Old 01-28-2015, 08:30 PM   #1
EncoreCamaros
EncoreCamaros's Avatar
Drives: 2010 Victory Red Camaro SS/RS LS3
Est. Hp boosted with meth/nitrous
I currently have the 2.9 whipple with the 4'' pulley tuned by jannetty racing and in the spring I'm going to pull the trigger and install Jannetty racing rough idle blower cam with more boost and hopefully make around 700rwhp. On top of that I'm looking to install the alky control meth kit, I'm curious on the pros and cons of running that set up on a stock bottom end and what kind of rwhp numbers are we talking. I'm not to familiar with the alky control meth kit but I've heard nothing but good things. Thoughts of maybe putting a small shot for the track as well? or thats playing with fire?
ARH 1 7/8 headers catless 3'' long system, Whipple sc 4.00 pulley 9 lbs boost, msd boost-a-pump, CAI intake, Pfadt coilovers, toe links, trailing arms, solid cradle bushings, sway bars, Forgestar CF5 19x9.5/19x11, M/T et street II radials
EncoreCamaros is offline   Reply With Quote
Old 01-29-2015, 10:52 PM   #2
BLACK10
BLACK10's Avatar
Drives: 2010 CAMARO. 10.04@133mph, 1.4 60'
On a stock motor you'll be fine with the meth and Whipple at 700rwhp. Adding N02 to that mix will be a risk.
The Whipple is more than capable of making 700rwhp with a cam and proper fueling
Good luck!
BLACK10 is offline   Reply With Quote
Old 01-29-2015, 11:25 PM   #3
JD_Alaska
JD_Alaska's Avatar
Drives: 2013 Camaro SS Coupe L99
Check out Aquamist for your meth, also look at DSX tuning. Just my .02
JD_Alaska is offline   Reply With Quote
Old 01-29-2015, 11:52 PM   #4
Js2fst
2010 transformer
Js2fst's Avatar
Drives: 2010 ss camaro
The methanol will help bring down the iats that the whipple makes
Js2fst is offline   Reply With Quote
Old 01-30-2015, 06:09 AM   #5
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Stock bottom end is good for 900whp, and if your going to do meth, get the big tank. So far I love it.
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
