Old 05-10-2018, 01:52 PM   #57
1erMQP
1erMQP's Avatar
Drives: 15 Z/28 #605
Stickers plotted
Want to show you the outcome of today (bank holiday in Germany).
Plotted some stickers for the doors and the front fenders.
I'm in love with the new style
1erMQP is offline   Reply With Quote
Old 05-11-2018, 02:47 PM   #58
1erMQP
1erMQP's Avatar
Took a snapshot on my todays after-work tour
Old 05-11-2018, 04:28 PM   #59
Z Beast
Z Beast's Avatar
Drives: 2014 Z/28 Ashen Grey Metallic
Looks great.
"The walls are white, the track is grey, the grass is green, and the sky is blue... your job is to keep them all where they belong." - Johnny Rutherford
Z Beast is offline   Reply With Quote
Old 05-13-2018, 11:12 AM   #60
1erMQP
1erMQP's Avatar
Found today a new tool for editing pictures on the smartphone.
PhotoShop-Express, love the results
Old 05-13-2018, 06:12 PM   #61
JUSTIFIED
JUSTIFIED's Avatar
Drives: 2015 black Z/28
JUSTIFIED is offline   Reply With Quote
Old 06-04-2018, 08:41 AM   #62
1erMQP
1erMQP's Avatar
Shooting Quick & Dirty
Had yesterday a ride with a friend who's a shutterbug.
We were looking for a good location for the next shooting.
As it happens he's got his camera with him.
Usually he's working with light and flashes.
Like this quick & dirty pics
Can't await when he's doing the real good ones...
Old 06-04-2018, 09:53 AM   #63
craZed
craZed's Avatar
Drives: Z/28 15 AGM
Pretty good for quick & dirty. Congrats to both of you.
craZed is offline   Reply With Quote
Old 09-05-2018, 01:39 AM   #64
1erMQP
1erMQP's Avatar
Camaro sticker
Something was missing on the front Fender.
So I've created a "modernized" Camaro sticker.
Hope you like the new style
Old 09-05-2018, 01:46 AM   #65
Jberg805
Drives: N/A
Originally Posted by 1erMQP View Post
My first aproach to divide the combined brake-turn-signal with the CURT module was unfortunately not targeting
The module is unable for a correct hazard flasher.
The logic behind the module is:
- signal on one side -> turn signal
- signal on both sides -> brake signal
So the hazard flasher is resulting in flashing brake lights.
Unfortunately I've found the info about this behaviour too late on the
CURT FAQ's and on the German Camaro forum.
So it was time for a rework of the board...
Knew I had seen this somewhere.. I am going for a swedish made splitterbox wired to RS LED european tail lights. Was hoping not to route cables from the front turn signals.
Also going for a OEM light switch with foglight buttons to start the rear foglight.
Jberg805 is offline   Reply With Quote
Old 09-05-2018, 01:51 AM   #66
Jberg805
Drives: N/A
Ehere did You steal ignition power for the rear foglight?
Old 09-05-2018, 02:52 AM   #67
1erMQP
1erMQP's Avatar
I'm working with the adapter board in the trunk.
The fog lights are fired by a relay supplied direct by the battery (terminal 30)
Relay is activated by my switch solution.
Power for the the switch is coming from the lights.
So foglights only working with lights on.
This is required for homologation in Germany.
All voltage carrying wiring is secured by fuses.
Old 09-05-2018, 03:47 AM   #68
Jberg805
Drives: N/A
My lightswitch will not come until later this fall, I am putting a temporary foglight switch where the 12v power outlet is in front of the shifter. Should be enough if the foglight is powered by the cars ignition, in Sweden You are not allowed to drive without lights on during any time of the day, stealing the power temporarily from the power outlet wich is controlled by the ignition, will put a new fusebox in the trunk for powered cables.
Hopefully they will approve this solution and I can use this winter to make a permanent solution with OEM looks.
I bought a prewired relay wich was not wired correctly from factory, I just got everything to work out fine. Thanks!
Old 09-05-2018, 03:14 PM   #69
Jberg805
Drives: N/A
Got everything sorted out today, a couple of bolts left to mount for tomorrow night and I am ready to pass the swedish road legal tests.. if I’m lucky they’ll squeeze me in on friday, keep Your fingers crossed! 😁
Old 09-18-2018, 12:34 PM   #70
Bad@ssCamaro
BeckyD Rocks :-)
Bad@ssCamaro's Avatar
Drives: 2015 1SS/1LE
Here is the correct font for "CAMARO"
https://www.dafont.com/trireme.font?text=CAMARO
2015 CRT 1SS/1LE RS/Recaro's/NPP/Nav/Rear vision pkg./BA speaker upgrade. Stage 3 BMR cam, ARH 1 7/8 headers, CAI,
BMR 1.25 drop springs, JPSS Billet Bushings, Peddars Cradle Bushings...460 whp...so far....SOLD, but not forgotten!
Bad@ssCamaro is offline   Reply With Quote
