01-21-2024, 03:19 PM | #15 | ||
Retired from GM
Drives: 2017 Camaro Fifty SS Convertible Join Date: Mar 2017
A8 | MRC | NPP | Nav | HUD | GM Performance CAI | Tony Mamo LT1 V2 Ported TB | Kooks 1-7/8” LT Headers | FlexFuel Tune | Thinkware Q800 Pro front and rear dash cam | Charcoal Tint for Taillights and 3rd Brakelight | Orange and Carbon Fiber Bowties | 1LE Wheels in Gunmetal Gray | Carbon Fiber Interior Overlays | Novistretch bra and mirror covers | Tow hitch for bicycle rack | |
01-21-2024, 03:34 PM | #16 | |
Retired from GM
From independent news source Reuters… During a historic cold snap that has left millions of Texans without electricity, water, and heat for days, claims that the state’s use of renewable energy sources, specifically wind energy, are to blame have circulated on television and social media. These claims are misleading, as they shift blame for the crisis away from what appears, so far, to be the root cause: record cold temperatures that affected generation and transportation across all fuel types (including, but not limited to, wind energy), combined with the inability of the state’s independent and isolated electricity grid (operated by the Electric Reliability Council of Texas, or ERCOT) to source supplies from elsewhere. Far from being a diversity hire, GM’s CEO started with the company right out of high school as an engineering student at General Motors Institute (now Kettering University) which was then and now still is one of the country’s leading engineering schools. At one point she very famously did stand up to tell government to piss off. This happened in early 2020 when she stated that GM would not support efforts to block California’s waiver allowing them to set their own emissions and air quality standards.
01-21-2024, 04:42 PM | #17 | |
Drives: 2023 Vivid Orange Camaro 1LT Join Date: Jun 2023
100% Correct, EV's will not work in the long run
Not sure why this current disaster of a government is shoving them down our throats ?, Unless those losers are invested in it, which would explain some of it. Also the Save the planet nuts, it isn't going to save anything, it has just as many issues and harm for the planet.
01-21-2024, 06:16 PM | #18 | |
2017 HyperBlue 2SS
http://www.camaro5.com/forums/showthread.php?t=30755 2010 IBM 2LT RS......Traded for..... 2012 IBM 2SS RS......Traded for..... 2017 HBM 2SS |
01-21-2024, 09:25 PM | #19 | |
Drives: Camaro 1LE Join Date: May 2018
01-22-2024, 12:17 AM | #20 |
Drives: 2020 Rally Green ZL1-1LE Join Date: May 2020
I've done the math and the power grid cannot handle the total replacement of ICE vehicles with EV's. There is no where near the capacity, especially if you want to charge in 1/2 hour and go.
IMO, the best path forward is to eventually upgrade home power to 480v 3-ph. Why? Because a 2 port fast charger is 62.5KW. If running that on 240v 1ph, thats 260 amps at full capacity. 200a home power is only rated at 80% continuous, or 160a so you have to get your service upgraded to 400a which is actually 320a continuous leaving you 60 amps of overhead. However, 480v 3ph is much more efficient and would cost less on your power bil in the long run due to a couple of reasons. Upgrading to 3ph wont be cheap though! Now, California has 14 million cars. Its simple math to figure out how much power would be needed to charge all of them at once, but thats not realistic. Is is 1/8th at any given time? Is it a 1/16th at any given time? Is it a 1/32nd? At any rate, the power capacity is monumental but its simple to come up with a number. Consider this too, the power companies will HAVE to regulate EV charging at night because thats when the demand will be highest. I smell disaster! California is already dealing with brown outs all the time, they are decommissioning carbon based power plants, and the new CARB/SORE regulations for 2024 have already went into effect so small gas engines such as those for back up portable generators will be illegal to sell into California after 2028 so best get em while you can. The drive to eliminate carbon there is in full effect!!!! On top of all of this, the plan is to eventually have only electric semis operating in California. I've no idea what this will add but Cummins launched Accelera in 2023 to develop electric OTR trucks and bring them to market. It would stand to reason that their main market will be California first. As someone else pointed out, increasing the demand while lowering the supply doesnt math out right. |
01-22-2024, 12:57 AM | #21 |
Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
Not to mention the billions they are investing in removing coal and natural gas energy for wind and solar. I'm not against green energy, but they are not ready to replace reliable sources yet. To make them reliable we would need large scale batteries and we would also need to build enough generation plants to 'over-produce' in order to charge those batteries as you cannot charge them if you are only supplying at demand levels.
That is going to cost ALOT of money. |
01-22-2024, 06:19 AM | #22 |
Drives: 2023 Chevy Camaro 2LT V6 6MT Join Date: Sep 2023
If you have to plug-in for a charge to have freedom of travel you are in the hands of government and I don’t trust them to do much of anything right. Especially when you get administrations with crazy agendas.
2023 Camaro 2LT V6 6MT Vivid Orange Metallic
01-22-2024, 06:49 AM | #23 | |
Drives: 2023 2SS Convertible Join Date: May 2009
-Geoff
'12 2SS RS Convertible - Traded in.
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold! '23 2SS Convertible -Same as above except orange. |
01-22-2024, 07:50 AM | #24 | |
2017 HyperBlue 2SS
01-22-2024, 08:55 AM | #25 | |
Somewhere in the Kalahari
Drives: 2021/18 (de-fresh) 3LT RS Join Date: Dec 2017
01-22-2024, 09:01 AM | #26 | |
Drives: 2023 Camaro LT1 6.2 MT6 Join Date: Jan 2023
EV - Extended Vacation. You'll need an extended vacation if you travel more then 50 miles from your home in an EV. EV's aren't about "saving the planet". EV's are all about taking away our freedom of movement. It comes as no surprise to this former gm employee that they stopped listening to their customers when gm didn't even listen to it's employees! gm has always been top heavy, but back in the day they still managed to put out products people liked. gm became lazy, gave up without trying, and blamed everyone but themselves for their poor sales. Rather than fighting, gm just eliminated divisions driving those divisions loyal customers to their competition. Employees could see the problems a mile away, yet upper management chugged along, became yes men for bad ideas and then blamed all of their problems on their assembly workers. I sold all of my gm stock the moment they went on their "downsizing" craze on the factory floor, while upper management stayed intact. Every employee on the floor knew that gm was on a path to bankruptcy. Killing the Camaro is just another example of what's really wrong at gm...gm has been run by imbeciles for far too long! |
01-22-2024, 09:16 AM | #27 |
Drives: 2000 WS6 Join Date: Dec 2014
here's a video of the Munro evaluation of the Ultium stamped steel million-weld skateboard,
https://youtu.be/jB_vDkaO3hU https://news.yahoo.com/gmc-hummer-ev...175600928.html All the General's eggs appear to be in this basket and I fear for this company's future, esp since there seem to be so many issues with mass producing it so far. |
01-22-2024, 09:57 AM | #28 |
Drives: 2023 SS 1LE Sharkskin Join Date: Jun 2023
Bottom line is consumers DO NOT want EV's. Sure, you have yuppies buying Teslas, but that does not mean your working class American wants them. If they did, they would not be languishing on dealer lots (Ford F150 anyone). Americans want reliable and affordable transportation, and EV's ain't it. They can't tow much for long, they suck in cold weather, and you better budget $10K-$30K when the battery dies. If the government were not forcing the car manufacturers to produce these boring appliances due to global warming BS, they would only sell in California. It is absolutely laughable that the government thinks we will all be driving these boring, unreliable cars in 10 years. Never gonna happen!
ΜΟΛΩΝ ΛΑΒΕ
