01-20-2014, 12:25 PM | #1 |
Drives: 2011 Camaro 2SS/RS Vert Join Date: Jul 2011
Continental or Nitto?
I need to decide this soon... Which is the better tire overall?
Nitto Motivo or Continental ExtremeContact DWS Continental: http://www.tirerack.com/tires/tires....r=RS%20Package Nitto: http://www.discounttire.com/dtcs/fin...634&vid=020300 Price isn't really a big deal, I have a friend that will get the best price available. I have been looking for too long and am in need of new rears, but ill be replacing all 4. Thanks for your opinion!
01-20-2014, 06:39 PM | #2 |
Drives: 45th 2LT/RS Join Date: Aug 2012
I just got new tires also and i was in the same situation you are in. I went with the Nittos because they had a better warranty from discount tire and i liked the tread pattern over the DWS.
2012 45th 2LT RS, LG ZR28 (20x10 20x11) 275/40/r20 315/35/r20, MRT V2.0, Black bowties, MGP Caliper Covers, 15% Tint all around
01-20-2014, 10:16 PM | #3 |
ill have to post up the pics of my continental dws tires. I ended up going with them as I wanted a good looking tire that matched in 275 & 315 sizes.
01-21-2014, 12:00 AM | #4 |
instigator
Drives: 2020 6.2 Trail Boss, 2022 XC90 Join Date: Jan 2010
Conti
-John S.
01-21-2014, 12:30 AM | #5 |
Side shot
01-21-2014, 12:31 AM | #6 |
One more
01-21-2014, 06:10 AM | #7 |
SSmokinJoe
Drives: 2010 SIM 1SS/RS M6 Join Date: Feb 2010
I got about 40,000 miles out of my Continental DWSs. I use my car as a daily driver. I liked the tires. They were relatively quiet, good traction, and good tread life.
1SS/RS Silver with Black Rally Stripes.
35% Tint Roto-Fab CAI SLP Loudmouth II Axleback Hurst Shifter R1Concepts Slotted Rotors Hawk Ceramic Brakepads I drive way too fast to worry about my cholesterol. |
01-21-2014, 09:11 AM | #8 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
In a test I saw, the DWS's ranked just below the Pilots in overall performance. They have lots of sizes available as well. I'm running 295/40's in the rear and 255/45's in the front, all on the OEM 20's. They look perfect on the wheels, with just a very slight bulge. My thinking is, they help protect the lip and the extra sidewall softens the ride a tad (I have 1.25in drop springs). They were actually cheaper than the OEM size DWS's. I've driven in rain, sleet and snow and they flat out work. There are better tires for specific purposes but not many for all around performance. FWIW, tirerack is about $20/tire cheaper on the DWS's.
I'm not saying they are better than the Nitto's cause I haven't used them or heard of anyone using that particular tire.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. Last edited by axis; 01-21-2014 at 09:21 AM. |
01-21-2014, 10:10 AM | #9 |
Wow! Thanks for all the replies! My main concerns and the reasons im not getting the pirellis are tread life and sound. Sounds like everyone likes the Conti's, i've asked a lot of different tire places too, but the Nittos are fairly new so that might have some effect. I like the warranty on the Nittos, but I like the look of the Conti's. I want to keep the performance look, but enhance ride and sound. Thank you for the pictures ex-ss-ve!
01-21-2014, 10:14 AM | #10 | |
When you replaced, did you stick with the Conti's? If not, what did you switch to?
01-21-2014, 03:39 PM | #11 |
Guest
I will be buying my nitto motivo in two months and i have been researching for a long time...they are for a 11 rs...and I'm a flat out aggressive driver. What I have found is this...The utrg on the continentel is 480 and nitto is 560 which makes for potentially longer tire life. ..less sticky as they are harder. Also reading other forums and on tirerack...There are those customers that say the continental loose alot of performance after halfway point on the tread life. Yes the nitto are new...but so far it's constantly rated a great tire. Tire rack doesn't sell nitto so another source has to be found. Big O tires is a nitto dealer and their prices aren't half bad.
01-21-2014, 04:05 PM | #12 | |
2010 2SS/RS M6
Drives: 2010 2SS/RS M6 Join Date: Jun 2010
The only downside is they give up a bit of grip during the hot summer months. I'm considering going with a 2nd set of rims/tires for summer use and keeping the Conti's on my stock rims for Oct-March use.
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter Bumblebee Racecar Build |
01-22-2014, 04:44 AM | #13 |
SSmokinJoe
I replaced the Conti's with General G-MAX AS-03s, but it was only due to cost. I put a lot of miles on my car, so I tried the less-expensive tires this time. If money were not an issue, I definitely would have bought the Contis' again.
I actually bought a set of slightly used Conti's for the rears. As soon as the General rear tires wear out, I'll put the used Conti's back on.
35% Tint Roto-Fab CAI SLP Loudmouth II Axleback Hurst Shifter R1Concepts Slotted Rotors Hawk Ceramic Brakepads I drive way too fast to worry about my cholesterol. Last edited by jmelchio; 01-22-2014 at 10:38 AM. Reason: Put in wrong tire |
01-22-2014, 06:44 AM | #14 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
My winter tire in the Conti Extremes. Love them for the cold, wet traction.
