Old 07-22-2019, 10:25 PM   #1
XxshadowdawgxX
XxshadowdawgxX's Avatar
Drives: 2012 Camaro ZL1
All the boost. No power?
So I️ had a 388ci motor built by a very reputable shop and it was not cheap. Ive done three different forced induction setups. Every setup yielded very high boost numbers around 20-24lbs. But the hp/tq numbers just aren’t there. I’ve put every best part I️ can on the car at this point hoping it would solve the issue. The car seems to spew oil and such into then catch can. Like literally a half day of driving is a full catch can, so yeah it’s pretty ****ing bad. I️’m going to have a leak down and compression test done. But what would cause this, it’s basically been like this since the motor was built. Any opinion or advice is wanted, thanks.
*2012 Camaro ZL1 (1 of 69 preproduction) A6*
376CI Built Bottom End LSA (10.1:1) Ported LSA Heads, BTR STG 3 400+ CI Camshaft, F1X Procharger - Cogged, Holley Sniper High Rise Intake, 1 7/8” TSP Headers, 1700CC ID Injectors, Fore Innovations Triple 450lph, DSX Flexfuel Sensor. Making 1000+rwhp. Tuned by Tuning by Shane Hinds LLC.
XxshadowdawgxX is offline   Reply With Quote
Old 07-22-2019, 11:06 PM   #2
UNRIVALED SS
UNRIVALED SS's Avatar
Drives: 2010 Camaro SS
Send a message via Yahoo to UNRIVALED SS
Send some more info.
What are the hp/tq numbers?
If you are using HP Tuners post the tune file for review.
With 24 pounds you should be around 1300 hp give or take.
UNRIVALED SS is offline   Reply With Quote
Old 07-22-2019, 11:10 PM   #3
XxshadowdawgxX
PMing now.
Old 07-23-2019, 06:02 AM   #4
5thgenlife
Drives: zl1
Sounds like your rings are not sealing. You should have figured this out before changing setups 3 times.
5thgenlife is offline   Reply With Quote
Old 07-23-2019, 08:45 AM   #5
XxshadowdawgxX
Yeah sometimes you don’t want to believe your brand new $15,000 motor is ****ed.
Old 07-23-2019, 11:59 AM   #6
hillshooter
Drives: 2015 Camaro SS commemorative
Your problem starts with Pro and ends with charger. 24 pounds of boost maybe but at what, 50% parasitic loss? Motor I am sure is fine and is begging for a turbo. I have been down this road , they are heat pumps at best.
2015 Camaro SS, LS3 Stroker, PRC heads,CUSTOM CAM. AGP 68/68 with custom Hot and Cold side. Fore triple pumps, Holley terminator X. BMR drag suspension with carlyle brake kit. 15" ET drags and 17" skinnies. ZL1 3.73 gears , aluminum driveshaft. TH400 with circle D converter.
hillshooter is offline   Reply With Quote
Old 07-23-2019, 12:00 PM   #7
hillshooter
also in for the tune file.
Old 07-23-2019, 12:50 PM   #8
sscamaro
sscamaro's Avatar
Drives: 2010 2SS, 2017 Silverado LTZ
The engine came stock with 376 ci. How come yours is 388ci? That's only 12ci gain. A stroker motor is 418ci.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
sscamaro is offline   Reply With Quote
Old 07-23-2019, 02:12 PM   #9
bct10985
4.125” bore
Old 07-23-2019, 05:40 PM   #10
XxshadowdawgxX
The car has had 2 different prochargers and a roots blower and made very piss poor power with all 3. When I️ say piss poor, I️ mean piss poor. I️ traded my first Procharger kit to a guy with a stock LSA and he made 180rwhp more than my built motor with ported heads and all while making less boost. I️ don’t think it’s the Procharger. The engine also spews oil.
Old 07-23-2019, 08:04 PM   #11
davidscamaro
davidscamaro's Avatar
Drives: 2010 SS/RS M6 BIG cam
Oil getting past the rings or need a much much better catch can route for the lines
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
davidscamaro is offline   Reply With Quote
Old 07-24-2019, 10:27 AM   #12
5thgenlife
Drives: zl1
His rings aren't sealing. It's not hard to figure out.
Old 07-24-2019, 01:32 PM   #13
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
Exactly! Sounds like washed cylinders.
Also get rid of the pro charger and go turbo.
ttshovel is offline   Reply With Quote
Old 07-24-2019, 04:14 PM   #14
AGP Turbo
Drives: All things Turbocharged
You should have amazing success with that engine, sounds like you have a lot of good parts. Could be losing a ton in your transmission.
You should call Kevin @ AGP 480-401-1515. That much oil in your catch can it must be hooked up wrong.
AGP Turbo is offline   Reply With Quote
