dave@hennessey
Old 02-27-2021, 01:37 PM   #43
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Redline or LS Driven in my opinion. I like the Redline 5w30. A little thicker than most off-the-shelf stuff, more zddp, etc. Stock bottom end still gets a 30wt in my opinion. I doubt your failure had anything to do with viscosity, personally.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides-
2014 ZL1 M6 Red Hot | Tons of mods
2004 CTS-V M6 Silver | Many mods
1995 Corvette M6 Torch Red | A few more mods
1992 Camaro M5 White | A few mods
RobZL1 is offline   Reply With Quote
Old 02-27-2021, 02:01 PM   #44
beersngars
Drives: 2012 ZL1
LS Driven.. This is the oil Hutter Racing pushes. They build lots of high HP engines including NASCAR stuff.
beersngars is offline   Reply With Quote
Old 02-27-2021, 06:11 PM   #45
silversleeper
Big Crow
silversleeper's Avatar
Drives: '13 ZL1
Originally Posted by Bigtime53 View Post
I cannot express this enough STAY AWAY FROM PENNZOIL!!!! Maybe some of you like that oil but not me. I have had catastrophic damage to motors in the past with this oil. I do not know about the synthetic oil but just having pennzoil on the bottle scares me away from it.
I had it ruin some small gas engines with sludge way back in the 80s, before there were synthetic oils. I haven't heard of anything out of the ordinary on their current full synthetic or their base oil either for that matter. I did stay away from it, like you, until recently because of that.
I'm not saying it's better than the other oils mentioned previously in my opinion, just sayin' it might be ok, even if it's not the best.
silversleeper is offline   Reply With Quote
Old 03-01-2021, 02:05 PM   #46
RyangAsh
Drives: 2014 ZL1
Originally Posted by Astatenate View Post
Man that’s crazy. Every LSA guy Z or V around here is running that 20w50 VR1 and I was the only one running 5w30 and I somehow spun a bearing. Both my tuners at GPI recommended the VR1 as well. As it’s not daily driven. I guess I’ll do some more research.
Yeah I could see that. Do we have an aftermarket option that would work well? Haven’t done much research on the pan.
Yeah for sure. Upgrading bearings and oil pump, with big cam for sure while it’s out. I don’t have the power goal of 1,xxx so I think I’ll be fine just with OE parts (crank, etc) if destroyed. But we shall see.
Care to explain why? I never really understood pan volume in comparison to a HV oil pump. If the pump is flowing more sufficiently then what’s the need for a bigger pan? Just curious.
I run 20-50w vr1 in my big block...not saying it isn't good oil, the tolerances in an LSA aren't meant for it though. Shit, you can spin a bearing anyway though..
RyangAsh is offline   Reply With Quote
Old 03-01-2021, 02:31 PM   #47
Happy_Dan
Happy_Dan
Happy_Dan's Avatar
Drives: 2012 IOM Camaro ZL1 #569
Send a message via AIM to Happy_Dan Send a message via Yahoo to Happy_Dan Send a message via Skype™ to Happy_Dan
Just remember that VR1 had no detergents in it. Meant for race applications.
Happy_Dan is offline   Reply With Quote
Old 03-03-2021, 01:25 AM   #48
Astatenate
Astatenate's Avatar
Drives: 2015 ZL1
The cars only brought out and beat on. So I guess it’s pretty much a race car. Oil is changed every 1.5-2k miles. So 5-20 wouldn’t be too bad. I just feel like if I’m not upgrading the oil pump. I at least need a better oil in there. Gives me peace of mind.
787WHP/ 719TQ | Fully Forged Short Block | Custom Spec GPI Cam | DSX aux pump & FF sensor| 1200cc FIC Injectors | Lingfelter 10.0” pulley & ATI damper | RotoFab Intake | ZZ Performance solid isolator | Kooks Headers | Corsa Catback | AFCO dual fan HX | Reinforced IC brick | AEM 3-in-1 Gauge | GPI Tuned | Carbon Fiber WickerBill | Morimoto Tail-lights | WELD S71 + ET STREET R’s
Astatenate is offline   Reply With Quote
Old 03-03-2021, 04:51 AM   #49
CJ27
Drives: Chevrolet camaro zl1
In the same boat. Spun a rod bearing and in the process of rebuilding right now. I too was running mobil 1 5w 30. I was not even getting on it just cruising and heard the knocking. I did notice for about a month before the oil pressure at idle only showed 14 to 15 psi when warm.
