03-27-2015, 10:03 AM | #1 |
Drives: 2010 2SS IOM/IOM Join Date: Feb 2014
NPP Exhaust Sound Difference (M2M Retrofit)
I just recently installed a NPP Catback on my 2010 SS and retrofitted my own NPP in a box. (can create a DIY later if needed) I was disappointed in the difference between open and closed. The sound difference at idle is minimal. At WOT you can noticeably tell the difference. Has anyone else experienced the same outcome either with a factory NPP or a Retrofit? Also has anyone opened a Camaro NPP muffler to see if the straight through pipe has holes in it similar to the early Z06 mufflers? If so I was thinking about having a muffler shop cap the the straight through pipe.
03-27-2015, 10:28 AM | #2 |
Blue Ray SCPO
For the Factory NPP there is a fuse you can pull to keep it on the loud side. That's what I did and I will never go back. It does cause only one side to get dirty on your pipes which is one way to confirm that the flap is staying open.
There is a DIY guide on the forums, but I doubt its the same for a retrofit.: http://www.camaro5.com/forums/showth...=npp+fuse+pull You might need a mild to wild (or something like it) switch for it.
03-27-2015, 11:10 AM | #3 | ||
Drives: E92 BMW M3 Join Date: Oct 2012
Now that I have a cam, open vs. closed is an even bigger difference. Open is insanely loud and deep, even at idle(love it), and closed is much more tame and bearable for those that don't love it like we do.
J-Rod Built and Matt@FSP Tuned |
03-27-2015, 11:48 AM | #4 |
I have a similar setup to what you had. Kooks Header and Highflow cats. I guess my next mod needs to be a cam. I just thought there would be a more noticeable difference.
03-27-2015, 11:53 AM | #5 | |
Drives: 2015 Camaro 1SS Join Date: Dec 2011
03-27-2015, 12:50 PM | #6 |
yes with how i retrofitted my exhaust with a powered solenoid, I can open and close it at idle.
