Old 11-12-2018, 03:21 PM   #1
XxshadowdawgxX
XxshadowdawgxX's Avatar
Drives: 2012 Camaro ZL1
Supercharger - Making 1/2 boost
Hello Folks,
I am wondering if anyone ever ran into this issue before. My supercharger is making 8lbs of boost when it is suppose to be making in the upper teens the way it is pullied. On the low side you could say it should at least be at 16lbs. The blower has been rebuilt due to a faulty bearing that caused the rotors to lock up. This is the first time the blower has been back on the car. Has anyone seen a blower lose more than 8lbs out of nowhere? I realize it could be a bypass issue and such, but has anyone else ran into this issue before where it was the bypass or something I am not thinking of?
*2012 Camaro ZL1 (1 of 69 preproduction) A6*
376CI Built Bottom End LSA (10.1:1) Ported LSA Heads, BTR STG 3 400+ CI Camshaft, F1X Procharger - Cogged, Holley Sniper High Rise Intake, 1 7/8” TSP Headers, 1700CC ID Injectors, Fore Innovations Triple 450lph, DSX Flexfuel Sensor. Making 1000+rwhp. Tuned by Tuning by Shane Hinds LLC.
XxshadowdawgxX is offline   Reply With Quote
Old 11-12-2018, 04:26 PM   #2
Kelly@PCMofNC
Drives: 2010 RS/SS
Is this the factory LSA blower or something else?
Kelly@PCMofNC is offline   Reply With Quote
Old 11-12-2018, 05:47 PM   #3
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
I'd definitely check the bypass valve for proper adjustment. If that checks out okay, I'd check that the installation was correct and there isn't a leak between the blower and lower intake manifold, or between the lower intake manifold and head surface.
I guess it could be some serious belt slip also...
Hope you get it figured out!
-Scott
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 11-12-2018, 05:54 PM   #4
Zl1dad
Drives: 2013 zl1
Sounds like your bypass valve isnt functioning properly. There is a line from the snout to the valve, make sure that is on by pressure from that line helps fully close bypass.
On another hand, if you're on Facebook, come join our all 5th gen ZL1 only group
Zl1dad is offline   Reply With Quote
Old 11-13-2018, 02:56 AM   #5
swiftkart
swiftkart's Avatar
Drives: 2010 SS/RS LS3 M6
His sig. says Harrop TVS2650 which is a brand new blower that has issues.
swiftkart is offline   Reply With Quote
