TireRack
Old 06-08-2018, 03:58 PM   #1
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
Improving Traction?
Does installing rear cradle bushings and new trailing arms actually improve traction on the street? I know it helps with wheel hop but I'm hoping it will give the car some more bite too? Any feedback would be great.
zz430camaro is offline   Reply With Quote
Old 06-08-2018, 04:55 PM   #2
Synner
Drives: cars
Improved stability and reduced wheelhop, they won't bite anything or anyone.
Synner is offline   Reply With Quote
Old 06-08-2018, 05:20 PM   #3
KillboyPowerhead
Drives: 2015 Z/22
They most certainly do; after I did mine I could feel a difference when I stepped on it and I only have a little ol' V6, so I suspect the difference would be even more noticeable in a V8.
Edit: maybe I misread the post, but said upgrades will keep the tires on the ground when accelerating by reducing wheel hop as mentioned, so they'll improve traction from a stop
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
KillboyPowerhead is offline   Reply With Quote
Old 06-08-2018, 05:57 PM   #4
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
nope....
frankwjr is offline   Reply With Quote
Old 06-09-2018, 06:39 AM   #5
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Drives: Kami, 2013 2SS LS3 Luvin
Send a message via MSN to Scott@Bjorn3D
If you are dropping more torque than the tires can handle they will spin. The only tires I have found that I can not break loose smashing the throttle on my while going about 10-20mph are the MP4S. Even regular Pilot Super Sports I can spin thru.
Running 285/35-20 all the way around.
Scott@Bjorn3D is offline   Reply With Quote
Old 06-09-2018, 07:18 AM   #6
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
You're kidding right? I've got 305/35/20 nitto 555R drag radials which are much more sticky than pilots and I can still break them loose and chirp the gears with little effort. Engine is still stock.
TheFlyingBananaSS is offline   Reply With Quote
Old 06-09-2018, 08:16 AM   #7
frankwjr
frankwjr's Avatar
if I run my DR's on the street at 30 psi they break lose....at the track at 12 psi and a burnout...not so much...
peace.
btw - my BFG comp 2's do a good job, especially in the rain...
Old 06-09-2018, 10:35 AM   #8
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2021 Shadow Grey Camaro 2SS 1LE
Those items will help stabilize the rear. The cradle bushings help the IRS feel as part of the car in turns, not follow the cars in turns. Both really helps in autocross that I do a lot of. As to traction I have every part to reduce wheel hop and I don’t seem to have that issue. Traction though? I run RE71R’s 305/30/19 for autocross, I can only leave the start at 1500 rpm to get could bite. Past that no way.
VR Baron is offline   Reply With Quote
Old 06-09-2018, 02:18 PM   #9
Scott@Bjorn3D
I am talking about when already rolling, not reving up engine and dropping clutch and breaking them loose.
Old 06-09-2018, 03:15 PM   #10
zz430camaro
Drives: 2015 1LE
I will have to remember this next time I get new rubber, thanks! I was looking to those tires too.
Old 06-09-2018, 08:03 PM   #11
quickdrraw
quickdrraw's Avatar
Drives: 2015 Z/28
It is a night and day difference in how the power is put to the ground. IMO yes, it improves every aspect of the handling.
2015 Camaro Z/28 Black
Sold:
2010 Camaro 1SS/RS
quickdrraw is offline   Reply With Quote
Old 06-09-2018, 09:31 PM   #12
TheFlyingBananaSS
peace.
We have near identical setups. I have the sport comp 2 on the front and the nitro 555R on the rear. Same tire pressures!
