BeckyD @ James Martin Chevy
Old 01-26-2017, 09:55 PM   #1
Canadian ZL1
Canadian ZL1's Avatar
Drives: 2017 ZL1, 1995 Trans Am
Front plate dilemma SOLVED - 2017 ZL1
In case anyone was wondering...here is the best option for having to mount a front plate on the Zl1.
Save 5% - You're welcome!
https://youtu.be/Tmt1MGHYHdo
Codes from Sponsors!
➤ Save 5% on all ZL1addon parts and accessories with coupon code lethal5 - http://bit.ly/2gCQBzg
Canadian ZL1 is offline   Reply With Quote
Old 01-26-2017, 10:00 PM   #2
Ghost7997
Ghost7997's Avatar
Drives: 2014 Ultimate Track SS "Weapon-X"
Very interesting. Thought you drilled holes at first. Had a small heart attack lol
"Speed has never killed anyone, suddenly becoming stationary... That's what gets you." -Jeremy Clarkson
Ghost7997 is offline   Reply With Quote
Old 01-26-2017, 10:18 PM   #3
Canadian ZL1
Ha ha..funny looking at the picture your right it does look that way. Watching the video will give you peace of mind.
Old 01-27-2017, 09:46 AM   #4
Hellobatman
Hellobatman's Avatar
Drives: 2017 Ford F250, 2019 Lincoln Navi
Just put a rho plate on my V...great quality as well.
Instagram: MattZ_L1 Vengeance Racing Built
Hellobatman is offline   Reply With Quote
Old 01-28-2017, 01:51 PM   #5
gblaue
gblaue's Avatar
Drives: 2017 Bright Yellow ZL1 6spd
Another option is the sto n show bracket for the 2016-2017 Camaro, with a small modification. The mounting bolts need to be moved inward and forward on the mounting plate.
I placed a center line front to back. The mount bolts need to be ~7.75cm from the center line of the bracket. The bolts need to be ~1.25-1.5cm in forward, with respect to the original mounting holes. This will put the plate ~1/2" in front of the peak of the air splitter. I put a piece of 3/4" foam between the plate mount and the air splitter, to reduce any chance of rattle. The stock screws seem to be long enough.
One note, in addition to the instructions above. Turn the mounting bracket around 180 degrees. The straight edge, now, goes toward the rear.
Or, you can wait for them to make the correct bracket.
2017 ZL1 Bright Yellow w/ black center stripe, 6 speed, CF gas door, PDR, Navi
gblaue is offline   Reply With Quote
Old 01-28-2017, 02:17 PM   #6
stella16
1959 Chevy Apache 4X4
stella16's Avatar
Drives: 2017 ZL1
gblaue
what does it look like stowed?
stella16 is offline   Reply With Quote
Old 01-28-2017, 02:41 PM   #7
gblaue
gblaue's Avatar
Originally Posted by stella16 View Post
gblaue
It's got a pull-pin underneath. The plate comes off in 2 seconds.
http://shop.bigmikesperformanceparts...-2SS-SNS89.htm
Old 01-28-2017, 08:13 PM   #8
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
Hmm... interesting. I did a hide a plate on my 5th gen and have been happy but I do like how you can completely remove this one.
9/26/09 Took delivery!
Old 01-29-2017, 11:37 PM   #9
Canadian ZL1
Quick update guys. It appears they now make specifically a front plate holder for the ZL1. When I originally posted my post it was for the SS model. The link is below.
https://zl1addons.com/collections/to...nt=29234027009
Old 01-29-2017, 11:48 PM   #10
Canadian ZL1
I love the placement BUT it is a little too low for my liking. I know it will most likely scratch the payment at some point. I believe they make the same one you have but it has a remote where it automatically flips and hides underneath.
I found this; http://www.pfyc.com/GN1018.html
P.S I do love the fact that is allows the full air flow without covering up the grill.
Old 01-30-2017, 07:44 AM   #11
gblaue
gblaue's Avatar
I only have 600 miles on my car, so far, but I find it seems less likely to hit going into parking lots than my Gen5 ZL1. I was thinking about welding on a little skid plate to add reinforcement to the mount. The motorized mount would be a waste of money. One good curb hit, and you'll scatter all the electronics all over the place. I'm not a fan of the plate being up, and to the left. I got a thing for symmetry. Bottom line, there is no good place for a front plate.
Old 01-30-2017, 10:52 AM   #12
iPODFAN11
iPODFAN11's Avatar
Drives: 2019 Shock ZL1
Ya guys know the factory bracket is 100% removable right?
From Super Chevy mag, April 2002: "Most of the weekend Settlemeire was meeting and greeting and quickly became known as simply "The Camaro Dude" (note, even his initials are SS)."
we're certainly looking at it -- but right now, the emphasis MUST be on getting the Camaro V6 and SS out -- and having it exceed your expectations....
Once that's done....................
iPODFAN11 is offline   Reply With Quote
Old 01-30-2017, 10:59 AM   #13
gblaue
gblaue's Avatar
Yup, it's just as ugly as all others. This plate comes off in 2 seconds, litteraly. The stock bracket, not so quick, and it won't hold up to be taken off frequently.
Old 01-30-2017, 11:54 AM   #14
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
I haven't seen how it mounts....I just assumed there was drilling involved....if there is no drilling into bumpers and/or covers..., I may consider it.
