04-19-2024, 10:15 AM | #1 |
Drives: Camaro LT1 RS V6 Join Date: Mar 2016
CAMARO OVERHEATING WHEN IDLE ONLY
So I’ve been having a issue where the Camaro only overheats when idle , I took it to a shop they told me it was the computer not telling the fans to kick on and now i have to take it to the dealer , has anyone else had this issue before I get ****ed with no lube by GM?
04-19-2024, 01:21 PM | #2 |
What do you call overheating? What temperature? Or does water actually boil out?
04-19-2024, 02:00 PM | #3 |
CamaroFans.com
Sounds like the shop made a decent assessment. That's what I was about to say.
04-22-2024, 12:11 PM | #4 |
Same here. If it is overheating at idle, probably the fans not turning on, because while you're moving, you have air flow to cool it down. I would have someone check the fan connectors and or fuses/relays for them. Good luck.
05-03-2024, 05:10 PM | #5 |
05-04-2024, 06:21 AM | #6 |
Drives: 2013 ZL1 Join Date: Sep 2021
Long shot but try disconnecting the battery for a few hours, sometimes the ECU's get confused.
ac fix, dealer, repair costs, repair failure |
