Vararam
Old 09-21-2015, 04:53 PM   #1
Ace0751
GEN5 Detail
Ace0751's Avatar
Drives: 2011 Synergy Series 2SS Convertible
Became Victim to Reduced Power
My time has came to be a victim of the reduced engine power message. Luckily I was not on the highway but was driving home today and it came on, had to baby it home. I have the VTC and took that off and now everything is fine minus the check engine light being on. Probably just disconnect the battery to have it reset or if anyone knows a better option please post. So I will probably have a VTC on sale sometime soon along with a K&N CAI that I still want to get rid of that's clogging up space lol. Just sticking with my tune now and if I want more throttle response I'll contact RDP. What a good way to start off the week.
Roto-Fab CAI, Borla ATAK Exhaust System, Stainless Power Headers, RX Performance Catch Can, ACS T4 Splitter, Oracle side markers, Dyno Tuned by RDP Motorsports
Ace0751 is offline   Reply With Quote
Old 09-21-2015, 05:33 PM   #2
splashlog48
splashlog48's Avatar
Drives: 2011 Green SS M6
Good Idea--Let someone else deal with that POS
splashlog48 is offline   Reply With Quote
Old 09-21-2015, 05:45 PM   #3
Draven1327
Socal Mayhem
Draven1327's Avatar
Drives: 2010 RJT 2SS/RS (KYORI)
what setting did you have it on?
Draven1327 is offline   Reply With Quote
Old 09-21-2015, 06:14 PM   #4
Ace0751
GEN5 Detail
Ace0751's Avatar
SP4
Old 09-21-2015, 06:32 PM   #5
Spec
Drives: 2010 Camaro 1SS LS3
The CEL should disappear after a few 'cycles', and the ECU no longer detects an issue.
Spec is offline   Reply With Quote
Old 09-21-2015, 06:50 PM   #6
clashley1976
clashley1976's Avatar
Drives: 2011 Camaro 2LT RS M6
If you have a buddy at autozone, they can clear the code for you.
Sent from my SM-N900V using Tapatalk
-Cameron Lashley
Albany, GA
2011 Camaro 2LT/RS 3.6L M6 Summit White w/silver rally stripes
CAI intake, VTC, VMax PTB, VMax Iceolator, Apex intake scoop, Roto-Fab washer bottle relocate
Build Journal: http://www.camaro5.com/forums/showthread.php?t=419992
clashley1976 is offline   Reply With Quote
Old 09-21-2015, 06:54 PM   #7
Ace0751
GEN5 Detail
Ace0751's Avatar
I'll give it this week to see if the light goes off if not I'll get it cleared. Need to up the throttle response though cause I can feel the difference. But that can come spring since the temps are cooling down.
Old 09-21-2015, 10:28 PM   #8
zenben
Drives: 2015 2LT
Vitesse says that most problems occur with ported throttle bodies. I see in the signature that your vehicle has one. I wonder if there are any VTC fails with a stock throttle body.
zenben is offline   Reply With Quote
Old 09-21-2015, 10:36 PM   #9
Dizzy82
Dizzy82's Avatar
My VTC has caused my car go into limp mode, but only because it is tuned. The VTC and tunes don't always play nice together.
Old 09-22-2015, 12:55 AM   #10
Squishy
Squishy's Avatar
Drives: 2016 camaro 1SS
And for this same reason is why you see at least 2 VTC on the marketplace every week.
2016 BLK Camaro 1SS/LT1 M6:
NPP | black front/rear bowtie | Blacked out taillights
2011 IOM Camaro 1SS/RS LS3:
Stainless works 1 7/8" LT headers w/ Offroad pipes | TSP Cam 235/239 on a 112 | Powerbound 25% UD Pulley
Roto-Fab Cold Air Intake | SW Retro Chambered Catback Exhaust | VMax Ported TB | Hurst Short Throw Shifter
Trunnion upgrade | LSA Oil Pump | BMR 1.25 Spings | R1 Concept d/s Rotors
Tuned by Lashway Motorsports - 501 Hp 430 ft-lb
Squishy is offline   Reply With Quote
Old 09-22-2015, 01:09 AM   #11
sixtyseven
sixtyseven's Avatar
Drives: 2015 Camaro 2LT/RS 2017 XL1200C
Right here stock TB.
Happened one time.
Pulled the CEL code.
P2138
Accelerator pedal position (APP) sensor 1-2
ECM has detected that the APP sensor 1 and APP sensor 2 disagree more than 4.5% for less than 1 second.
Probable cause:
1) Poor electrical connection
2) Failed APP sensor
2015 2LT/RS Black -w- CGM Rally Stripes. CAI, Elite CC, Apex air scoop + w/b kit, JacFab ported IM/Extendolator, Solo HFC's, Corsa Sport Cat-Back #14953, GM strut brace, GM stealth splash guards, GM premium floor mats, Defenderworx two tone sills, Emblem Pro LFX hood emblems, FR41-20x9/20x10 gloss black wheels, OK91/93 - OKTCM Tune.
sixtyseven is offline   Reply With Quote
Old 09-22-2015, 01:21 AM   #12
1Canuck
1Canuck's Avatar
Drives: 2014 2LT RS
yes, sensor in TB failed, new TB and now no problems.
Probable cause:
yes, connection at TB was not tight. after reading issues with pedal sensor after VTC install leads me to think the connections are the source of the problem. many similar reports that on reset or unplug/replug that no more issues does not point to VTC component?
1Canuck is offline   Reply With Quote
Old 09-22-2015, 09:20 AM   #13
Ace0751
GEN5 Detail
Ace0751's Avatar
If it does it again then I know it's the ported TB but don't think that was the case though. Car ran much better today and was not jerky at all in the shifts.
Old 09-22-2015, 09:26 AM   #14
Venomous
Venomous's Avatar
Drives: 2015 Silver Camaro 1lt RS M6
Happened to me. It takes about 5 starts to clear the engine light.
Cold air induction cai, ported throttle body, Vitesse Throttle Control, Oracle Ghosted LED side markers
Venomous is offline   Reply With Quote