2014 Sliver ZL1. Built engine, Stage 1 Frankenstein heads, Magnuson, SW long tubes, AFCO H/E, She Gone cam, flex fuel sensor, meth injection. 820rwhp e85.
CJ27 is offline   Reply With Quote
Old 03-03-2021, 01:07 PM   #50
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Both of these unfortunate incidents sound like they have more to do with the movement of the oil than the oil itself.
Past Rides-
Old 03-03-2021, 01:29 PM   #51
xdamxincx
Drives: zl1 blk
there are many reasons these lsa's have bearing issues.. i have studied it some .. the lsa is set up with tight tolerences from factory with the forseen concept that the aluminum motor will grow when heated up. Aluminum motors expand and contract more than a cast iron block. I feel the lsa's get some premature wear upon start up and if the car is not up to temp before seeing some load may be a contributing factor.. I think we should gather some data.. like which bearing/pics, oil specs, oil psi, start up treatment,mileage. etc... might be able to get a better understanding of whats causing these issues. but there are a lot of factors to consider ...
xdamxincx is offline   Reply With Quote
Old 03-03-2021, 02:04 PM   #52
Astatenate
Astatenate's Avatar
Drives: 2015 ZL1
I could give my personal experience. If anyone would like. To Talley them up lol
Sure are
But I guess I’ll be at least making sure my factory oil pump is good. If it is. I’ll leave it alone. If not. Then I may upgrade to HV one. Regardless a better oil is going in it. With e85 dilution. I feel like 5-30 M1 isn’t going to cut it. And have my Rev limit moved from 7k back down to like 6500.
Geez man. Sorry to hear that. You going 416 or just rebuild?
Old 03-03-2021, 09:41 PM   #53
DrkPhx
DrkPhx's Avatar
Drives: 2013 Triple Black ZL1 / 2006 TB SS
IMO 7000 rpm is way too high for a stock LSA with the stock valves which are very heavy. It also spins the SC excessively high and generates a lot of heat which translates into high combustion chamber temps which is never good. I've run Mobil 0w-40 in mine since 2014 when I swapped cams. It's a good oil imo. 12.4 AFR at WOT is on the lean side and with too much timing can cause failures. Even with TF heads I keep mine on the conservative side for AFR and only shift at 6500 rpms. I've been down the stroker road before with my previous set up and it gets expensive fast.
DrkPhx is offline   Reply With Quote
Old 03-03-2021, 10:40 PM   #54
CJ27
Stock displacement but better pistons, rods and Frankenstein stage 1 ported heads. Oh and the "she gone" cam.
Old 03-04-2021, 08:04 AM   #55
Risingson05
Risingson05's Avatar
Drives: 2015 zl1 m6
I replaced my oil pump to a 10355 for my truck . From what I was told by tsp that stock oil pumps tend to cavitate and starts to aerate at Rpms above 5500rpms .
When it’s time to do my z I will be replacing my oil pump , as I’m changing the cam right from the get go, I’ll already be there , plan on cutting cross member and using that kit I bought from here to modify cross member to get the oil pan out . To me it’s just that much more extra insurance besides the pump is only like 200-300.00 from what I remember . I’ve also always ran driven ls-30 and I do have a mm catch can aswell .
I’ve been running cam and. Other bolt ons for my truck for over 3 years now
Risingson05 is offline   Reply With Quote
Old 03-04-2021, 08:07 PM   #56
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Originally Posted by Risingson05 View Post
I replaced my oil pump to a 10355 for my truck . From what I was told by tsp that stock oil pumps tend to cavitate and starts to aerate at Rpms above 5500rpms.
That is accurate. Here is the graph:
Past Rides-
