Vararam
Old 04-03-2014, 10:21 AM   #1
rickdlance
Drives: 700hp 6 speed
1000 HP Help!
I'm new to the forum, but not to speed. My signature has my current car but I need more. I want to break 1000 hp in a true street car. I also want to put my original motor on the stand and save it.
Looking for advice. I know I'll need a fuel pump and bigger injectors. I would like to re-use my cam and cylinder heads.
I'm thinking about maybe buying a LSX 454 short block. Any suggestions? Is this a bolt in deal using my parts and headers?
Will my supercharger handle this? Will I need a bigger throttle body? Are there any recommendations on where to buy the short block?
2011 HPE600 Camaro
TVS Supercharger w/3.6" pulley upgrade
Kooks Headers & 3" exhaust w/ Dynomax VT mufflers & High Flow Cats
Vented & Drilled Rotors w/ Ceramic brake pads
GM Performance CNC Cylinder heads
3:91 gears
ACT dual disc clutch
Comp Cams 223/231 610/615 on 115 cam
Comp cams timing set, push rods, valve springs
Currently 597.97 RWHP @ 6700
529.61 Torque @ 4500 on conservative tune
rickdlance is offline   Reply With Quote
Old 04-03-2014, 11:22 AM   #2
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
You will for sure need a bigger blower, squash pump, and bigger injectors.
MODS:
ADM built 417, 2.9L Whipple with 3.250 pulley, ADM ported and polished LSA heads,ADM stage3 cam,ADM LSA belt drive system,ADM CAI race scoop, ADM dual fuel pumps, ID 850's, BMR full suspension, Gforce 9 inch kit with 3.5 inch driveshaft, Street Slayer twin carbon clutch, Lingenfelter oil seperator. Tuned by built by ADM Performance, 763rwhp,705rwtq
10aSSee D is offline   Reply With Quote
Old 04-03-2014, 11:26 AM   #3
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
IMO 454 is not optimum for the boost required to hit 1000. Stick with an LSX at 427 or smaller. thicker cylinder walls are one reason.
Your Maggie is woefully undersized for 1000whp and bigger cubes.
Fuel system you need at least Squash return style setup with ID1000s or preferable a bit bigger.
Go twin turbo or slap a YSI or even better an F1x
It takes a BUNCH of cash to make a 1000+ whp reliable street car. Good Luck.
Look at the sticky here in the FI forum about motors/builds for the guys running the big HP setups. It will help
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 04-03-2014, 11:31 AM   #4
Frans96ss
Frans96ss's Avatar
Drives: 96SS
Give us a call. We can get you taken care of from start to finish. We did this for a customer in Dallas Texas
Frans96ss is offline   Reply With Quote
Old 04-03-2014, 01:49 PM   #5
blake-b
blake-b's Avatar
Drives: 2009 ZR1
I see you are in Holden MO. I am near Liberty MO. PM me with your number and I'll give you a call. I've been over 1000hp with 2 slightly different combos and getting ready for a third.
Old 04-03-2014, 02:15 PM   #6
AGP Turbo
Drives: All things Turbocharged
+1 to all of that.
AGP Turbo is offline   Reply With Quote
Old 04-03-2014, 03:53 PM   #7
Unreal
Drives: 2006 Z06
Talk to Blake. I'm sure he could steer you in the right direction.
Forged 376 or bigger, but I wouldn't do a 454 and some twins will be the easiest/cheapest way to get there.
Nick
Corvette Z06 -1200ish rwhp
Unreal is offline   Reply With Quote
Old 04-03-2014, 04:25 PM   #8
AGP Turbo
Do a forged stroked motor 416-427ci and keep the compression around 10:1 or higher. LSX block for safety to make it last a long time even if an accident happens here and there.
Then a pair of 56mm turbos and have fun.
Old 04-03-2014, 05:21 PM   #9
pdiddy
Drives: 2011 2SS
More MO people both of u guys should come to the BBQ car meet on April 19th in independence it's at Resto mod car shop if u r intrested I can get u more details pm me it's a free BBQ then a cruise after is what the information shows on it would love to hook up with some more local guys back on topic now for that hp I will need some good drive train up grades
2011 2SS,fti th400, ECS 1500, Flex Fuel, Boost built 376, squash fuel system
pdiddy is offline   Reply With Quote
Old 04-03-2014, 07:22 PM   #10
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
I'm saying use the RHS or ERL aluminum block instead of the LSX and make sure you get the 6 bolt head. I did it with a blower and nitrous but those turbos sure look tempting......
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 04-03-2014, 08:42 PM   #11
mikeyg36
Drives: 2015 Z/28 #533
I'd go with twin turbos.
Old 04-04-2014, 02:59 PM   #12
H-E
Drives: 2010 zr1 Camaro 2011 vert
If you drive the car on the street and rarely run above 140 -150 mph your TVS can be a heck of a fighter on the street.I routinely out run 1000hp turbo cars and centris with my 800hp 454 Maggie car.The others make impressive dyno numbers and can be a lot of fun but you can build a great street car with what your thinking. If we can help you out in any way give us a call.
H-E is offline   Reply With Quote
Old 04-04-2014, 03:30 PM   #13
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Send a message via AIM to SSE 4 2SS Send a message via Yahoo to SSE 4 2SS
I'll be your huckleberry...
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
“If everything seems under control, you're just not going fast enough.” Mario Andretti
If you can turn, you ain't going fast enough...
SSE 4 2SS is offline   Reply With Quote
Old 04-04-2014, 03:39 PM   #14
AGP Turbo
By 130mph (top of 4th) I've pulled a couple bus lengths on built Maggie cars with a stock L99 TT. But none of them with a 650hp n/a motor under the blower.
