Old 12-31-2023, 11:13 AM   #1
whitelt1
Drives: '23 LT1 Convertible (Auto)
Is wire harness relocation necessary on newer Camaros?
I'm hearing that wire harness relocation is not necessary on 2020 and later Camaros when running wider tires while some are saying it is. Anyone know what is the case?
whitelt1 is offline   Reply With Quote
Old 12-31-2023, 12:33 PM   #2
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Drives: 2020 2SS - A10, NPP, MRC, CAI
Depends on what size tires you are going to... If you are going to 305/30's then you are fine, if you go to 305/35, you probably should relocate the harness as a precaution...
BEFORE:
AFTER:
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires
Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph...
2SS Capt is offline   Reply With Quote
Old 12-31-2023, 12:39 PM   #3
whitelt1
BEFORE:
AFTER:
I see that you drive a 2020 SS so it looks like it is still necessary.
I'm thinking 285/35 square. The diameter would only be a 0.2" difference between that and stock. A 305/35 would be 0.7" from stock. I'm now wondering how 285/35 would fare.
Old 12-31-2023, 12:43 PM   #4
2SS Capt
2SS Capt's Avatar
I think you'll be fine with 285/35... Honestly, I moved my harness simply because I was already in there so figured the 15 minutes was worth the effort so I didn't have to worry...
Here is a guy running MRR 017 square setup on an SS with 285/35's: https://www.camaro6.com/forums/showthread.php?t=619771
harness, relocation, tire, wheels, wire
