Old 12-25-2013, 04:43 PM   #1
killascrimp
Drives: 14 z51
Mold in my Break fluid?
I backed into my driveway and lifted my hood to clean engine bay when I took off the cap of brake fluid. I looked and saw black cloudy possibly mold in the fluid?? Is that normal? And what causes it. I just need to know if I need to do anything about it or leave it be thanx.
killascrimp is offline   Reply With Quote
Old 12-25-2013, 06:34 PM   #2
Silversled
Drives: 2016 ZL1 1LE
I know on aluminum bodied master cylinders on my motorcycles (Brembo), a black cloud of aluminum suspension builds up in the fluid. I'm wondering if that is what you're seeing. I do not believe that brake fluid will sustain mold.
Silversled is offline   Reply With Quote
Old 12-25-2013, 06:44 PM   #3
killascrimp
Drives: 14 z51
ok ya I tried to get it out w my finger and it just made it cloudy kind of strange, just checking I might flush it out just for fun.
Old 12-25-2013, 07:59 PM   #4
bnall40
Drives: Z51 3LT, 2009 Pilot, 2012 Ody Tours
What is the year make and mileage of your vehicle?
bnall40 is offline   Reply With Quote
Old 12-26-2013, 07:50 AM   #5
killascrimp
Drives: 14 z51
its a 14 z51 1400 miles. got it in October.
Old 12-26-2013, 08:34 PM   #6
kiteboarder
Drives: C7 on order
Are you sure its your Brake fluid and not Clutch fluid resevior (similar to brake fluid) I assume you have a Manual trans? ...If so that is likely clutch wear particles due to the hydrolic system, its a common problem with the C5 and C6 you can watch youtube vids on how to flush properly, if it is clutch fluid then you will want to flush on a regular basis to avoid your clutch pedal from sticking
kiteboarder is offline   Reply With Quote
