Vararam
Old 01-07-2014, 01:28 PM   #15
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
Originally Posted by Vette TPI View Post
I agree, I am just wondering the measurements so I know how well it will cover my stock cowl.
Well your corvette had a double hump hood cowl and this is made for a relatively flat side to side installation. It will probably not sit right on it. You also need to consider the front to rear curvatures if your hood compared to a Camaro Hood. How far back were you going to place it on the hood? All the way back to the back edge? Also the water drainage you need to consider.
You may want to consider hex vents I am sure you could get them to work.
The Bird is the word!
Old 01-07-2014, 01:40 PM   #16
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
If no one responds to this request, I will measure mine tonight for you.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 01-07-2014, 01:40 PM   #17
Vette TPI
Vette TPI's Avatar
Drives: 1987 Corvette TPI
I'm fine with working out those small problems, that's why I need the measurements so I can find out if it will fit back too far. I mainly want the extractor in front of the engine.
Vette TPI is offline   Reply With Quote
Old 01-07-2014, 01:42 PM   #18
Vette TPI
Vette TPI's Avatar
Thank you!
Old 01-07-2014, 01:48 PM   #19
Angrybird 12
I would go out and measure mine but it's under a blanket if snow and it's 10F outside.
Old 01-07-2014, 01:53 PM   #20
el ess A
Older Than Dirt
el ess A's Avatar
Drives: 2010 & 2013 Camaros
Just in front of the scoop openings, it's about 21-7/16" wide. About 6" from the rear of the insert, it's about 23-3/4" wide. About 40-1/2" long from front point to the back.
All measurements done by my wife's super-accurate (yeah, right) cloth sewing measuring tape and thus listed as approximate. But this should give you an idea.
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
http://www.camaro5.com/forums/image.php?type=sigpic&userid=26108&dateline=142898  4774
el ess A is offline   Reply With Quote
Old 01-07-2014, 01:54 PM   #21
Vette TPI
Vette TPI's Avatar
I understand, thank you.
Old 01-07-2014, 01:55 PM   #22
Vette TPI
Vette TPI's Avatar
Thank you!
Old 01-07-2014, 01:58 PM   #23
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
Are you sure it will apply downforce? GM spent a lot of money and man hours in the wind tunnel to get this system to work on the ZL1. No doubt it will look cool, though. Good luck with the project.
Old 01-07-2014, 01:58 PM   #24
Vette TPI
Vette TPI's Avatar
I just measured the cowl on my C4 and it should fit just about perfect! A little modding is understandable as this is not going on a Camaro. I'll also welcome other measurements
Old 01-07-2014, 02:05 PM   #25
Vette TPI
Vette TPI's Avatar
Yes it should, the air goes just under the nose through the radiator then out the ZL1 extractor hopefully
Old 01-07-2014, 05:31 PM   #26
ZL1-V
ZL1-V's Avatar
Drives: 2013 Camaro ZL1
Unless you make provisions for the catch basin over your radiator as the ZL1 has you will get water runoff into the engine compartment.
ZL1-V is offline   Reply With Quote
Old 01-07-2014, 07:27 PM   #27
Stephen12ZL1
Drives: '21 ZLE A10
look at a pic of the insert. It is 41" from the cowl to the front point center to center. It is 22 1/2" wide at the center point of the hood.
Old 01-07-2014, 08:13 PM   #28
Vette TPI
Vette TPI's Avatar
It will clear the engine plenty, my worry is it actually going to far forward and touching the radiator.
