BeckyD @ James Martin Chevy
Old 07-14-2020, 02:26 PM   #1
Teneck83
Drives: 2018 SS 1LE
Dead battery 18 ZL1LE
When not in use, I keep it on a maintainer. If the car sits without maintainer for a week or longer the battery is dead. Replaced it with an optima yellow top yesterday. Are dead batteries common ?
2018 ZL1 1LE
1966 Corvette 427/425 vert
1969 Corvette 350/350
Teneck83 is offline   Reply With Quote
Old 07-14-2020, 02:57 PM   #2
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
mine is a 2016 ss and mine died last spring so less than 3 years
Old 07-14-2020, 03:35 PM   #3
Teneck83
Drives: 2018 SS 1LE
I tested it at autozone and they stated it was head. Yet at home shows 12.7 volts. Is there more to the battery?
2018 ZL1 1LE
Old 07-14-2020, 05:25 PM   #4
Vigilante375
Drives: 2018 Camaro ZL1
Mine sits for 2 weeks or more at a time before I drive it. Never had any issues with the battery. Though I do drive it every day for about 2 weeks before letting it sit for another 2 weeks.
2018 with 17k miles.
How much do you drive it once you do get to drive it? I would think a good trickle charger would keep the battery maintained.
Vigilante375 is offline   Reply With Quote
Old 07-14-2020, 05:52 PM   #5
supersportss
Drives: 2019 SS
It's not volts that starts a car, it's amperage, you can have a battery with 12.7 volts but wont start the car due to no/low amperage. Test machines put a draw on the battery for amp draw.
supersportss is offline   Reply With Quote
Old 07-14-2020, 05:58 PM   #6
Mark R
Drives: 2018 ZL-1
Bad batteries can show good voltage just sitting, but under load they fail to deliver the juice. A good trickle charger / maintainer can keep a battery alive for many years. Mine is plugged in every time I park the car, because I only drive it a few times a month.
Mark R is offline   Reply With Quote
Old 07-15-2020, 10:59 AM   #7
Schlok
Schlok's Avatar
Drives: 2015 Z/28 #397 2022 ZL1 #1799
Lead acid batteries want to live at a high state of charge, 13.4V or so and you’ll be set. Get a good maintainer a leave it connected when not driving. There are some fairly decent “ battery testers” on Amazon that are “same same” as the Midtronics EXP-1000. That’s a ~2k tool that kicks ass but the $50 Amazon one will do a CCA test and let you know “ good or bad” battery. They do a quick pulse to see if it can deliver the 600 or so CCA rating. I’ve tested the Amazon tool against the Midtronics and the results are the “same” and the numbers close enough.
Schlok is offline   Reply With Quote
Old 07-15-2020, 11:17 AM   #8
ZX-10R
ZX-10R's Avatar
Drives: 2019 ZL1 Riverside
https://www.amazon.com/OptiMATE-Ampm.../dp/B003UANXCE
The best auto charger on the market
These cars eat batteries. Turning over a 6.2L takes some juice
ZX-10R is offline   Reply With Quote
Old 07-15-2020, 11:35 AM   #9
PROMETHEUS
PROMETHEUS's Avatar
Drives: 2019 ZL-1, Shadow Gray, Sold
Mine sits on a charger anytime it is in the garage. Only takes a minute to take it off and the hood being open is a "good" remainder that it is on there, LOL!
PROMETHEUS is offline   Reply With Quote
Old 07-15-2020, 12:39 PM   #10
Teneck83
Drives: 2018 SS 1LE
All the replies are greatly appreciated.
2018 ZL1 1LE
Old 07-15-2020, 08:34 PM   #11
Yessa
Drives: 2015 Camaro Z/28
The best auto charger on the market.
Yep, that is a good one!
Yessa is offline   Reply With Quote
Old 07-16-2020, 02:54 PM   #12
DFW_Muscle
Drives: 2018 Chevrolet Camaro ZL1
Right, however, just because it reads 12.7V with no load doesn't mean it's a good battery. One or more cells could have failed inside it, not allowing it to put out the amperage (CCA rating) it needs to work properly. Parts stores will use a tool that load tests it, which can determine the battery health. I am sure that's what they did.
Unfortunately, ACDelco batteries failing within a few years is certainly not uncommon.
DFW_Muscle is offline   Reply With Quote
Old 07-17-2020, 07:38 AM   #13
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Get a Batteryminder tender they have a desulfurator mode and will often bring a battery back. Brought mine from 60 % to 90 %.
2019 ZL-1 Acquired 4/23/21 at 6300 miles. Riverside Blue, A10, PDR. Traded in 2017 2SS with 6M and 32k miles. Continental Extreme Contact Sports. Now has 10,000 miles...
2012 Yukon XL Denali w/ 6.2 AWD
avalonandl is offline   Reply With Quote
Old 07-17-2020, 09:12 AM   #14
ZX-10R
ZX-10R's Avatar
Optimate does that and it's better quality. I've tried them all
