Vararam
Old 11-22-2015, 11:30 AM   #1
WIPLASH
WIPLASH
WIPLASH's Avatar
Drives: '15 SW/2SS/RS/1LE
Is your steering wheel like this?
I bought a 2015 2SS in April. Sold it and bought a 2015 1LE this month. Went with a buddy to buy a 2015 1LE for himself yesterday. All three steering wheels have the same thing in common:
They're not aligned. In other words, they all steer due straight when slightly turned to the right. Very slightly. If the steering wheel is centered true straight, lined up with the stalk base, it drifts slightly to the left. The cars don't pull and both mine were less than 15 miles when I bought them. Dealer said it was due to the way the cars are tied down on the delivery truck and it will correct itself. My 1st 2SS had 15k miles on it and never corrected itself. I've heard there is a steering wheel alignment to center the steering wheel to true. Is this right?
Forgive the verbosity, I just wanted to make sure the issue was clearly conveyed.
Thanks!
1" BMR | CAI | SW LTH | BTR Stage 3 camshaft | Stage 2 LSA Supercharger | LSX376 B8
624whp/562tq
WIPLASH is offline   Reply With Quote
Old 11-22-2015, 11:36 AM   #2
5thGenerationSS
Drives: TT '14 SS
i havent noticed it, but every time i get in my car im gonna be over analyzing lol.
All of it.
5thGenerationSS is offline   Reply With Quote
Old 11-22-2015, 11:45 AM   #3
fastlane2010
fastlane2010's Avatar
Drives: 2010 camaro with fast lane stage 2
It means you need an alignment because the sterling wheel only goes on one way
12.4 in 1/4 at 117mph first time
custom 2tone paint fastlane stage 2 hydroformed carbon fiber cowl and cluster kooks headers and 3" xpipe with pypes axle back
fastlane2010 is offline   Reply With Quote
Old 11-22-2015, 11:46 AM   #4
KR4545
KR4545's Avatar
Drives: 2012 2SS
Does the road they were test driven on have any pitch to it?
KR4545 is offline   Reply With Quote
Old 11-22-2015, 11:54 AM   #5
WIPLASH
WIPLASH
WIPLASH's Avatar
None of the 3 cars pull or seem out of alignment and the previous 15 2SS had no unusual tire degradation which would indicate an alignment issue. When letting go of the steering wheels while driving, they drive straight. It's only when you center the steering wheel (line up the flat area above the airbag with the stalk base) that it drifts to the left.
All 3 vehicles are new. All three have the issue on any road.
624whp/562tq
Old 11-22-2015, 11:56 AM   #6
1Coopgt
1Coopgt's Avatar
Drives: All Black 2012 1LS
Most roads in the US are crowned for water drainage . If the car pulled to the left because of the crown they would be driving on the wrong side of the road .
Op I would get your wheels re-aligned . Mine goes and is aimed straight .
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
1Coopgt is offline   Reply With Quote
Old 11-22-2015, 12:01 PM   #7
Scalded Dog
Scalded Dog's Avatar
Drives: 2011 1LT
Mine is centered, straight, and does not drift in either direction (except in the event of road crown, or course), and has been that way since I got it four years ago.
It sounds like the dealer is just trying to talk you out of performing warranty work on your car. A non- centered steering wheel would make me so nuts that I'd start ramming curbs just to see if I could accidentally fix it (okay, I'd just go get an alignment done--- which includes steering wheel centering).
The story about how they are transported being the cause of mis- centering sounds like a random story made up on the spot. It does not add up.
Scalded Dog is offline   Reply With Quote
Old 11-22-2015, 12:32 PM   #8
rozarioorlan
rozarioorlan's Avatar
Drives: 2013 Camaro 2LS
i have the same problem on my '13 LS. i got it used and for the first year had the 18" stock tires/rims with no problems. i upgraded to 20" rims and new tires and the steering wheel tilted towards the right, like everything you said! if you hold the wheel straight and drive it, it pulls to the left and if i just drive without touching the wheel it pulls to the right so it's just always crooked. had tons of alignments and everything checked out and still no fix
2013 2LS - K&N CAI, Overkill Ported 80mm Throttle Body, Overkill E85 Kit and Overkill Tune, Jacfab Ported Intake Manifold and Spacer, Stealth 3.0 TC, ARH Catted Downpipes, Magnaflow Resonated X-Pipe, Resonator Delete, Jones Full Boar Racing Mufflers, BMR 1.2" Lowering Springs, Elite Engineering Catch Can and Clean Side Seperator
rozarioorlan is offline   Reply With Quote
Old 11-22-2015, 01:16 PM   #9
paul84043
paul84043's Avatar
Drives: 2015 Camaro 2SS RS 1LE
My 2015 1LE wheel leans slightly to the right.
paul84043 is offline   Reply With Quote
Old 11-22-2015, 01:34 PM   #10
WIPLASH
WIPLASH
WIPLASH's Avatar
3 of the (only) ones I've driven do the same thing. I was hoping this was something that could be fixed with a steering wheel calibration or something. I'm an OCD guy, but even so, I try to keep my eyes on the road.
624whp/562tq
Old 11-22-2015, 01:34 PM   #11
Stecky
Drives: 0000
Make sure Ties pressure are the same also
Stecky is offline   Reply With Quote
Old 11-22-2015, 01:35 PM   #12
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
Typical!!!
Soprano 4/1/00-6/14/11, Gone but NEVER forgotten!
FSP tuned: 377/389
nyrfan is offline   Reply With Quote
Old 11-22-2015, 02:19 PM   #13
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
Drive on a flat parking lot and see if that slight misalignment is still there.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
Old 11-22-2015, 02:35 PM   #14
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
Mine veers a bit, but i know that i need an alignment lol, also could be because of the road being crowned a bit like 1Coopgt mentioned. Doesn't hurt to get your car aligned, helps your tire wear in the long run as well
Current: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower w/ Idler Relocation, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, Tuned by Pat G
Past: 2010 2SS, some bolt ons, 415rwhp/400rwtq
spadz93 is offline   Reply With Quote
