12-21-2015, 04:09 PM | #15 | |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2013
01-07-2016, 01:45 PM | #16 |
Ok..update on all of this. JerTM I checked the wiring you suggested and no issues there. Ended up replacing the throttle body...still had the issue. So at this point I figured it has to be the accelerator pedal sensor...replaced that as well, still same issue. Checked my spark plug wires and found that one of the wires was not snapping into the coil properly, plug wire connection was partially broken. Replaced all the wires and did the spark plugs while I was in there. After all this...same issue. So now i am at my wits end and ready to take it in to the dealer. I have a friend that works at a small indy shop and he asks me to bring it in today so they can run some diagnostic tests free of charge (yes, I know...should have done this first).
He told me that it had over 30 codes stored and they were baffled at first because once the codes were cleared the car seemed to run fine. But then when he test drove it hard the service stabilitrak & reduced engine power started acting up again. After a few hours they found that the ECM module itself was loose & with hard acceleration it was shifting the module around and tweaking the connection slightly making the car go hay wire. He ended up strapping it up tight with a couple of large wire ties and bingo...no more issues. I haven't seen what is going on with it yet and how he rigged it up but I'll take a look at it later when I pick up the car and maybe get some photos uploaded. Probably end up finding a cleaner way to get it secured in there tight instead of wire ties. So...if you have this issue check that your ECM is snapped in tight with no movement. I'll keep you guys posted if I start having the issue again but supposedly that did the trick. |
01-07-2016, 02:32 PM | #17 |
Destroyed by flooding
Drives: Wife's car Join Date: Mar 2014
Thanks for sharing and updating OP. Things like this can help others and I hope that took care of your issue.
