Roto-Fab
Old 12-10-2014, 11:51 PM   #1
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Arrow MY FSP Built AGP TT Camaro [COTW 4/20/15]
Current status of car, and summary of build.
Update As of January 4th, 2017
I have made arrangements to have the car taken to Hutter Performance, which is also Hutter Racing Engines. For engine R&R, and tuning. As soon as they can get me in, the car will be transported to them. Looks like 6 weeks from now.
October 2016
Current status
Car is home, and parked in the garage, trying to finish some of the things FSP missed, or never did. It has low oil pressure when at operating temperature. So the car will likely stay grounded until the spring. When I can get it to someone else who can fix the engine and tune the car.
Summary of Current mods.
Engine mods are as follows
CP pistons
Callies compstar rods
ACI coated race bearings
Durabond cam bearings
arp head studs
arp cam bolts
arp balancer bolt
arp main studs
GM High pressure oil pump with Melling spring
ls2 damper
c5r timing chain
comp cams trunion upgrade
new front and rear cover seals
new oil pan gasket
new valve seals
ls9 head gaskets
cadillac racing lifters
ID850's
25% SLP Under drive pulley
AGP Twin turbo kit
54/57 Turbos
Large race Intercooler
Livernois Dual fuel pump system
ECS BAP
Alky Control dual nozzle meth system
FSP custom grind cam
Car mods
AEM Tru Boost Controller
AEM AFR gauge
AEM Fuel Pressure Gauge
LNC-2000 Two Step
JDP clutch reservoir kit
SJM Line Lock
Autometer A Pillar pod
AreoForce dash vent gauge pod
MSD Raptor shift light
3" inch Magnaflow Catback Exhaust with X pipe
Mantic Twin 9000 Clutch
DSS 1000hp axles
DSS aluminum one piece drive shaft
ZL1 Rear end with 3.23 gears
BMR Trailing Arms,
Rear, Polyurethane Bushings
BMR Toe Rods,
HE solid sub frame bushings
HE rear differential offset bushings
R1-Premiere Cross drilled and slotted rotors
Hawk HPS Pads
Exterior mods.
CEC c884 aluminum forged 20X10 inch wheels for the front and 20X11 inch wheels for the rear sitting on Goodyear Eagle F1 tires on the front and Mickey Thompson DR's on the rear.
New billet aluminum grill, top and bottom piece
Smoke colored headlight covers
Smoke colored tail light covers
Smoke colored fog light covers
Future mods, once I get the car home.
BMR one inch lowering springs
New Mickey Thompson DR's
Things I will do once my cash flow permits:
Fore or AGP triple pump fuel supply
Milled heads to raise compression a little
New clutch want to go to a triple disk
Two 17 inch wheels for the track
AGP MPH switch (for upping the boost after a certain mph)
Flex fuel meth fail safe system
RPM Roll Bar with removable swing out door bars
Here is a compilation of all my idle clips.
Here is a couple videos of some WOT pulls.
Two step videos, day and night.
Here is Matt from FSP breaking in the engine and clutch on the dyno, followed by a couple runs, ending with the car spinning the tires.
My complete build thread starts here.
I have never had my very own super duper kung foo killer muscle car to do with as I see fit, for financial or other reasons...family and spouse were always totally against it. Until now......
Week of July 4th 2012--Made the decision to get a car I knew I could have fun with and afford. Had to have been a Chevy, my first car was a Camaro, after that I was a chevy man for life.....Went to the dealership and told them I wanted a M6 LS3, those were my only requirements.
Car was bought with 48 miles on it...which was really cool because I am a Jimmy Johnson fan!
So one day I was doing some research on the internet, and one of my searches led me to C5, I had also remembered my car salesperson tell me that you guys were all a bunch of nuts and had all kinds of cool things you could do to the cars....Now I am a C5 junkie and am constantly reading, gathering information, and formulating evil master plans!
I was real big into SC for my future build. So I started investing in parts that I could consider supporting mods. And also in some parts that I just wanted anyway for fun.
Hawk HPS Pads
Bought Kooks Stepped LT's
Cat-less mid-pipes
Borla S-Type Axle back mufflers
VMAX Ported Throttle Body
Cold Air Inductions. Inc CAI
ADM race scoop and washer bottle relocation kit
Innovate MTXL-1 AFR guage
Vitesse Throttle controller
Had Matt from FSP remote tune the car on the street first then a Mustang dyno. 420WHP/401WTQ
Here is a sound clip of the car with the Kooks Stepped headers, no cats and Borla Axleback Exhaust, I will really miss this once I re install my factory manifolds.
So The time had come for me to pick a FI system, it was either SC or Turbo's. To make a long story short A lot of people have Superchargers on their Camaros, but not so many have turbos. That and after doing a ton of research, the AGP kit met my HP goals within the price I was wanting to work with.
So here it is! the RWHP goal is 750ish..
Pics and videos will start coming soon!
December 10th 2014 Took the Car to Matt @ FSP for the following work.
AGP Twin turbo kit
54/57 Turbos
AGP CAI kit
Intercooler
ID850's
MSD shift light
DSS 1400hp axles
DSS 1 piece Aluminum Drive Shaft
Lakewood Sub-frame connectors
BMR Trailing Arms,
BMR Toe Rods,
Here is a before and after photograph of the car, along with the dyno sheets. Don't mind the dent in the drivers side quarter panel, it was fixed months ago.
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 12-13-2014, 10:41 PM   #2
KriticalFlaco
Drives: 2011 Camaro SS
should be a beast no doubt when "santa" is done with it....
