Vararam
Old 09-19-2020, 03:49 AM   #1
Texamaro
Texamaro's Avatar
Drives: 2011 Camaro SS, 2004 Silverado 2500
Exhaust quietting recommendations? 2011 Camaro SS
Hi all! Im looking for some recommendations on quietting my car down a bit and hopefully eliminating some of the drone going down the highway.
It's a 2011 Camaro SS, cammed, tuned (all that good stuff). Currently has long tube headers, cat deletes and magnaflow dual center exhaust system (not sure model).
Prior to the cat delete and long tube headers, but with MagnaFlow, I loved how it sounded. Now I barely want to start my car after 9pm for neighbors sake.
Any tried and proven recommendations to keep my set up but add on something to mellow the sound a bit?.
On a bit if a budget but would like a permanent solution.
Someone mentioned adding a bullet?
Thanks in advance!
Texamaro is offline   Reply With Quote
Old 09-19-2020, 05:05 AM   #2
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
Put the cats back on.
TheFlyingBananaSS is offline   Reply With Quote
Old 09-19-2020, 06:14 AM   #3
MrChrisLS3
Drives: 2018 1SS M6
You can either put in some hi flo cats, which will be a good move in the long run if you are in an emission testing county.
The only other thing is to add mufflers. Magnaflow makes a great muffler, many call it a resonated x pipe. It's just a dual in dual out muffler with an xpipe in the center of it. I had one of these on my '96 Corvette that had no cats and no mufflers. I had no drone or resonance what so ever. Also did it to my otherwise stock 2011 SS Camaro.
For a cammed car with headers, maybe a combination of a true x-pipe with mufflers might work the best to get rid of that drone.
MrChrisLS3 is offline   Reply With Quote
Old 09-19-2020, 10:47 AM   #4
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
Have J pipes installed by someone that knows what they are doing.
Camaro2ss2010 is offline   Reply With Quote
Old 09-19-2020, 12:48 PM   #5
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
^^^^ This as mentioned above. I had this issue before and installed a Magnaflow resonated x-pipe, did the trick for me, no more drone and a bit quieter too. Then I finally was able to do a complete 3 inch catback system, now I'm getting ready to order a new Corsa catback system.
Here is the resonated x-pipe.
https://www.phastekperformance.com/C...pipe-11386.htm
Old 09-19-2020, 07:25 PM   #6
Avenging Orange
Avenging Orange's Avatar
You could always find a stock cat back on the cheap.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 09-19-2020, 08:23 PM   #7
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
Good lord man, did someone lift the car up with the trans pan? Mine caved in a bit when I had the jack under the pan during my engine swap and that was from just resting on it. I swapped in a new OEM pan for $25 or so. I got nervous because the trans filter/pickup feet rest against the bottom of the pan and I was worried about any fluid issues.
InFiD3ViL is offline   Reply With Quote
Old 09-19-2020, 08:47 PM   #8
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
I'd go back with the OEM cans on it. They actually sound pretty darn good with headers, remind me of Hush Thrush mufflers.
SlingShot is offline   Reply With Quote
Old 09-19-2020, 10:07 PM   #9
OHIOSS
Russ
Drives: Yukon Denali, Charger, CamaroSS
Send a message via AIM to OHIOSS
Can you install exhaust cutout's? I have them on my SS and I love them. I get tired of the drone and the engine popping sound when I decelerate. I want it loud I open the cutouts, want it quiet I just close them.
OHIOSS is offline   Reply With Quote
Old 09-19-2020, 11:52 PM   #10
SSJ2
SSJ2's Avatar
Drives: 2010 2SS CAMARO
J pipes took care of all the unbearable drone on mine. I currently have long tubes with hi flo cats straight pipes and muffler deletes
BBK Long tube headers, Hi flo cats, straight pipe muffler delete with j-pipes. K+N CAI, Soler Performance Ported Throttle Body, Soler Performance Throttle Controller, Phantom Grill, MGW flatstick shifter. 3.91 Gears, Ported Rod Mod Intake, ZTA Spoiler, Rohana RC22 20x10 20x11.
SSJ2 is offline   Reply With Quote
Old 09-20-2020, 11:19 AM   #11
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Amen to that !! Here, this with the stock exhaust..
Old 09-20-2020, 07:23 PM   #12
oldman14ss
Drives: 2014 1ss camaro
I have solo j-pipes axle back. works for me. not that cheap but, stainless and you never have to worry again.
oldman14ss is offline   Reply With Quote
Old 09-20-2020, 07:30 PM   #13
lemontwist
lemontwist's Avatar
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled
off topic but for the love of god don't put another fram oil filter on that car.
lemontwist is offline   Reply With Quote
Old 09-26-2020, 06:46 PM   #14
Texamaro
Texamaro's Avatar
Sorry for the delayed reply guys been out of state with my dad who's currently fighting cancer and I got super side tracked.
Thanks all for the suggestions! Still going through options but need to order something asap.
Also as an FYI for the above comments I got the car with the beat up trans pan and Fram oil filter. Both have been replaced. Lol..
