Go Back   Chevrolet Corvette Stingray C7 Forum > Technical Forums > LT1 (6.2L V8) Powertrain and Drivetrain Discussions
Old 01-25-2013, 02:27 PM   #1
chrisrefaei
What are y'all choices of C7 Corvette exhaust systems? Thinking of straight pipess
So lets hear it, since I'm sure more than everyone is leaving the exhaust as a option that they would improve. MY options are either going with a Borla Full Cat-Back, or going to cut the whole thing out and go straight pipes and re weld the Stock tips exactly how they were originally. What are y'all thoughts?
2008 Mitsubishi Eclipse Spyder (SOLD)
2010 Mitsubishi Ralliart Sportback (SOLD)
2002 Toyota Camry XLE
(Can't wait to add her too my garage!!) (2014 Corvette Sting Ray: Cyber Metallic Gray with Red and Black Interior)
chrisrefaei is offline   Reply With Quote
Old 01-25-2013, 02:41 PM   #2
Stingray
just can't get enough
Stingray's Avatar
First and foremost... I want to be mesmerized by muscular tunes from that stock quad exhaust setup... and if possible, the NPP option.
It'll be :music: to my :ear:
Old 01-25-2013, 02:43 PM   #3
ec1990
Drives: 2012 AGM SS
Whichever sounds best, but always leaned towards Bassani, Borla, Corsa, although the Stainless Works is awesome on the Camaro.
Although with AFM I may just leave the upgraded performance from GM on since it has exhaust flaps to counter the drone.
ec1990 is offline   Reply With Quote
Old 01-25-2013, 02:47 PM   #4
chrisrefaei
Do any of y'all think when the car shuts off half the cylinders while cruising, that there you be a sound problem when running straight pipes?
Old 01-25-2013, 02:49 PM   #5
chrisrefaei
Whats NPP? Thank you
Old 01-25-2013, 02:49 PM   #6
Stingray
Stingray's Avatar
= :sad::sad::sad::sad::sad:
Old 01-25-2013, 02:51 PM   #7
Stingray
Stingray's Avatar
...similar to what the new Camaro has... a Variable Tuned Performance Exhaust option but obviously engineered specifically for the new
Old 01-25-2013, 02:52 PM   #8
chrisrefaei
Thank you!
Old 01-25-2013, 02:54 PM   #9
chrisrefaei
So its best to just stick with a Pre made system from either Borla or Corsa probably uh?..
Old 01-25-2013, 02:55 PM   #10
Stingray
Stingray's Avatar
Too premature to answer... we'll see later this year!
Old 01-25-2013, 02:57 PM   #11
chrisrefaei
Gotcha , most likely we can wait for some to post test about it.
Old 01-25-2013, 04:07 PM   #12
Gohan
Guest
Posts: n/a
Nice, I like seeing talk of modding already
I've always been a fan of Borla and Corsa. But the factory exhaust already sounds pretty good!
Old 01-25-2013, 04:33 PM   #13
OctaneZ28
Camaro Disciple
OctaneZ28's Avatar
Drives: 2013 Camaro 2SS/RS
Send a message via AIM to OctaneZ28 Send a message via Yahoo to OctaneZ28
Definitely want NPP. My C6 has it and I love it.
And it's even better with the Mild2Wild remote control.
As far as cat-back exhaust goes, stock is sufficient.
Aftermarket systems just change the noise, they're not worth much power, if any.
But headers are definitely worth it, so long tubes would be in the plans for sure.
2013 Camaro 2SS/RS
OctaneZ28 is offline   Reply With Quote
Old 01-25-2013, 05:57 PM   #14
chrisrefaei
You so read my mind about the Long Tube headers, that's why I originally wanted to go straight pipes, but most likely I'll do Headers to stock cat back and see what that brings and then consider a cat-back. And your right about it not being about the power gain over noise, cause thats truly what I'm really going for is the noise factor.
