TireRack
Old 09-19-2020, 10:15 PM   #1
OHIOSS
Russ
Drives: Yukon Denali, Charger, CamaroSS
Send a message via AIM to OHIOSS
Has anyone read about the premature failure of starters in the SS?
While looking for something else I came across this article about problems with the heat shields causing the starters to overheat and fail. Yesterday after driving the car for about 20 minutes I shut it off to get gas and the starter was barely able to turn the car over. I don't think it is a battery problem because I put in a new battery a couple of years ago.
This may be old news so sorry for posting if it's already been discussed.
https://gmauthority.com/blog/2020/09...amaro-starter/
OHIOSS is offline   Reply With Quote
Old 09-19-2020, 10:22 PM   #2
mikeman
Drives: 2015 Camaro
Brand new batteries only last a couple of years though. Could be the starter, but it also could be the battery too.
mikeman is offline   Reply With Quote
Old 09-19-2020, 10:30 PM   #3
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
Yeah, it was posted here a few weeks ago. Regardless of the age of the battery that is the first thing I would have tested so you are not chasing this.
InFiD3ViL is offline   Reply With Quote
Old 09-20-2020, 11:37 AM   #4
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
Kinda hits a sore spot don’t it. Thread is already dead.
Camaro2ss2010 is offline   Reply With Quote
Old 09-20-2020, 07:18 PM   #5
oldman14ss
Drives: 2014 1ss camaro
there is a class action law suit for that very thing.
oldman14ss is offline   Reply With Quote
Old 09-20-2020, 08:21 PM   #6
SS 310H55A
Drives: 2014 Camaro SS
I just had my ‘14 SS sitting in 110 degree heat. Started right up. Drive home 75 miles in 95-100 degree heat with a/c on, stopped at home to unload the trunk, hopped back in and started back up no issues whatsoever. Maybe the issue is related to starters with some mileage on them? I’ve got 24k, so still fairly new.
I have an ‘06 avalanche with 215k miles and service history from prior owner documenting multiple starter replacements. If I had to take a guess, I’d say GM starters are all around problematic, generally speaking.
2014 SS | MGW Flat Stick shifter | Raceseng Slammer shift knob | Z/28 spoiler and grill
SS 310H55A is offline   Reply With Quote
Old 09-20-2020, 08:45 PM   #7
InFiD3ViL
InFiD3ViL's Avatar
lol yup!
