Old 10-06-2020, 02:04 AM   #1
jason7090
Drives: Figo Ford
BRAID TO FLUOROCARBON KNOT: STEPS FOR TYING THE UNI-TO-UNI
Are you thinking which braid to fluorocarbon knot to apply when attaching your leader in your line? While there are a few one of a kind fishing knots you may use, permit's recall one of the fine knots to apply for tying mild braid to fluorocarbon leader -- the uni-to-uni knot (additionally called the double uni-knot).
If you're getting to know a way to fish for inshore saltwater species like redfish or snook, this braid to fluorocarbon knot is a easy and robust one to start with. Here is cheap surf fishing rods for you. You can use those pointers for tying the uni-to-uni braided line to fluorocarbon knot.
As you get greater enjoy tying different fishing knots, you can find another braided line to fluorocarbon knot which you choose, however the uni-to-uni is a good line-to-line connection for beginners to study.
Overlap the braid and fluorocarbon strains that are to be joined. Be sure to leave about 6-inches of overlapping line on each aspect so that you could make several wraps.
Take the tag quit of the road from the left and loop it round to make as a minimum four wraps around each lines (if that is the aspect along with your braided line, double the quantity of wraps from 4 to eight for added energy), and then run the tag end via the loop that turned into fashioned.
Repeat with the tag end of the road at the right, reducing wide variety of wraps from eight to four if that is the fluorocarbon side of the uni-to-uni.
You have just tied two uni-knots. From this point, pull the status strains in opposite instructions in order that the 2 knots slide up towards every different (moisten each knots earlier than tightening on the way to save you line damage due to friction).
Trim each tag ends of the road close to the knot and you have effectively tied a uni-to-uni or double uni!
As you get more revel in tying one of a kind fishing knots, you can discover any other braided line to fluorocarbon knot that you pick, but the uni-to-uni is a great line-to-line connection for novices to examine.
jason7090 is offline   Reply With Quote