KriticalFlaco is offline   Reply With Quote
Old 12-14-2014, 02:24 AM   #3
i2disturbedSS
i2disturbedSS's Avatar
Drives: 2010 SS L99 IOM
Nice, good things do happen - Keep the Dream Alive!
369rwhp/392rwtq
"Spending money I don't have, to buy parts I don't need, to impress people I don't know!" -Jenkins
i2disturbedSS is offline   Reply With Quote
Old 12-14-2014, 06:20 AM   #4
miller8907
miller8907's Avatar
Drives: 2014 1SS/RS LS3
Nice build. I have twins in my dreams but it will be a while. Looking forward to seeing what you get out of them.
2014 1SS/RS LS3 AGP TT, Custom TSP Cam, 4L80E Swap 1/4 mile- 9.53 @ 145mph
miller8907 is offline   Reply With Quote
Old 12-14-2014, 07:21 PM   #5
1KillerSS
1KillerSS's Avatar
The wait is killing me!
Build thread
Old 12-16-2014, 06:55 AM   #6
fyibaiers
Drives: Camaro
fyibaiers is offline   Reply With Quote
Old 01-06-2015, 05:32 PM   #7
1KillerSS
1KillerSS's Avatar
The boys at FSP been rockin it!
yesterday they took out the axles, Drive shaft and transmission along with tearing the valve covers off for the new dual valve springs.
Today the car was all tore down ready for the rest of the build, they finished the dual valve springs but tomorrow starts the rest!. Here are the pictures of the day.
Build thread
Old 01-08-2015, 01:08 PM   #8
1KillerSS
1KillerSS's Avatar
So yesterday when they were putting the cam, one of the lifters dropped so they just pulled the engine. The transmission was already off of the car and the motor was just sitting there on a few motor mounts.
So cam is in, valve springs are done motor is finished and Livernois dual Fuel pumps will be done by the end of the day. Not sure when they will put the engine back or what else they will finish or get started onto today, but its only 2pm and as we all can see there moving fast. Here are the pictures of today, more updates later!
Build thread
Old 01-08-2015, 07:44 PM   #9
Jared91
Jared91's Avatar
Drives: 2011 Camaro SS/M6
And the anticipation builds !!! Going to be one sweet car when it's finished up. Good luck falling to sleep at night in the mean time haha.
2011 Ls3. Slp TSV2300. 8PSI. 3.4 Pulley. Livernois Twin Fuel Pump. Id850 Injectors. Slp 1 3/4 headers. CAI Cold Air Intake. 3inch exhaust. V-Maxx portted throttle body. Night Fury cam. Lpe 391 gears. Fj performence tune. 643rwhp 574rwtq
Jared91 is offline   Reply With Quote
Old 01-08-2015, 08:22 PM   #10
1KillerSS
1KillerSS's Avatar
Mantic 9000 Clutch is installed!
Livernois Fuel system installed!
Fuel tank and transmission will be back in the car tomorrow, first thing in the morning.
Build thread
Old 01-10-2015, 07:50 AM   #11
1KillerSS
1KillerSS's Avatar
So here we are at the end of the week, motor and accessories are back in the car, along with transmission. The Alky Control will be installed by Monday, the AGP kit was shipped earlier this week so it will be here shortly....
FSP really moved fast on this build. I dropped the car off to them on the 10th of December, They didn't start on it until the 4th of Jan. They had other projects in the shop they were working on and plus the shop shut down from the 24th of December to the 4th of Jan. So considering they ended up pulling the motor and transmission, and as you can see by the pics they went through everything, they hauled ass! I couldn't be happier with my choice. In less than a week they did all the work described above.
Build thread
Old 01-12-2015, 05:56 PM   #12
1KillerSS
1KillerSS's Avatar
Well today was Alky control. As you can see by the picts they rocked it out.
So were waiting on the turbo kit from AGP, it will arrive Wednesday, which is a real bummer for FSP. I had bought a plane ticket and hotel reservations in December for the 15th of Jan. That was based on me and Matts discussion. We both felt it was plenty of time. Not much he can do when parts are not in his hands. Yet Matt is assuring me that hell have the car ready by the end of the week. I hate to put them under the gun, the cost of the tickets is nothing compared to the cost of the build. So we will just see how it goes. I want the guys to have fun and enjoy the build, not want to kick it out of the shop.
Build thread
Old 01-12-2015, 10:05 PM   #13
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Drives: 2012 SS/RS LS3
FSP FTW....you will be very happy once you get it back.
CHMSC is offline   Reply With Quote
Old 01-14-2015, 12:05 PM   #14
1KillerSS
1KillerSS's Avatar
Ok well the car will not be picked up this week, I discussed with Matt, the possibility of me picking up the car on Friday and keeping my travel plans in order, as we originally decided on, and he and I both think that we are just asking for trouble. We are both on the same page, I know, and he knows, they could have the kit installed and finished for me Friday night, however this leaves no room for error or anything else that will most likely come up according to murphys law. I have had over ten years in this business and I know what happens when you try to rush things out the door, add onto that what happens when the employees start to hate the project. Its just not worth it. I can always buy another plane ticket. Better to do that than regret it later.
As I stated before I want the shop to have fun with my build, and keep a great attitude towards the job. Not for them to stress out and want to kick the car to the curb when its done. Then only to find out after it goes that its got a few bugs in it and needs to come back. After all as Matt said, "its not like I live an hour away", I no longer live in his backyard I now am a snow bird living in Ohio, and when I pick up the car, that's where I'll be driving too. I want to send a big THANK YOU! to all the guys at FSP! and also to Matt personally for being a stand up guy and a consummate professional!
Build thread
