02-10-2022, 06:32 PM | #1 |
Drives: 2012 Camaro 2ss 45th anniversary Join Date: Nov 2021
Offroad Vs Non?
I am looking at Texas Speed for headers for my 2012 2ss ls3. I was wondering which ones to go for I just want straightpiped from the headers back. I was confused on what the offroad headers are and I dont want them not to fit. I also dont know if I should go with 1 7/8 inch or 2 inch. The 2 inch seem a lot more expensive. Sorry if I sound dumb I truly don't know and I am trying to learn.
02-10-2022, 07:24 PM | #2 |
Drives: 2015 Z/22 Join Date: Aug 2015
Offroad referring to headers/cats generally means that they're not meant for the street because they may or may not be street legal depending on the state/province (emissions-related). If your state/province doesn't require your car to have cats - or you just don't care about getting a hefty fine - go for it!
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
02-10-2022, 07:42 PM | #3 |
Sporting Foole
Drives: 2010 Camaro SS Join Date: Sep 2019
racin stuff
02-11-2022, 08:26 AM | #4 | |
Drives: '20 Corvette Stingray Join Date: Jul 2009
exhaust, headers |
