Vararam
Old 01-13-2018, 10:30 AM   #1
Divindirty
Divindirty's Avatar
Drives: Camaro 2ss/rs
looking for shop in socal to do gear change?
Any recommended shops in socal that I can drop off the rear end to have the gears done professionally ? I just want it done right from someone that does these day in and day out! im in the riverside area but will drive if that's what it takes, thanks for any input!!!!
Divindirty is offline   Reply With Quote
Old 01-14-2018, 02:32 AM   #2
Deftones
Deftones's Avatar
Drives: 2012 RS/SS LS3
Cunningham Motorsports
Deftones is offline   Reply With Quote
Old 01-14-2018, 10:45 PM   #3
Divindirty
Divindirty's Avatar
thanks ill call them and check em out!!
Old 01-14-2018, 11:02 PM   #4
SynergyGreenSS
SynergyGreenSS's Avatar
Drives: 2011 2SS
Cunningham, Accelerated racing solutions, new era, D3
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears
SynergyGreenSS is offline   Reply With Quote
Old 01-15-2018, 09:38 AM   #5
Divindirty
Divindirty's Avatar
thanks synergygreen!!!!! I noticed your auto with 3.91 gears? how do you like it? how bad is it cruising at 80 to 85 ish?? rpms up quiet a bit? thanks for any input
Old 01-15-2018, 09:55 AM   #6
SynergyGreenSS
Drives: 2011 2SS
At those speeds I’m cruising at like 3k. It’s not that bad especially if your exhaust doesn’t drone. The gears really wake the car up and make it feel a lot quicker off the line. I absolutely think they’re a worthwhile mod. Certainly one of the most noticeable things I’ve done to the car
2011 SS L99
Old 01-15-2018, 06:30 PM   #7
760bowtie
760bowtie's Avatar
Drives: 2014 1SS/RS, 2018 Silverado CC
Cunningham will only do it if you buy parts from them. If you already have the parts your best bet is to find another shop, if you don't then CMS is the place to go. I hear good things about Accelerated also.
AGP 57/57 turbos and Dual Pump System, NA Cam, McLeod RXT clutch, MGW shifter, ZL1 Rear End, BMR Trailing Arms/Toe Rods, Pegasus Solid Cradle Bushings 10.7 @140mph M6
760bowtie is offline   Reply With Quote
Old 01-15-2018, 09:43 PM   #8
Divindirty
Divindirty's Avatar
That sounds great😜!!!!!!! Thanks!!!!!
Old 01-15-2018, 09:45 PM   #9
Divindirty
Divindirty's Avatar
Great info thanks!!!!!!!
Old 02-11-2018, 10:27 AM   #10
Divindirty
Divindirty's Avatar
these shops are telling me to not put 3.91 gears in the auto that first gear would be too short and the 3.73 gears since they are not gm do not run long and eat up and they wont install them????? damn!!!! they are recommending 3.45?? I think that's barely a change from the 3.27 gears????? worth the money to do that little of a change??? im lost
Old 02-11-2018, 12:00 PM   #11
The_Blur
Moderator
The_Blur's Avatar
You'll have to report your experience at whichever shop you choose. It's always good to have a local installer. I can't go up to dynosteve in Ohio for all of my work.
I did my 3.91 up at RDP on a road trip. This gear upgrade will change your life.
warn 145:159 ban
Old 02-12-2018, 10:05 AM   #12
Divindirty
Divindirty's Avatar
are you an automatic trans???? how much more rpm for frw driving??
Old 03-07-2018, 02:21 PM   #13
V8only
Drives: 2012 camaro 45th 2ss/rs Centri SC
premier west gears-Carlos.
hes mobile and had amazing prices. He gutted and swapped all new parts into my bro's 06 avalanche and they came out perfect. 951 320 1390
V8only is offline   Reply With Quote
Old 03-13-2018, 12:14 PM   #14
Divindirty
Divindirty's Avatar
thanks ill call them today!!!! just saw this!!!
