Old 01-09-2018, 11:53 PM   #1
camaro5
camaro5's Avatar
Drives: X-15 Velocipede
Camaro ZL1 1LE Spied Sans Wing, With Carbon Ceramic Brakes
At the very least, we’re looking at General Motors validating carbon-ceramic brakes for the Chevrolet Camaro ZL1 1LE. At most, this could be some sort of Camaro Z/28 test mule.
Photos of the prototype car, posted to Facebook page V.I.S.I.T. on Monday, show a manufacturer-plated Camaro ZL1 1LE without the massive rear wing, but with large carbon-ceramic brakes hiding behind the wheels. The ZL1 1LE does not feature carbon brakes and retains iron rotors for a variety of reasons.
If this is some kind of sixth-generation Camaro Z/28 prototype, it begs the question of what resides under the hood. The previous-generation Camaro Z/28 skipped forced induction for the massive 7.0-liter LS7 V8 engine. News on the sixth-generation Z/28 has been near zilch, but a March 2017 report claimed GM is working on a 5.5-liter LT6 V8 engine for such a car. This engine is reportedly a DOHC design with a flat-plane crankshaft and will be closely related to a forthcoming LT7 V8 engine, which could find a home in the ever-unconfirmed mid-engine C8 Corvette.
Flash forward to present day, and those rumors seem slightly corroborated. CAD drawings revealed a twin-turbo LT7 V8 engine last month, and a report from last November named three engine options for the upcoming C8 Corvette. One of those engines? A 5.5-liter DOHC V8.
Also off the shelf is the 6.2L LT5 V8 powering the ferocious 2019 Corvette ZR1. The dual-injected pushrod V8 boasts a larger supercharger than the LT4 engine found in the Camaro ZL1 and Corvette Z06, and produces a staggering 755 horsepower. It might not be naturally aspirated, as has been Z/28 tradition, but such an engine finding its way to the Camaro family would surely be the crown jewel of a top-of-the-line model.
All of this is to say we may just be looking at an upcoming carbon ceramic brake package for a supposed 2019 Camaro ZL1 1LE, and not a Z/28, in this instance. But, Chevy has surprised us before.
Read more: http://gmauthority.com/blog/2018/01/...#ixzz53l3slrOH
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 01-10-2018, 07:15 AM   #2
FringBirdAloha
Drives: Pre-production ZL1 M6
Originally Posted by camaro5 View Post
If it is a Z28, it’s not going to be naturally aspirated. There’s no doubt there are mules running around with LT5’s in them. But develop a new DOHC NA for the Camaro?... nope. Plus any release of an LT5 based Camaro would be at least a year after the ZR1. But we can be sure it’s in the plans.
I think there may have been some fallout over not offering CC brakes and they may be implementing a brakes package.
FringBirdAloha is offline   Reply With Quote
Old 01-10-2018, 08:25 AM   #3
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
i agree, the amount of engine technology and refinement to make a meaningful gain over the 7.0L and keep it NA would be impractical. You aren't going to get up 650hp at a lower weight without going to extreme measures that would require materials and tooling that would be out of reach. Think lamborghini or ferrari NA engine. Ferrari 812 gets 788hp, but requires 12 cylinders to do so, just the maintenance on that kind of engine is staggering for most people, let alone the cost of it.
JamesNoBrakes is offline   Reply With Quote
Old 01-10-2018, 08:59 AM   #4
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
I'm real curious...a little Devil's Advocate work, here:
- Some racing series do not allow CCM disks.
- Most racers (esp. Porsche) ditch their Carbon brakes for iron replacements for track days due to wear and price.
- They cost a ridiculous amount of money to replace...and they're brittle while servicing.
- Different compound, more aggressive racing pads are more readily available for iron brakes.
- The '14 Z/28 (with CCM brakes), at 3858 lbs, stopped from 60-0mph in 97 ft.
- The '18 ZL1 1LE (with same-sized iron brakes), at 3837, stopped from 60-0mph in 91 ft.
GM/Al have said they didn't see a benefit to using the CCM brakes in either fade resistance or braking distances, so they couldn't justify the cost in utilizing them on the car.
So why do we consider these brakes worth anything other than a party piece?
Old 01-10-2018, 09:41 AM   #5
Fast Dalmation
Fast Dalmation's Avatar
Drives: 2018 Summit White ZL1 1LE
Nicely Said!
Also unless they are heated up, they will not perform correctly and make tons of noise.
- Few, if any racing series allow CCM disks.
GM/Al have said they didn't see a benefit to using the CCM brakes in either fade resistance or braking distances on the Camaro, so they couldn't justify the cost in utilizing them on the car.
Fast Dalmation is offline   Reply With Quote
Old 01-10-2018, 09:46 AM   #6
ninetres
ninetres's Avatar
Drives: Crush ZLE M6 | 2000 Corvette FRC
- Most racers (esp. Porsche) ditch their Carbon brakes for iron replacements.
I agree with most of this (although I know many series that allow them). I also know sooooo many people that immediately remove them, and run iron until they sell the car to avoid ever having to replace them. What a waste of time and money for something you keep on a shelf in the garage!
A ZL1 1LE level Camaro, plus CCB, plus whatever other upgrades it will include will cost what....$85k? $95k? Eek.
ninetres is offline   Reply With Quote
Old 01-10-2018, 09:53 AM   #7
Mr. Wyndham
I stand corrected - and will edit the post!
I knew a few didn't allow them, and since I don't know all, I sort of extrapolated.
