dave@hennessey
Old 05-07-2016, 08:25 AM   #15
Merc
In The Circle
Merc's Avatar
Drives: 2010 Camaro 2SSRS IOM M6
Originally Posted by BFASTNOTLAST View Post
woTVz_bwoDY&fs=1">woTVz_bwoDY&fs=1" type="application/x-shockwave-flash" width="855" height="505">
1.56 and still leaving soft. I also play with spring rubbers to stiffen the rear even more. I'll put them in later today and take a picture for you guys. But the IRS definitely does not like squat. Squat means loosing time going forward...... To an extent..
1.56 sixty is nothing to sneeze at.
Merc is offline   Reply With Quote
Old 05-07-2016, 08:33 AM   #16
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Originally Posted by Mkn95u0 View Post
so lowering springs will negatively impact most 60' times & launches? Is it just recommended to keep the stock springs, or is there a better alternative?
With 1" BMR lowering springs and trailing arms, I would always have a .1 to .15 slower 60' with full traction than the guys with stock springs. Stock springs are yeilding 1.5x 60'. Sounds like others have experienced different than I.
Originally Posted by Merc View Post
I'm working with Jordan from JDP on my coiler settings for the new Ride Tech's and He want's almost full stiff in the rear and full loose in the front. Jordan say's with IRS you don't want the rear to squat. Custom spring rates as well 350 in the front and 550 in the rear, stock is 300/500.
I'll defer to Jordan for sure.
That's about as good as it gets for stock suspension which is damn good IMO.
Old 05-07-2016, 08:51 AM   #17
Merc
In The Circle
Merc's Avatar
Making the Strange order Monday morning for the 4.57 2nd gear set. Wondering what Pumpkin will 60 foot this fall with the new set up? Just had to clarify a few things with Frank from DSS as Strange recommended that I run the bolt through forged case rather the light weight case one.
Old 05-07-2016, 02:04 PM   #18
BFASTNOTLAST
BFASTNOTLAST's Avatar
Drives: 2012 SS LS3
These come in all different durometers, this one in particular is a 30lb rubber.
BFASTNOTLAST is offline   Reply With Quote
Old 05-07-2016, 02:27 PM   #19
Merc
In The Circle
Merc's Avatar
Nascar stuff?
Old 05-07-2016, 03:13 PM   #20
BFASTNOTLAST
Drives: 2012 SS LS3
Old 05-08-2016, 06:07 PM   #21
GQ4Life
Drives: 2010 Camaro SS LS3
Between stiffer suspension and now 20" rims instead of 18" mine doesnt hook as good
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
GQ4Life is offline   Reply With Quote
Old 05-16-2016, 02:28 PM   #22
Mkn95u0
Mkn95u0's Avatar
Drives: 2012 IBM L99
seeing a lot of mixed reviews. Maybe can say it affects some, but not noticeable enough where as weather and launch technique could be the factor?
So safe to say that If i were to drop 1", it more than likely wouldn't help or hurt my times more than say tire psi, weather, technique, and/or track prep basically.
Robert
12.012 @ 115.75mph DA: 2371 | 486rwhp/467rwtq (11/8/2015)M
11.265 @ 123.55mph DA: 2318 | 526rwhp/532rwtq (11/19/2016)M
10.722 @ 132.21mph DA: 850 | 645rwhp/581rwtq (12/3/2017)M
10.609 @ 130.19 DA: 975 | 675rwhp/629rwtq (2/16/2020)D
Build: E-Force w/ 3.25" pulley (11lbs of boost), 10% OD under pulley, Fore Dual Fuel System, ID850's, AEM CAI, Borla Long Tubes, Flowmaster Super 10's, Circle D 3200 converter 258mm triple disc lockup, cam 226/242 116+4 LSA, ZL-1 Rear end, E85 & BRC Raceworks Tune (previously known as CMS)
Youtube Channel: http://www.youtube.com/c/RobertMitchellRCM
Mkn95u0 is offline   Reply With Quote
Old 05-22-2016, 04:53 AM   #23
2010SSRSM6
2010SSRSM6's Avatar
Drives: My wife crazy with my C5 usage.
Where you've got an automatic, I don't think you would see a big loss, if any. If Jordan is right (and I see no reason to doubt him based on his track record) it sounds like they may help.
UNDER CONSTRUCTION......again......
2010SSRSM6 is offline   Reply With Quote
Old 05-27-2016, 08:58 PM   #24
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Can anyone reccomend a 2" drop spring for the year that is around the stock spring rate?
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II
13.15@106 1.95 | 100% Stock
12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune
12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune
11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts
10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800
Pro Stock John is offline   Reply With Quote
Old 05-31-2016, 11:51 PM   #25
2010SSRSM6
2010SSRSM6's Avatar
Eibach's are close to 1.5" drop for the rear, I think Hotchks and Pfadt were both 1.75" drops. Maybe BMR?
Old 06-03-2016, 12:31 PM   #26
Pro Stock John
Writer
I got a set of BMR 1.4 rear drop springs on the way.
PROJECT HEAVY CHEVY
Old 06-03-2016, 01:05 PM   #27
Rdunn
Really, Really Fast
Rdunn's Avatar
My car is still 100% stock shocks and springs. The only thing i had modded in the susp was BMR bushings, trail arms and DSS axels. on 17s my car would average a 1.38-.39
since then i added the carlyle 15" kit and cut a coil off the stock springs. first pass off the trailer leaving soft the car went 1.35 sixty.
Procharger F1X, TH400, E85, CBI Street Cars, DSX Tuning, 1300whp
Rdunn is offline   Reply With Quote
Old 12-31-2016, 08:16 PM   #28
jydavis
Drives: 2011camaross
Did you ever try the 1.4 drop springs to see if it helped or hurt the 60 foot times. Thanks jerry davis
jydavis is offline   Reply With Quote
