11-22-2015, 05:20 PM | #29 |
Drives: Love the one you're with Join Date: Sep 2009
I stopped worring about it a long time ago. I've had many cars and trucks with the same thing. I've always been told it's because of our lousy Pa roads.
11-22-2015, 08:30 PM | #30 |
Drives: 2014 2SS/RS Join Date: Dec 2014
In the past I observed that standard procedure when alignment is done is to center the steering wheel then adjust tie-rods so wheels are pointed straight. At alignment shops there use to be a gadget that attached to the steering wheel with an adjustable cushioned bar that ran back to the seat to lock the steering wheel once it was exactly centered ... then wheel alignment process continued.
During Camarofest took a tour of the Corvette factory and watched them align the wheels prior to rolling off the end of the assembly line. Process was done in what seemed like 2 minutes per car. There was different color indicators showing on the screen and an allowable "normal" +/- range for each spec. If they didn't put the steering wheel in the exact center during this step I can see how the off-center condition would occur. It won't affect tire wear but sure would be annoying to me. I use to remind alignment shops to "center and lock" the steering wheel before adjusting toe-in and toe-out on my vehicle because I was so picky about it being in exact middle ... and did return once because it was off very slightly. Ron |
11-22-2015, 08:54 PM | #31 |
Consistently inconsistent
Drives: 2015 2LT Summit White Join Date: May 2015
There is no factory spec for centering a steering wheel- the spec is "centered."
The pain in the arse is you have to adjust both tie rod ends to deal with it- but it's easy to do. The "acceptable" range during an alignment is, in my opinion, too wide. I've found if you buy the alignment guy a turkey provolone sammich and a cup of coffee he will take whatever amount of time to dial it in absolutely perfect and not just 'within specs.'
Thanks to MRR, I have some SWEET wheels! Thank you!
2015 2LT Ported TB, Ported intake, JACFAB intake spacer, Borla exhaust, IPF 91 tune, Complete 1/LE suspension, Brembo brakes, Goodridge lines, Elite catch can, CAI with Thermo-wrap, 275/40-20 x 10's all around, Z/28 spoiler, GM splitter, Alpine/Polk stereo with AudiControl interface. |
11-22-2015, 09:00 PM | #32 |
Drives: 2014 2SS/RS Join Date: Jun 2013
Your wheel could be upside down and the wheels could be aligned properly.
The tool that is used to hold the steering wheel straight doesnt seem to work well with the camaro steering wheel... I have the same thing OP. Your alignment is fine, just next time you get it done, ask if you can get in the car and turn the wheel straight after they calibrate on the rack |
11-22-2015, 10:49 PM | #33 | |
WIPLASH
Drives: '15 SW/2SS/RS/1LE Join Date: Apr 2015
Thanks for your response!
1" BMR | CAI | SW LTH | BTR Stage 3 camshaft | Stage 2 LSA Supercharger | LSX376 B8
624whp/562tq |
11-23-2015, 08:06 AM | #34 | |
Drives: 2010 Camaro 1LS 3.6 LLT V6 325 HP Join Date: May 2009
2010 Camaro Auto, Inferno Orange, Titanium Interior, Gearhead Wheels AIRAID CAI
11-23-2015, 08:20 AM | #35 |
Drives: '15 Camaro 1LS/M6 Join Date: Oct 2015
Must be a "1LE" thing. On mine, the steering wheel is perfectly straight.
11-23-2015, 08:27 AM | #36 |
Drives: 2013 Camaro 2SS RDP Tuned L99 Join Date: Apr 2013
Mine has the same thing ever so slight to the right a degree or two perhaps... Never posed a problem either.
11-23-2015, 09:31 AM | #37 |
Drives: '23 LT1 A10 Join Date: Oct 2015
No but what really bothers me is that "chrome" trim around the airbag area and it shines right back in my eyes. I want to rip it off.
11-23-2015, 09:58 AM | #38 |
Drives: 2014 2SS/RS Convertible Join Date: Jun 2013
It always amazes me to hear the utterly ridiculous things dealers say. Do they have conventions where they learn this stuff? Maybe compulsive liars are drawn to working at car dealerships for some reason.
11-23-2015, 10:33 AM | #39 | |
corner barstool sitter
Installing wider wheels and stiffer tires will then force some of the previous tire distortion to show up at the steering wheel, adding to the steering wheel error that was already there. On edit, if your rear "axle's" thrust angle is off, an uncentered steering wheel when driving straight ahead on a level road is exactly what results. In the case of IRS, this would mean that either or both rear toe settings was incorrect as well as being inconsistent with the other side's toe. Norm
11-23-2015, 09:19 PM | #40 |
11-23-2015, 09:20 PM | #41 | |
An alignment shop is more likely to overlook the exact straightness of the steering wheel during alignment than they are to have car's thrust angle be off. Technicians are constantly looking at the computer that displays all the angles, including the thrust angle, but they only move the steering wheel to the center one time. |
11-23-2015, 10:17 PM | #42 | |
Drives: '10 Inferno Orange SS Join Date: Feb 2015
OK, jeez, I haven't gone through the couple pages of this post so I may be repeating, but the ROADways are humped. If you could drive your car on an airport runway, dead center, I would bet your steering wheel would be dead center. I'm not trying to mock the question, but it seems to me that folks on this forum ask questions that at least to me, are common sense. Are we as a car culture, gone to the darkest depths of having to ask "If I drive my SS in the rain on tires with 45K miles, will I skid" (mocking some absolutely mundane questions)..... See my point? Nobody call these folks out. I think it's simple. Nothing wrong with the alignment of three cars. What are the roads your driving on? Humped, 1 lane? Or a 4 lane? I would bet the offset of the steering wheel changes with the amount of lanes, i.e. the curvature of the road you are on. Done now. -Tony |
