Vararam
Old 09-03-2015, 08:11 AM   #1
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
New ERL motor is tuned for road course action
I just finished with my tuning session at RPM in Delaware for my road course setup. The mods are as follows:
ERL LS2 block sleeved to LS7 bore with LS7 crank. Still displaces 7.0L. Forged pistons and crank. 11:5.1 compression.
B-3 Cam and Advanced Induction cylinder heads
ARH 1 7/8" headers...no cats.
MSD atomic airforce upper intake
Nick Williams 102mm TB
ATI balancer
The tune is conservative and the shop temp was 95 degrees and humid so take that into account...even with corrected dyno #s. Final #s were 575rwhp/500tq. I will post the graph later. It is so much smoother than before and very responsive. Can't wait to get it back to the track!
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 09-03-2015, 08:33 AM   #2
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
What have you done for oiling?
Old 09-03-2015, 08:40 AM   #3
Trackman
Trackman's Avatar
Drives: 67RS Camaro ,Black 2013 ZL1
Wowzers , cool
Trackman is offline   Reply With Quote
Old 09-03-2015, 09:03 AM   #4
Stephen12ZL1
Drives: '21 ZLE A10
I kept the same LS7 oil pump, pan, tank, etc.
Old 09-03-2015, 09:04 AM   #5
JusticePete
Did you consider a dry sump or accusump?
Old 09-03-2015, 09:42 AM   #6
Stephen12ZL1
Drives: '21 ZLE A10
Z/28 is a dry sump from the factory. I retained all of the stock dry sump parts.
Old 09-03-2015, 09:49 AM   #7
JusticePete
575 at the fly or wheels?
Old 09-03-2015, 09:49 AM   #8
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
The way the LS7 oiling works its only part dry sump, there is still oil in the pan.
2SSRS@Gen5diy is offline   Reply With Quote
Old 09-03-2015, 09:53 AM   #9
2SSRS@Gen5diy
http://www.aviaid.com/pdfs/z06retrofit_kit.pdf
Old 09-03-2015, 09:55 AM   #10
Stephen12ZL1
Drives: '21 ZLE A10
575/500 to the wheels
Old 09-03-2015, 09:57 AM   #11
Stephen12ZL1
Drives: '21 ZLE A10
sure...maybe a quart or so in the sump. If I'm not mistaken, all dry sumps have some oil in the sump with the majority of the oil in the tank.
Old 09-03-2015, 10:00 AM   #12
JusticePete
Vented or closed crank case?
Old 09-03-2015, 10:01 AM   #13
pgviper
Drives: 67 Pro Touring Camaro
Send a message via AIM to pgviper
Great results. Lets get a video of that bad boy!
pgviper is offline   Reply With Quote
Old 09-03-2015, 11:35 AM   #14
Stephen12ZL1
Drives: '21 ZLE A10
stock pcv system which appears closed. The Z/28 has a little extra tank on the side of the oil tank that the C6 Z06 doesn't have. It is t'ed into the pcv lines that connect to the valve covers. I may change it to an aftermarket setup if I have any issues with oil ingestion.
