03-31-2016, 01:05 PM | #15 |
Drives: 2013 Camaro 2SS RDP Tuned L99 Join Date: Apr 2013
To me they are just 2 different approaches to achieve a similar end goal. I am not aware that the Coyote has any more failures than the LS series but I honestly don't know. I would expect QC of the engine build would be more important.
As noted about the oil pump failures on the LS3's and some L99's I believe too, it was shavings from the block machining that was plugging the pumps. Thats just poor QC or workmanship. |
03-31-2016, 01:30 PM | #16 |
Drives: 2018 1SS M6 Join Date: Nov 2014
The OHV/cam in block engine allows for greater power density. They can give us larger displacement, which results in more torque and broader power band, in a smaller and lighter package. At least this is the answer GM engineers give whenever they are posed with this question, and the numbers generally seem to back it up.
03-31-2016, 02:16 PM | #17 | |
Drives: 2014 2LS (traded in) 2015 1SS 1LE Join Date: Apr 2015
03-31-2016, 02:39 PM | #18 | |
Destroyed by flooding
Drives: Wife's car Join Date: Mar 2014
03-31-2016, 02:43 PM | #19 |
03-31-2016, 04:43 PM | #20 |
Drives: 2010 Camaro 2SS Victory Red 6M Join Date: Apr 2015
The simple fact is an engine is an air pump. The more fuel/air it can ingest and burn, the more power it will make. GM does it with large displacement engines and Ford does it with higher flowing and faster turning dohc. Typical comparison is any pushrod 4cyl vs a dohc 4cyl of equal displacement. The last pushrod 4cyl engine I can recall is the old LN2 2.2L GM engine that was in the S-10 and J-body cars. Made a measly 90-110hp. The Ecotec is the same displacement and makes more hp/tq. You can also compare said engine to Honda's F22C engine. same displacement but makes 220hp. To get the same power out of the LN2 would require a ridiculous cam and radical cylinder head. VVT like Honda, Ford and others use allows a fairly large cam while still giving great driveability and emissions. Honda has their own ace by using 2 separate cam profiles all together and switching them as rpm dictates. Yes a dohc V8 is physically bigger externally than a similar pushrod V8. That doesn't mean it's heavier. The Coyote and LS3 are within 15lbs of each other. Smaller, higher rpm engine with higher flowing heads get the same job as a bigger, slower turning engine. Both have pros/cons. I look at it this way, when you can build an all out Mod Motor that makes just as much, if not more power than a similarly built LSx engine while using mostly oem parts vs mostly aftermarket parts, who has truly made the better engineered engine? Again, pros/cons of both. Both great platforms and both great cars.
2011 2SS 6A Red Jewel Metallic, Vararam Tune CAI, Magnaflow 3" Competition c/b, Speed Engineering 1-7/8 LT's, Circle D 5C, M/T 275/40R20 S/S, HPTuners tune by Ryan@GPI
12.3 @ 112 ACM as of 12/22/19 Gone on 12/28/19 R I P 2010 2SS 6M Victory Red/Black (old ride) CAI intake, Speed Engineering 1 7/8" LT's, X4 base tune, Flowmaster Outlaw axle-back. 12.6 @ 115 SAR as of 9/19/15 Gone but never forgotten. |
04-01-2016, 12:59 PM | #21 |
Who cares? Capt. Butthurt
04-01-2016, 01:08 PM | #22 |
Drives: 11 F150 EB/13 Sonic RS/15 Z06 Join Date: Sep 2010
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread |
04-01-2016, 01:10 PM | #23 |
Fast Cars and Old Guitars
I just went to two Home Depots driving the hell out of my Camaro. Not once did I think of the valve train configuration. It was a good day.
04-01-2016, 01:59 PM | #24 | |
2010 2SS/RS
04-01-2016, 03:21 PM | #25 |
04-01-2016, 03:22 PM | #26 | |
