10-02-2020, 12:06 PM | #1 |
Drives: SS A8, NPP, Red Hot Join Date: Jan 2019
Epoxy Recommendations
I bought a ZLE wing and don't trust the acrylic double sided tape that comes with it to attach the winglets. Any recommendations on permanent plastic to plastic epoxy?
10-02-2020, 12:19 PM | #2 |
I'll chime in first. This is easily the most durable, weather-proof epoxy I have used. Long working time.
https://www.westsystem.com/specialty...poxy-adhesive/ https://www.amazon.com/West-Systems-.../dp/B002IVAJ6Y |
10-02-2020, 12:27 PM | #3 |
Retired from Car mfrs....
Drives: 2LT RS/HR-V Join Date: May 2013
You’ll be fine with the tape. use an epoxy and if it ever breaks and you need to get it off you’re gonna ruin the fender… The key with the tape is to make sure you have an absolutely pristine clean surface that’s been rubbed down with alcohol.
10-02-2020, 12:43 PM | #4 |
2018 SS A8 11.85@117.06
Drives: 2018 Camaro SS A8 "Dark Knight" Join Date: Oct 2019
parts have been mounted with double sided tape for about 20+ years with no problems
DARK KNIGHT
2018 SS A8 11.85 @ 117.07 GPI Tuned E85 stock tires Roto Fab CAI LT 2 intake |
10-02-2020, 01:52 PM | #5 |
Drives: 2015 Camaro Join Date: Aug 2018
3M makes an adhesion promoter that works great for things like that. It's much better than alcohol.
10-02-2020, 04:21 PM | #6 |
Drives: 2017 1SS Hyper Blue Join Date: Apr 2017
I have window vent visors held on with 3M tape that haven’t budged a millimeter in the 17 years I’ve had my truck. Wind, ice, automatic car washes, no problem.
10-04-2020, 11:35 AM | #7 | |
Hot Camaro
OP - My side skirts are held on solely with 3M 4922 tape and haven't budged at all. These things are like 7 feet long and are subject to deflection forces from air moving around the car at speed. Here are some tips when gluing items like this: - Ensure that all surfaces are clean, dry, and smooth - Ensure that you "get it right" the first time - don't touch the pieces together, pull them apart, etc. - Ensure that you apply sufficient pressure to promote adhesion - Add heat if you're able (I used a hair dryer to keep the rockers / skirts warm for over 20 minutes once I installed each skirt, and I kept pressure on the pieces to hold them together). - Don't drive the car for up to 48 hours after installation (look up the details of how long it takes for these tapes to fully cure) of everything to ensure that the adhesive on the tape can fully meld itself into place before air movement starts applying opposite pressure on it |
10-04-2020, 01:21 PM | #8 | |
Drives: Red Hot SS 1LE Join Date: Dec 2015
10-04-2020, 03:02 PM | #9 |
Drives: 15 SilveradoLTZ,162SSVert BlazerRS Join Date: Dec 2015
The 3M tape is VERY strong, I have a trailer where that tape holds all of the outer skin together!!!! You would destroy the skin before the tape fails!!!
10-04-2020, 03:05 PM | #10 | |
If the vehicle or part has been repainted with some cheap paint, then all bets are off. I've only used it on factory OEM paint and high quality prepainted aftermarket parts. Never had a problem. |
10-06-2020, 08:14 AM | #11 |
Thanks for all the recommendations! I'll look into each one.
