Old 11-16-2012, 02:25 AM   #43
Normagene
Normagene's Avatar
Drives: 2013 Ashen Gray M6 ZL1
Originally Posted by 69NMYSS View Post
+1
Great looking picture, but you need some black lugs.
Problem solved. Gorilla Wheel Lock System, Black, Part #71643NBC. Looks way better. Torque to 122 pounds for the black rims, 110 on the aluminum ones.
Normagene is offline   Reply With Quote
Old 11-16-2012, 05:24 PM   #44
PNYSLAR
Summit White 2012 ZL1 M6
PNYSLAR's Avatar
Drives: 2010 BLACK 2SS/RS M6 Delvd 8/24/9
Originally Posted by Sven59 View Post
My thought too, if some don't make noise then all shouldn't.
Mine started the same thing last week. I thought it might be the additive, but I see that others have tried it so now I'm at a loss.
2012 Summit White ZL1 Manual 6sp Blk 10 spoke, "Thanks Champion Chevrolet" delivered 6/9/2012 #1588
PNYSLAR is offline   Reply With Quote
Old 06-14-2013, 01:21 PM   #45
DRTH VDR
DRTH VDR's Avatar
Drives: 2012 triple black ZL-1 #799
Relighting this thread...........my ZL 1 started to make differential noises at about 3200 miles when turning.
Took it to my dealer and they came up with the following service document:
#PIP5097: ZL1 Rear Differential Moan Noise On Turns - (Mar 6, 2013)
Requires total fluid drain and refill three times with specified driving requirements in between each drain and fill cycle to bring the fluid up to operating temp and scrubbing of the posi-parts. The correct fluid is GM part #88862624 which retails for about $22.00 USD for each 2.43 Qt bottle and several are used. Shop labor would have been over $300.00. Very sweet that it's a freebee under the PIP.
Routine differential fluid change is at 45k miles unless severe service is the case and then it's every 15k miles.
Hope this helps those who are experiencing similar Grannie Groans from the arse end of their ZL1's.
Cheers - Major Boyd
DRTH VDR is offline   Reply With Quote
Old 06-14-2013, 01:46 PM   #46
Sven59
HAMMER PILOT
Sven59's Avatar
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado
Cheers - Major Boyd
That sounds like what they did to mine months ago except I don't think they did the 3 fill and flush. Mine is starting to make slight sounds again, I think I will take it back to the dealer and see if they did it three times.
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
Sven59 is offline   Reply With Quote
Old 06-14-2013, 08:41 PM   #47
djnice
djnice's Avatar
Drives: 13 ZL1 SIM, 99 Z28 Black
Mine has a slight whine when slightly letting up the throttle at 60 mph. Guess I should take it in.
What does PIP stand for?
2018 C7 Z06 - WGG, M7. / 2013 ZL1 - SIM, 6 spd, RotoFab CAI, Can. / 1999 Z28 - Black, 6 spd, K&N, Subframe. / More Fun Stuff - www.inlandspeed.com
djnice is offline   Reply With Quote
Old 06-14-2013, 09:02 PM   #48
OldScoolCamaro
Drives: Camaro's, always have, always will.
Originally Posted by Dutchman427 View Post
Live Fast. Die Young. Leave a good looking corpse.
In Scott We Trust...all others must show proof.
OldScoolCamaro is offline   Reply With Quote
Old 06-14-2013, 09:17 PM   #49
roSSco
∞ Smiles per mile
roSSco's Avatar
Drives: 2013 ZL1 Summit White A6
I have the same issue. It's minor, but is an indication that something just ain't right. I might swap the fluid out myself after the 1500 mile break-in.
roSSco is offline   Reply With Quote
Old 06-14-2013, 11:45 PM   #50
djnice
djnice's Avatar
I changed the fluid and it didn't help.
Old 06-15-2013, 06:54 AM   #51
roSSco
∞ Smiles per mile
roSSco's Avatar
That's discouraging. :(
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
2013 ZL1 #4739
'Heisenberg'
Color - Walter White
Roto-Fab CAI
On Reddit? Check out /r/ZL1/
Old 06-15-2013, 01:00 PM   #52
DRTH VDR
DRTH VDR's Avatar
Why would you swap the fluid when your dealer will do it for you with two flushing refills for free? See post #45
Old 06-15-2013, 01:02 PM   #53
DRTH VDR
DRTH VDR's Avatar
I'll wager you didn't follow the GM PIP.................See post # 45
Old 06-16-2013, 03:22 AM   #54
djnice
djnice's Avatar
You are right. I should clarify.
I changed it at 1300 miles because I wanted to get the metal out before I started driving hard. Nothing to do with the noise.
Now that it has a very slight whine, I might see if the dealer will do what you guys are talking about.
