Roto-Fab
Old 04-21-2018, 10:19 AM   #1
Kylejames83
Kylejames83's Avatar
Drives: 2011 camaro 2SS
Just 3.91 comment
I think it's insane that people are selling used 3.91 rear ends for $1,000 when at least where I live you can have a shop provide all the parts and labor and have all new stuff for $100-200 more.
Kylejames83 is offline   Reply With Quote
Old 04-21-2018, 10:23 AM   #2
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
If you buy the 3.91 rear already done you can sell your old diff...
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 04-22-2018, 05:44 AM   #3
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
I went with new gears and glad I did. Setup is perfect zero whine.
TheFlyingBananaSS is offline   Reply With Quote
Old 04-22-2018, 07:45 AM   #4
briancamaross
briancamaross's Avatar
Drives: 2011 ss 2ss auto camaro
I spent right at a 1000 to get mine done .
2011 2ss white Camaro mods are texas speed stage 4 cam 235/239 Texas speed 2inch headers no cats magna flow bullet mufflers gpi rod mod ,circle d 4000-4200 5c stall. 3.91 gears vararm cai power wedge.
briancamaross is offline   Reply With Quote
Old 04-22-2018, 07:53 AM   #5
Rcheli4fun
Drives: 2011 camaro 2SS RS
I bought a complete rear end from GM brand new for $1400 and still had mine to sell and it sold for $700 locally
Rcheli4fun is offline   Reply With Quote
Old 04-22-2018, 08:29 AM   #6
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
Similar experience here.
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
Old 04-22-2018, 09:54 AM   #7
havelegs
havelegs's Avatar
Drives: '23 LT1 A10
I paid 940 for a used 3.91. A new one when I was looking was 1500 or so. Most of the shops around me wanted to charge at least 900 for labor to swap the gears, plus the 450 for the gear set. So yes, buying a used diff for nearly 1000 is worth it considering you can sell your old one and make something back.
24 LT1 M6 Sharkskin Metallic
havelegs is offline   Reply With Quote
Old 04-23-2018, 11:31 AM   #8
hazy
Drives: 2011 2SS/RS
Can you still buy the 1le diff from factory? I was thinking about doing this, and just did some quick looking. Shows as "unavailable" on just about every parts website. I know the gear set can be bought, but if you can buy the whole chunk, its a relatively straightforward diy swap, as opposed to having a shop install gears in an existing diff
hazy is offline   Reply With Quote
Old 04-23-2018, 11:45 AM   #9
rich2342
rich2342's Avatar
Drives: 2010 CGM Camaro SS
Interested in 1 LE as well.
Aside from that. What else is required for the upgrade any ancillaries? Just the diff/final gear?
rich2342 is offline   Reply With Quote
Old 04-23-2018, 12:50 PM   #10
krisprz2010camaross
krisprz2010camaross's Avatar
Drives: 2010 Camaro 2ss/Rs Transformers
Just 3.91 comment
Isn’t the diff in the SS the same as the 1le if you just switch out the gears it’s exactly like the 1le, right? I read that somewhere. Not sure if it’s true, but I love the 3.91s in my car. Worth it!
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage
LS3 conversion
Vararam intake(tune model)
Kooks LT headers & cats delete
Corsa ZL1 3" exhaust
RedBarn Racing Tune
CMS Stage 3 Cam
AFR CNC ported heads
MSD Spark plug wires
LNC-2000 Launch controller
NGK TR6 Spark Plugs
1le strut tower brace-TPIS spacers
Nick Williams 102mm throttle body
Fast lsxr 102 intake manifold
Slp 25% UDP
Katech Tensioner Pulley
Circle D 3600-3700 multi disk Stall
GM 3.91 gears
DDS carbon fiber driveshaft
ZL1 fuel pump & injectors
Flex fuel sensor(91/E85)
https://wheelwell.com/kris-perez
krisprz2010camaross is offline   Reply With Quote
Old 04-23-2018, 04:56 PM   #11
LCPLPunk
USA-1
LCPLPunk's Avatar
Yep, diffs are the same!
Old 04-23-2018, 07:30 PM   #12
Ashen 6.2
Ashen 6.2's Avatar
Here is the 3.91 diff part # 22806794. Based on my google search it shows to be discontinued.
Old 04-23-2018, 10:37 PM   #13
StingrayblueSS
StingrayblueSS's Avatar
Drives: 2013 Camaro SS
https://rover.ebay.com/rover/0/0/0?m...2F362289953734
When I searched ebay this came up
StingrayblueSS is offline   Reply With Quote
Old 04-24-2018, 11:26 AM   #14
havelegs
havelegs's Avatar
Drives: '23 LT1 A10
No they cannot be bought new.
