Go Back   CAMARO6 > Technical Camaro Topics > Cosmetic modifications (exterior and interior)
BeckyD @ James Martin Chevy
Old 02-27-2023, 05:15 PM   #1
TheSixSpeed
TheSixSpeed's Avatar
Drives: Chevrolet Camaro LT1 6 speed
White LT1 Gauges
I want to switch out my gauge cluster to these white ones:
https://newvintageusallc.mybigcommer...lay-perf2-wht/
My problem is that it requires the SS speedometer with its 200mph limit. My LT1 currently has the 160 mph speedometer from the lower models due to the Goodyear All Seasons not being rated for anything above 150.
How do I switch to the higher speedo?
TheSixSpeed is offline   Reply With Quote
Old 02-27-2023, 11:36 PM   #2
Start The Machine
Start The Machine's Avatar
Drives: 2016 M6 2.0T
Dam, wtf can't they make a 160mph one.
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, Ikon Motorsports Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
Start The Machine is offline   Reply With Quote
Old 02-28-2023, 07:29 AM   #3
Junction65
Junction65's Avatar
Drives: 2011 GMC Sierra 1500
There have been owners that have successfully swapped SS gauge clusters (200 mph speedo) in to LT1s. This video shows a guy that did it and states that the SS cluster was reprogrammed by a company called White Auto and Media Services. You may want to give them call to see if they can reprogram the cluster you want to install.
https://youtu.be/O5H8x4l7lgQ
https://www.whiteautoandmedia.com/pr...c-programming/
2023 LT1 Coupe M6 - Black (GBA) on Black (H1T)
Blade spoiler (5ZU), Recaro seats (AQJ), Technology pack (Y3W)
LT1 PBC engine built by Shane Parker
Current mileage: 310
Junction65 is offline   Reply With Quote
Old 02-28-2023, 08:37 PM   #4
TheSixSpeed
Thanks for the suggestion, I’ll give them a call.
gauges, interior, interior customization
