08-03-2023, 11:02 PM | #1 |
Anthony S
Please delete
Looks like I found one from one of our members, The forum prevails again!
https://www.camaro5.com/forums/showthread.php?t=600181 Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links. Last edited by The_bald_eagle_machine; 01-09-2024 at 07:30 AM. |
08-04-2023, 01:44 PM | #2 |
Drives: 2010 2SS RS Join Date: Mar 2017
PM’d you sir.
Procharged, cornfed, zl1 pump with some DSX assist, Pedders sway bars & end links, BMR suspension stuff out back, BTR cam, id 1050’s, DSS aluminum shaft, lth screwed to some borla chimney things, MGW short throw, RXT twin and a bunch of stuff I’m probably forgetting all tuned by the gpi boys.
08-04-2023, 02:22 PM | #3 |
Anthony S
To show my clearances.
12-03-2023, 09:18 PM | #4 |
Anthony S
Update, I have decided that I do want to purchase one of these. Now i can't seem to find them for sale anywhere!
12-04-2023, 06:04 AM | #5 |
@ max.i.s.cool
Drives: 2015 1/LE Join Date: Dec 2016
Kyler Freitas or @t13d.irocz on Instagram, was able to fit that intake tube. Only difference I see if that he has a 2010 so his strut towers are a little different.
12-18-2023, 11:05 AM | #6 |
Anthony S
Still looking... Getting lots of bot messages.
