Vararam
Old 08-28-2016, 05:01 PM   #1
bub
Drives: '17 1SS 1LE & '15 Corvette Z06
Condensation in Rear Camera '15 1LE
Trip to the dealer in order.
Occurred after a power wash this am. Anybody know if the camera can be removed without pulling off the rear fascia?
Looks like it may clip in from below over the tag area?
bub is offline   Reply With Quote
Old 08-29-2016, 01:40 PM   #2
Bulldog3071
Bulldog3071's Avatar
Drives: 2010 Camaro 2SS/RS LS3
power wash is never a good idea around electronics hope it works out for you
Hurst Short Throw Shifter, K&N CAI, SRP Racing Pedals, GM Performance Exhaust, GM GFX Package
Lakewood Strut Tower Brace, JBA Shorty Headers, JBA 8 MM Wires, Airaid TB Spacer, Phastek CAI Scoop, Washer Bottle Relocation Kit, Stainlees Steel Brake Lines, Brake Performance Slotted and Drilled Rotors, BMR Tunnel Brace, BMR Trailing Arms, BMR Subframe Connectors, Borla ATAK Muffelers, Z28 Wickerbill Spoiler, VTC, Bow Tie Delete, BMR Adjustable Front Swaybar, BMR End Link Kit, BMR Extreme Rear Anti-Roll Kit, Diablo I1000 "InTune"
Bulldog3071 is offline   Reply With Quote
Old 08-29-2016, 07:28 PM   #3
bub
Should be a design criteria (fully sealed) for this type of exterior camera tho.
Old 08-29-2016, 09:01 PM   #4
JerTM
JerTM's Avatar
Drives: 2011 2SS/RS M6
While I agree, GM won't. I have seen several warranties get kicked back because a tech wrote that the customer used a pressure washer and "X" component failed. It's just not common weather to have 100 psi water jetted at a vertical surfaces on any car. The cameras are pretty cheesy anyway, maybe when this one gets replaced try not to let the pressure washer hit it directly.
JerTM is offline   Reply With Quote
Old 08-29-2016, 09:35 PM   #5
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
Yes any exposed electronics are designed for the elements....the manufacturer has no idea where the car will end up so they are all designed to take anything from -20 and salt to 110 in the shade.
rontammy0 is offline   Reply With Quote
Old 08-29-2016, 09:46 PM   #6
rontammy0
Should be a design criteria (fully sealed) for this type of k1 camera tho.
Old 08-30-2016, 01:29 AM   #7
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
wait for it to go away if it comes back with out power washing then take it to the dealer. You do mean a home power washer not car wash power washer. if it happened at a car wash then it would be covered under warranty.
Old 08-30-2016, 05:12 AM   #8
trashmanssd
trashmanssd's Avatar
If water got in water/air can get out. Hair dryer on medium or low setting for few minutes should heat up the air inside and around it and help it evaporate and get out. Or just park it out side on nice warm sunny day in the sun back end facing the sun and it should clear right up.
Old 08-30-2016, 11:08 AM   #9
Mike J
Mike J's Avatar
Drives: 2015 Topless Btch RS
Had to have my camera realigned. Technician not happy have to take rear completely off. Was told it was the only way.let it dry and see.
Mike J is offline   Reply With Quote
Old 09-05-2016, 02:27 PM   #10
bub
I agree, after looking at it some more and doing some research (exploded view of parts diagram) that only way to replace or align would be to completely remove rear fascia. There are 2 screws fastening it in from the back side that can barely be reached by finger with the tag off.
Update: After a few days, it was back to normal. Yes it was a car wash (wand type) manual washer, not a home power washer. Just need to be cautious about shooting directly at the camera here on &/or cover it (lens area) with some blue masking tape prior to wash...
Old 09-05-2016, 03:59 PM   #11
Reaper85
Drives: 2013 2SS/RS
I've pressure washed mine for the past couple years with no issues. Could be a defect. I've done this on multiple vehicles. Never has any issues.
Reaper85 is offline   Reply With Quote
Old 09-05-2016, 11:03 PM   #12
JCunningham
Drives: 2017 2SS M6
should be covered under warranty then. tell them when you go to the car wash water gets in the camera. It was designed to withstand a car wash.
Old 09-05-2016, 11:18 PM   #13
The Blue Angel
The Blue Angel's Avatar
Drives: 2014 BRM 1SS/RS
A car wash pressure washer should be no different than a rain driven storms a Camaro can get caught in!!!
2014 Blue Ray Metallic 1SS/RS
A Road Warrior
The Blue Angel is offline   Reply With Quote
Old 09-06-2016, 03:20 PM   #14
bub
I'm going to give it some time. Still over 2 yrs left on warranty and plentyof miles. Don't want them yanking off the rear bumper cover and risk screwing something else up in the process. It's all clear for now, and with some precaution, I should be able to avoid a re-occurence in the future.