A dug up a couple of other references that are pertinent, too...
Written in 2014 or '15
http://www.motortrend.com/news/20-be...nces-recorded/
2015 Z06/Z07 (with CCM brakes), at 3533lbs, stopped from 60-0 in....91 feet!!!
...exactly the same as the much heavier ZL1 1LE....just sayin'....
Old 01-10-2018, 10:05 AM   #8
travislambert
travislambert's Avatar
Drives: '17 ZL1
I'm not sure this completely true, is it?... Some do for sure, but I don't know about "most".
These guys aren't technically "racers", but a Porsche group runs every month during the summer at PittRace. Several are pretty hardcore guys with $500,000+ invested in their cars. On multiple occasions I've ran my ZL1 with them (because they usually don't have enough Porsches to justify the track rental). I don't recall a single person who has swapped their carbon brakes for iron. They pretty much all are running carbon ceramics.
With that said, I've seen many Viper ACR owners go back to iron brakes. If you talk to them, their reasoning is almost always cost.
When I looked into this a few months ago, I was using the 5th Gen CCMs for reference and the cost didn't seem too bad to me. I think the CCM front rotors could be bought for a little over $1,000 each and a set of factory pads were around $800. That's still a lot of money, but it's cheap as far as carbon brakes go. Also, it's comparable to what track guys spend on tires.
That's a fair point. I didn't look into the details of this test, but I would think as the brake temperature increases the CCM brakes would get slightly better and the iron brakes would be slightly worse.
Was iron the right choice for the ZL1? I don't think there's any question. For most people iron makes way more sense. With that said, I am very excited to see that CCMs might be coming our way as an option! As long as the price isn't crazy, I want to try them.
2023 Camaro SS 1LE A10
2023 Camaro ZL1 1LE M6
2017 Camaro ZL1 M6
2016 Camaro SS M6 w/LT4 (Sold)
travislambert is offline   Reply With Quote
Old 01-10-2018, 10:10 AM   #9
ninetres
ninetres's Avatar
For me, I think the weight savings seems interesting. For all four corners it should be 50lbs+ of total rotating weight savings. There is no way that doesn't equate to some performance benefit. I know what Al has said, but I can also see what all of the exotics come from the factory with... and also what's pictured in this thread.
$1800 tires per Corner? Huh? What sort of unicorn hide tires do people you know run? Hoosiers can be had for <$500/corner.
Old 01-10-2018, 10:16 AM   #10
closs2sx
closs2sx's Avatar
Drives: 1970 chevelle
he's talking about the ceramic rotors and pads for each corner and if you factor in how many sets of tires you go through before you change pads and rotors it would be close
On Order 2018 ZL1 1LE Garnet Red Tint Coat Metallic
MY Car
2015 Z06 Z07
Daytona Sunrise Orange Metallic
Dads Car
2013 ZL1 vin 963
Crystal Red Tint Coat/Black Wheels
Exposed Carbon Fiber Insert
6 Spd Manual
closs2sx is offline   Reply With Quote
Old 01-10-2018, 10:18 AM   #11
travislambert
Drives: '17 ZL1
Surely you wouldn't do a full rotor and pad replacement with each set of tires, right? The brakes pads should at least last through a couple sets of tires. And the rotors will last through a few sets of brake pads as long as you change the pads early enough.
Given that factory tires are roughly $1,400 a set. The overall maintenance cost of the brakes should at least be comparable to the overall cost of tires.
That's all I meant.
2017 Camaro ZL1 M6
Old 01-10-2018, 10:34 AM   #12
Mountain
Mountain's Avatar
Drives: 2017 SS 1LE, 2016 1SS (previous)
It would make sense to create a Z/28, mainly based on the fact of a 5.5L coming. Why? The Cadillac DPi’s just switched to a 5.5L (hmmm...). The next Corvette will have a 5.5L (hmm...). The GTLM/GTE Corvettes run 5.5L’s (#muchdata #proven). With that, it makes sense to homologate to the GT4 Camaro, which opens up a business case for the option to create a Z/28 road car. Right now, the GT4 engine is a GM Performance/GM Racing frankenstein. Cost, complexity, durability and marketing wise, it’s a better move to go with the Corvette C8 5.5L.
Take a ZL1 1LE, remove the LT4 and shove in a 5.5L DOHC, or even HOHV, you reduce weight. Remove the rear seats, strip down the creature comforts...
With a 5.5L, you get a more stabil engine for high RPM. You can still get the power performance needed through a shift in the RPM band. Also, a 5.0+L V8 is still large enough to get good mid-range torque. A 5.5L also helps in pro racing because a 5.5L restricted is more efficient and stabil than a 6.2L (BOP - heat management/combustion efficiency) and fuel economy is better. So, a 5.5L also makes sense for the race cars.
Mountain is offline   Reply With Quote
Old 01-10-2018, 11:05 AM   #13
URBAN LEGEND
URBAN LEGEND's Avatar
Drives: 20 X3M CP & 19 ZL1 1LE A10
Hmm. Yet Vettes can have them... GM better put these damn brakes on this 🚘.
🔺22 RS E TRON GT
🔺21 Model S Plaid
URBAN LEGEND is offline   Reply With Quote
Old 01-10-2018, 11:16 AM   #14
closs2sx
closs2sx's Avatar
That's all I meant.
i was picking up what you were throwing down
MY Car
2015 Z06 Z07
Dads Car
2013 ZL1 vin 963
6 Spd Manual
