpg
C7 Z06 APR Real Carbon Fiber Front Air Dam Splitter
If you are looking for the best quality carbon fiber to put on your new Stingray then look no further than this APR front air dam splitter. Made right here in the USA, this front air dam splitter utilizes a built in aerodynamic design that creates a high pressure region of air above the protruding surface, which helps reduce lift and increase high-speed cornering. Or course, if you are not into racing, this piece also provides a great visual upgrade over the factory look.
Get your order in today.
Item # FA-207007 $997.95 use coupon code RPIDON5 on line or by phone and receive 5% off the listed price!!!:thumbs:
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=4935
C7 Corvette Z06 APR Carbon Fiber Track Pack Front Airdam Splitter
Our C7 Corvette Z06 real carbon fiber track pack front splitter is the ultimate for your C7 Z06. This front splitter is made of 100% carbon fiber, is extremely strong and very lightweight. If you are serious about your C7 Z06, this splitter is for you. Not only does it look great, but functions better than any other performance splitter on the market.
Item # FA-207028 $1,705.25 use coupon code RPIDON5 on line or by phone and receive 5% off the listed price!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=5451
C7 Corvette Z06 APR Carbon Fiber Side Rockers Skirts
If you are looking for the best quality carbon fiber to put on your new Stingray Z06 then look no further than this APR C7 Corvette Stingray side rocker extensions kit. Made right here in the USA, this side rocker kit helps reduce under-body turbulence, lift and drag by limiting excess airflow to the under- body. Or course, if you are not into racing, this kit also provides a great visual upgrade over the factory look.
Item # FS-207028 Price $1,610.55 use coupon code RPIDON5 on line or by phone and receive 5% off the listed price!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=5214
C7 Corvette Z06 APR Carbon Fiber Rear Spoiler
If you are looking to give your C7 Corvette Z06 a fresh, bold look, then look no further than our APR Performance real carbon fiber rear spoiler. This spoiler is made of 100% carbon fiber and comes complete with the wickerbill as shown in the photo. UnLike the factory GM wicker bill that is non adjustable, this one can be adjusted 7/8's of an inch. This spoiler is not only designed for great looks, but will also perform as it was intended. This spoiler bolts right up to a C7 Z06 Corvette.
Item # AS-105757 $1,187.00 use coupon code RPIDON5 on line or by phone and receive 5% off the listed price!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=5447
C7 Z06 Real Carbon Fiber Lower Diffuser
This C7 Corvette Stingray real Carbon Fiber Rear Diffuser is a direct replacement of your existing diffusor. Made in the USA by APR.
*Rear diffusers help reduce turbulence of the under-body airflow that exits the rear of the vehicle. This helps to reduce both lift and drag
Item # AB-277019 Price $1,465 use coupon code RPIDON5 on line or by phone and receive 5% off the listed price!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=4971
C7 Z06 Real Carbon Fiber Side View Mirror Housings- set
These C7 Corvette Stingray Carbon Fiber Mirror Housings are very light weight and replace your existing mirror housings.
This mirror conversion kit replaces the factory mirror housings (but re uses the existing lenses and power mirror mechanisms).
Item # CF-207007 Price $665.00 use coupon code RPIDON5 on line or by phone and receive 5% off the listed price !!!! :thumbs:
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=4970
C7 Corvette Z06 APR Carbon Fiber Front Fender Vents
Give your C7 Corvette Z06 the very best treatment with these replacement carbon fiber front fender vents. These front fender vents are made by APR Performance and designed to simply replace your existing OEM GM plastic vents. Once you get these new Z06 Carbon Fiber vents installed, just transfer your Z06 badges from your old plastic pieces to these new carbon fiber pieces. These C7 Z06 front vendor vents are sold as a pair. Free ground shipping on these vents.
Item # CF-700802 $650.75 use coupon code RPIDON5 on line or by phone and receive 5% off the listed price !!!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=5449
C7 Corvette Z06 APR Carbon Fiber Hood Vent
Here is a great way to set your C7 Corvette Z06 apart from the crowd. This real carbon fiber hood vent is a direct replacement of the existing plastic hood vent. Simply remove your plastic hood vent and replace with this carbon fiber hood vent. Built to be the exact same shape and size as the OEM GM unit. This hood vent is clear coated for a high gloss, show winning shine.
Item # CF-700805 $565.25 use coupon code RPIDON5 on line or by phone and receive 5% off the listed price !!!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=5448
C7 Corvette Z06 APR Carbon Fiber Rear Quarter Panel Ducts
These C7 Corvette Z06 carbon fiber rear quarter panel ducts are a great match to our front fender ducts shown to the right side of your screen. These rear quarter panel ducts are made of real carbon fiber by APR Performance and designed to simply replace your existing ducts. Installation is quick and easy. These quarter panel ducts are sold as a set of two.
Item # CF-700804 $ 650.75 use coupon code RPIDON5 on line or by phone and receive 5% off the listed price !!!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=5450
RPIDon is offline   Reply With Quote
Old 10-16-2015, 01:11 PM   #2
RPIDon
RPIDon's Avatar
Drives: Camaro
use coupon code RPIDON5 and save 5% off the website price!!
