08-23-2019, 09:14 PM | #1 |
Drives: 2018 Camaro 2SS Join Date: Jul 2019
Fuse 51 and AFM
So I pulled the F51 trick on my A8 the other day and have to say that the car sounded like crap in 4 cylinder mode. I assume that this is because of the AFM valves further up in the exhaust system.
Are folks disabling AFM in the tune when doing the F51 pull? If so, is there any point in getting a new exhaust, even an axleback, until after the powertrain warranty expires? All of the videos for aftermarket exhaust systems are either on M6s or at WOT on the A8s. There are no vids that I've seen sampling these systems in 4 cylinder cruise mode, probably because they sound like garbage. Right now I'm thinking that I wait until it expires and then get the full catback and tune out the AFM. If anyone has any experience with modified tunes and warranty issues, let me know. Full disclosure: I'm one of those people who value the warranty and don't want to give the dealership any excuses. Thanks all!
2018 2SS - Unmodified
08-23-2019, 11:25 PM | #2 |
Drives: 2019 Camaro 2SS A10 Join Date: Feb 2019
2019 2SS: A10, Satin Steel Gray Metallic, MRC, Nav.
08-23-2019, 11:26 PM | #3 |
Drives: 2016 2SS Convertible Join Date: May 2012
You could buy a Range AFM device. It plugs into the OBD port and keeps the engine in V8 mode without making any permanent changes to the ECU. Unplug it and the engine returns to normal AFM V4/V8 operation.
08-24-2019, 09:59 AM | #4 | ||
08-26-2019, 07:40 PM | #5 |
Drives: 2018 2SS Convertible MBM/Kal Join Date: Feb 2018
Had my Range (Firmware 8.6) in for over a year now and over 11,000 miles.
Works perfectly. No problems, no CELS, etc. I even left in plugged in (by accident) while on vacation for almost 3 weeks. Car sat the whole time. Started up just fine. That was about 3 months ago. Still no issues. I pull it when I take the car in for service. Put it back when I pick it up. Really makes a huge difference.
2018 2SS Vert. MBM/Kalahari. MRR FS01’s with 285/305 MPS4S. Black Bow ties, A8, MRC, NPP, 6-piston Brembo’s w/ matching rears, OEM Ground Effects/Splash Guards, 8”/Nav. Borla S-type, Pray IM/TB, RotoFab.
Past DD’s of note: 2013 Caprice PPV. (“Company” car.) 1998 Cadillac STS 1996 Impala SS 1969 Cadillac DeVille Convertible 1993 Corvette 1991 Mustang 5.0 LX 1973 Alfa Romeo Spider 1986 Mustang GT T-top 1964 Falcon Sprint Hardtop. (First car, still have the key!) |
08-27-2019, 05:26 PM | #6 |
Drives: 2016 Camaro 2SS Join Date: Mar 2018
Absolutely, if you like the exhaust sound with the dampers open all the time in V8 mode, get the Range, in V4 mode it sucks. I did for almost a year before I went full bolt on exhaust and tune. I do almost all non-highway driving and only lost about 1 MPG. V4 mode is more valuable to guys that do a lot of highway driving.
Mr Russ
Tim "the tool man" Taylor is my hero My Garage: '16 Chevrolet Camaro 2SS, Summit White, Adrenaline Red -- Rotofab CAI, Soler TB, 1 7/8 coated LT's, Full 3" mids, 3" Stainless Works NPP mufflers, Flex Fuel, E85/91 tuned '20 Honda Oddysey Elite 25th Anniversary Edition --wifes car, she said "No more SUV's" after the 2 CX-9's totaled |
08-27-2019, 08:58 PM | #7 | |
Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
NPP, MRC, Tinted side & rear reflectors, OEM ZL1 Rockers / 3rd Brake / Darken tail lights, OEM Blk rear splash guards, Satin hood wrap, Fuse pull, Sound tube delete, Cat delete, Ported 95 TB, Ported MSD IM, Dry RotoFab, ARH 1 7/8 headers, E85, "Performance Dyno" Tune, BMR "pieces", "Track" alignment, Hawk DCT-70/70's w/SRF, Goodridge lines, Ti shims, Red powdered calipers, 18" APEX SM-10's w/ Pirelli DH's, FE4 Vert swaybars, Brake cooling ducts, ATI 10% UD, Vorshlag camber plates, OEM 1LE Splitter w/APR Ext., Velossa BIG MOUTH Ram Air, CF QA1, ZLE brakes(F)
08-28-2019, 09:44 AM | #8 |
Drives: Camaro 50th anniversary edition Join Date: May 2017
+1
I have pulled my 51 and use AFM Range as well. No problems at all. No farting when going from V4 to V8 anymore.
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
09-02-2019, 02:07 PM | #9 |
INTSAGRAM: Failwish
Drives: 2019 /2SS LT1 Join Date: Jun 2015
Can fuse 51pull trick work on 2019 ss?
2019/LT1 2SS
09-02-2019, 07:46 PM | #10 |
Drives: 2017 1SS Hyper Blue Join Date: Apr 2017
Another thumbs up for Range AFM delete. Sounds tons better, you'll even get some more crackling when you let off.
Only bummer (and it's a small one), is that you'll see more soot in your outer tail pipes, unless you have a lead foot always. |
09-02-2019, 11:59 PM | #11 |
afm, exhaust, fuse 51, warranty |
