BeckyD @ James Martin Chevy
Old 09-18-2018, 11:33 AM   #1
WCKD 1LE
WCKD 1LE's Avatar
Drives: 2018 SS 1LE
2019 1LE
So you can now build and order your 2019 1LE on the Chevy homepage.
They also are offering the ZL1 1LE Carbon wing as a part you can add to the build this year which I think would have been a much nicer option for LAST YEAR!
Also, I'm very curious to see if the 19's hood is a direct swap, it looks super close from all the angles I can see in pictures. I'm very fond of the 19 hood going back to the Z28 style. I trade in might be in the cards here soon
WCKD 1LE is offline   Reply With Quote
Old 09-18-2018, 11:50 AM   #2
R3ctivision
1LE Convert
R3ctivision's Avatar
Drives: 2018 ZLE
Interesting! You can configure the wing but not the front fascia, splitter, and canards? That could make for an understeery car.
Also wonder if the wing brings the reinforced trunk as well.
R3ctivision is offline   Reply With Quote
Old 09-18-2018, 11:53 AM   #3
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
yea i just tried to build one for fun and saw the same thing also lol im stil salty you can add recaro seats to a 1ss and not have to get a 1le and its only like $1600 or something
Old 09-18-2018, 01:17 PM   #4
camaroJD
Drives: 2019 Satin Steel 1SS 1LE w/ PDR
I'm not sure if any of that is actually true until someone successfully orders one. There are still a bunch of little bugs in the build and order page.
camaroJD is offline   Reply With Quote
Old 09-18-2018, 02:00 PM   #5
KCelsius
KCelsius's Avatar
Drives: 2018 Summit White 1SS 1LE
I would think it would fit, the only thing I'd be concerned with is if the body lines on the hood line up with the ones on the front fascia. From memory I think there's only the one body line down the middle on the front clip and there aren't ones for the 2 body lines beside it.
KCelsius is offline   Reply With Quote
Old 09-18-2018, 02:14 PM   #6
WCKD 1LE
WCKD 1LE's Avatar
Drives: 2018 SS 1LE
But, you know it would looook so good!!!
Old 09-18-2018, 02:17 PM   #7
Laststandard
Drives: 2018 1SS 1LE
I like the new front splitter. Went a bit more aggressive with it.
The '19 looks good in black.. lets those stupid cheek pods blend in.
2018 1SS 1LE (sold)
Laststandard is offline   Reply With Quote
Old 09-18-2018, 06:40 PM   #8
max pl
Drives: BMW M3
edit
max pl is offline   Reply With Quote
Old 09-18-2018, 08:17 PM   #9
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
You could order Recaros on a '18 without the 1LE.
I looked at three of them, one 2SS and two 1SS's.
'18 1SS 1LE Black, PDR
Old 09-19-2018, 12:25 AM   #10
Cgocifer
Cgocifer's Avatar
Drives: 2018 1SS 1LE, 2015 RAM Ecodiesel
Configurator wont allow SS 1LE with crush. Hmmm
Shadow grey looks good too.
Cgocifer is offline   Reply With Quote
Old 09-19-2018, 08:45 AM   #11
GearheadSS
GearheadSS's Avatar
Drives: 23 LT1/22 Colorado TB/69 Chevelle
It's just an error in the system right now. Even my order screen says Crush isn't available with 1LE on SS but I can change it manually once the order has been submitted with a different color.
As for the ZL1 1LE wing, it's a $5,495 option and so far, only available on 1SS for some reason. It also requires either VTD ground effects($2250), 5VM ground effects($2250) or RZ3 front fascia extension($610). So the spoiler will cost a minimum of $6,105.
It's also not available to order with A1Y 1LE because of the required ground effects or front splitter.
GearheadSS is offline   Reply With Quote
Old 09-19-2018, 09:07 AM   #12
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
I was just able to configure a SS 1LE in Crush....Maybe they fixed it.
nancygrl is offline   Reply With Quote
Old 09-19-2018, 09:28 AM   #13
Bad@ssCamaro
BeckyD Rocks :-)
Bad@ssCamaro's Avatar
Drives: 2015 1SS/1LE
I just tried it and it wanted to remove the Crush when adding the 1LE package.
2015 CRT 1SS/1LE RS/Recaro's/NPP/Nav/Rear vision pkg./BA speaker upgrade. Stage 3 BMR cam, ARH 1 7/8 headers, CAI,
BMR 1.25 drop springs, JPSS Billet Bushings, Peddars Cradle Bushings...460 whp...so far....SOLD, but not forgotten!
Bad@ssCamaro is offline   Reply With Quote
Old 09-19-2018, 02:31 PM   #14
GTSLOW
Daily Driven 1LE
GTSLOW's Avatar
Sheesh, how many 100mph turns are you planning on taking?
2018 1SS 1LE
GTSLOW is offline   Reply With Quote
