03-20-2024, 11:41 AM | #1 |
Drives: Camaro 2016 RS Join Date: May 2021
Leak
Hello,
I noticed that on the right side of the engine cover, there's a stain. Upon touching it it seems somewhat oily, but I'm not sure. Relatively, everything looks dry, but I touched those two hoses that I marked in the photo, and they are "wet". Is anyone able to roughly locate the issue? I had the coolant replaced at the service center two months ago, but I'm not sure if it could be related to that. Best regards. |
03-20-2024, 12:26 PM | #2 |
when you touched it you then looked at your hand...what color was the fluid?
03-20-2024, 01:48 PM | #3 |
Electrical Engineer
Drives: 2023 1SS A10 Black Join Date: Apr 2022
I would clean up everything, document the color, smell, taste (jk), etc. Paper towels are handy for seeing color.
Then monitor. There is a mess down there and it's hard to tell where it's coming from. Now that you can look daily or after every drive.
2023 1SS A10 Black NPP/C2U/H72 - Daily Driver
Historically an Accord and Camry owner with self-performed maintenance/repair. 1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 22k mi. @ April 2024 New Engine @ 22,600 Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
03-20-2024, 04:35 PM | #4 |
03-20-2024, 05:22 PM | #5 |
Drives: 2022 Camaro LT1 A10 Join Date: Nov 2015
Those crimped pipes end up leaking sometimes. They probably need to be replaced.
2022 Camaro LT1 A10 - Drag Pack/AxleBack -11.849@118.67MPH/1.798 60' 2001 Camaro SS A4 - HCI/Stall/Bolt-on/Gear/Tune/DR/Diet - 429HP/392TQ - 10.99@123.58MPH/1.584 60' 1998 Camaro Z28 A4 - Bolt-on 1999 Camaro Z28 A4 - Stock FJB |
03-20-2024, 10:00 PM | #6 |
Waiting 4 A Point By!
Drives: 2020 ZLE, C8 Z06-Z07 2LT Carbon Join Date: Mar 2023
I recently had the fitting at the transmission Aux cooler leaking and replaced the o-ring. It was letting a little bit of oil to stream exactly where you are indicating.
03-21-2024, 10:06 AM | #7 |
Those do look like lines to the radiator for transmission fluid cooling.
I would try to figure out which one is leaking, as I doubt both are. Maybe wrap them both in white paper towels held by zip ties. See how long they take to saturate, and maybe you'll get an idea if one or both are leaking, not to mention how MUCH they are leaking. |
