Roto-Fab
Old 01-09-2015, 04:16 PM   #1
moiy1983
moiy1983's Avatar
Drives: 2010 camaro ss/rs
Questions on M6 to a 4L80E swap?
Well fellas my M6 tranny is on its last leg and that puts me in the market for a strong transmission, specifically the 4L80E. I wanting to know on the job itself. How difficult is it? What changes need to be made. What challenges were you faced with? Any and all info will be much appreciated. Pics would be VERY appreciated also. Diet coke made a thread a while back but all pics have been deleted. Another thing that concerns me is cost. Well I'm all ears thanks in advanced.
2010 SS @gt_klr Built by Jrod Tuned by Matt Sorian
LSX 434 by HKE Dragon Slayer, Callies ultra rods, Wiseco Coated Pistons, Mast 285cc LS7 Heads
ProCharger F1-X
Nitrous Outlet Direct Port
Fore Innovations Triple Pump on E85
Alky Control Meth Injection
ProEFI ECU
Stainless Works 2" Headers with Corsa 3" Exhaust
RPM 4l80e with Jakes Transbrake
BMR Everything with 15" Conversion
Zl1 Front Brakes & Carlyle Racing Rear Brake Kit
Weld Wheels
moiy1983 is offline   Reply With Quote
Old 01-09-2015, 04:24 PM   #2
UF4LIFE102SS
Treasure Coast Camaro 5
UF4LIFE102SS's Avatar
Drives: 2010 2 SS
Diet was on this morning so try pm him also Mr Nasty had a 6L but put a 4L in using Jakes parts and been a beast!
UF4LIFE102SS is offline   Reply With Quote
Old 01-10-2015, 06:46 PM   #3
pancherj
Drives: 2010 Camaro SS
Diet's pics are gone for good. I am in the middle of the swap right now, I have IM'd back and forth with Diet a few times. so far, things are pretty straightforward. My progress is pretty slow though! I am almost done rebuilding the 4L80E. I have the trans cooler in and the fan wired up. I also have the console out and the seats out.
If you have any questions, let me know!
pancherj is offline   Reply With Quote
Old 01-11-2015, 03:47 AM   #4
moiy1983
moiy1983's Avatar
Will do! Please keep us posted!
ProCharger F1-X
ProEFI ECU
Weld Wheels
Old 01-14-2015, 03:23 PM   #5
moiy1983
moiy1983's Avatar
What a dilemma! ...... So to those who made the change to the 4l80E. Do you have any regrets? I imagine dig racing is awesome but how is from a roll? Really need some help from guys who have made the change? What are the pros and cons?
ProCharger F1-X
ProEFI ECU
Weld Wheels
Old 01-14-2015, 04:43 PM   #6
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
Get a triple disc lockup converter and lockup wot. You can have your roll races too. It would be the same top speed as your 4th gear now.
ttshovel is offline   Reply With Quote
Old 01-14-2015, 05:58 PM   #7
jrpxxii
jrpxxii's Avatar
Drives: 2010 Camaro SS/RS 427ci
You wont regret it. Its not too difficult to make the swap either and get you a good trans controller like the PTS 2000.
jrpxxii is offline   Reply With Quote
Old 01-17-2015, 12:23 PM   #8
moiy1983
moiy1983's Avatar
Well I finally committed to the 4l80E swap. I called up RPM and placed my order. It will take a few weeks to receive it.
ProCharger F1-X
ProEFI ECU
Weld Wheels
Old 01-17-2015, 12:37 PM   #9
ttshovel
ttshovel's Avatar
Good deal! I test fit mine for the first time yesterday. You definitely need to cut the frame. Ill add a pic later if you'd like.
Old 01-17-2015, 07:10 PM   #10
moiy1983
moiy1983's Avatar
That would be great. Keep me posted!
ProCharger F1-X
ProEFI ECU
Weld Wheels
Old 01-17-2015, 07:15 PM   #11
402
Drives: Camaro
I would just wire in a t42 trans controller so you have factory control.
402 is offline   Reply With Quote
Old 01-18-2015, 10:43 AM   #12
Bo White
Bo White's Avatar
Just jump the wiring and make it full manual.
Totalled:
Old 01-27-2015, 10:29 PM   #13
BLACK10
BLACK10's Avatar
Drives: 2010 CAMARO. 10.04@133mph, 1.4 60'
I agree. Manual valve body is the only way to go especially if you are FI.
BLACK10 is offline   Reply With Quote
Old 01-28-2015, 02:49 PM   #14
Bo White
Bo White's Avatar
I drive on the interstate too much for a MV. They create a touch more heat than a stock one up on the hwy
Totalled:
