05-07-2023, 07:10 AM | #1 |
What Oil filter do you guys recommend? LS3.
Right now I am running the ACDelco UPF48R, Most of my other vehicles I run Amsoil filters, I am also considering K&N, and Royal Purple. What are your guys thoughts? I Run Amsoil Syn series oil in most of my stuff as well.
Thanks
05-07-2023, 08:23 AM | #2 |
Wix.
05-07-2023, 08:47 AM | #3 |
Mobil one filter I use
I’ve watched tons of videos of how they perform and Mobil one seems to be one of the best all around filter.
05-07-2023, 09:13 AM | #4 |
Still using the ACDelco on mine.
05-07-2023, 11:01 AM | #5 |
It don’t come easy.
Amsoil
05-07-2023, 05:55 PM | #6 |
Do filters have any affect on oil pressure?
05-07-2023, 07:23 PM | #7 |
Drives: 2010 camaro ss Join Date: Aug 2021
Yes they do. You probably won’t see much if any difference on a good quality filter but as they plug up flow will drop or if you throw a junk Fram on there made out of cardboard and it decides to completely restrict flow then you may have zero pressure. I found that out the hard way on a car I bought 20+ years ago. Sent from my iPhone using Tapatalk |
05-08-2023, 07:12 AM | #8 |
waiting at the tree
I use the Mobile One or Wix both are good filters
2010 2SS/RS A6 ZL1 Rims
05-09-2023, 09:45 AM | #9 | |
Here is some testing info.
05-09-2023, 10:01 AM | #10 |
I'm running Amsoil 5w-30 Signature and a Royal Purple filter. I explain why in my video and give some links to other YouTuber videos showing why I prefer them.
https://youtu.be/BbMg8V3Am54 . . . . . . .
05-09-2023, 04:01 PM | #11 |
Is the AC DELCO UPF48R a decent filter? I am not seeing to much on it during searches.
05-10-2023, 12:17 PM | #12 |
Native Floridian
Drives: 2014 - ZL1 / 2003 - Corvette Join Date: Oct 2013
Mobil 1 on all of my vehicles.
05-10-2023, 09:17 PM | #13 |
Drives: 2015 zl1 m6 Join Date: Jan 2020
Wix xp
791whp 699 ft lbs torque on E30 - ported sc /heads by boost mode racing - PAT G cam /Tune
PB:10.7 @133.9 |
05-10-2023, 10:04 PM | #14 |
Drives: Camaro 1LE Join Date: May 2018
I run wix xp on all of our vehicles here. 👍
