11-09-2014, 04:20 PM | #1 |
Drives: '14 1LE Join Date: Nov 2013
Z/28 Underbody Panel (Belly Pan) - New Design???
Does your belly pan look like this?
This picture from SEMA shows 4 vents/openings (see red arrow) near the back of the pan - these vents are not present in the other versions of the 2014-2015 belly pan that I've seen (and the one I own). I'm trying to decide if I want to cut out these openings in mine (could make oil changes much easier). Thanks for your help |
11-09-2014, 04:45 PM | #2 |
Jumanji
Drives: '14 Z/28 - AGM - No A/C Join Date: Mar 2014
All 4 are open in mine, 2014 #181. Though the design would allow for easy oil changes, I took mine off to prevent residual oil build up, the belly pan is in the way of the oil flow when the drains are pulled.
11-15-2014, 09:07 AM | #3 |
11-15-2014, 12:51 PM | #4 |
Drives: 2017 Jeep Rubicon, 2016 Z06 Join Date: Jun 2012
#176 is open
2014 Z/28 Black VIN #176
11-15-2014, 06:48 PM | #5 |
I tried to order the Z/28 pan (# 23459995)back in late September, I was told it was on hold. My parts guy is good to me, and he kept digging for info. GM told him not available, temporary hold, no restriction. So I told him to order me a ZL1 pan (# 22765382), after a week or so I called him and he said there was a new # (23188146). So that is the one I have, it has the notches near the cats, but not the openings like the Z/28 pan has.
I cut my rubber lower deflector (beneath splitter) to mimic the ZL1 & Z/28 version.
11-15-2014, 08:20 PM | #6 | |
11-18-2014, 11:24 AM | #7 |
Drives: Pontiac G8 GXP Join Date: Feb 2011
The Z/28 pan (23459995) is available now and is about $30.00 cheaper than the ZL1 pan.
FYI if anyone was checking. -Greg
1998 Pontiac Grand Prix - 11.24 @ 121
2009.5 G8 GT (Liquid Red) GXP fascia conversion, GXP diffuser 2009 GXP M6 (MSM) #405 586rwhp/495tq TVS2300, CTS-V Fuel System, Cam 222/230 116 lsa, Monster Lever 4 Clutch, American Racing 1 7/8 headers, rear Brembo's w/working Parking brake 11.91 @ 119 |
11-18-2014, 12:49 PM | #8 |
Drives: 2013 Camaro 1LE Join Date: Jul 2012
Does anyone know if the Z/28 belly pan will fit a 2013 1LE? Were there threaded holes/fasteners added to the 2014 models to allow bolting on this belly pan that are not present in a 2013 car? Just wondering if this is an easy bolt on for me or if there would need to be some drilling and tapping to the subframe to hold it on?
Thanks in advance for any info someone can provide.
11-18-2014, 07:31 PM | #9 |
Jumanji
IIRC there were caged nuts inserted into specific holes in the subframe and frame. I would think that the holes wow be there and you'll need the nuts and pan. Good luck with the projrct!
11-18-2014, 10:24 PM | #10 |
If anyone has their belly pan off to do an oil change or any other work under the car and wouldn't mind taking a few photos of the belly pan anchor points with the caged nuts that would be appreciated!
Thanks!
11-19-2014, 12:27 PM | #11 |
Answers my questions about putting this on my V6.
Retired United States Army
Bernadette: 2LT/RS, ABM #2041 of 3903 ZL-1 Springs | CAI | Muffler delete | Magnaflow resonator | LED DRL | DRL harness | RX Catch Can | Mini me Cortana: 2015 Harley Davidson Road Glide Special V&H Power Duals Headers & Oversized 450 Raider mufflers | Screamin' Eagle Stage 1 Chisel Extreme intake | Screamin' Eagle Stage 1 programmer | Klock Werks 12" Pro-Touring windscreen Own an Aqua Blue Metallic Camaro? Click here to join us on Facebook and help us in establishing the Aqua Blue Registry to locate all 3903 of these beautiful Camaros! |
11-19-2014, 12:32 PM | #12 |
Drives: '14 1LS Join Date: Apr 2014
12-13-2014, 03:01 PM | #13 |
Thanks everyone for your help. I ordered the Z28 version from Maureen at Rodgers Chevy, and am installing it today (it was cheaper than the uncut ZL1 version I bought originally). Also cutting the rubber deflector so that I only have a short piece on either end.
12-13-2014, 03:10 PM | #14 |
Please take some pics during the install to help point out where the caged nuts are located at on the subframe if you can and post them!
