Old 01-14-2017, 06:14 PM   #1
booneSS13
booneSS13's Avatar
Drives: 2013 Camaro SS LS3
Lightbulb Nitrous Owners, It's your time to shine..
Don't see too much on the forum from people using nitrous. Like the recent AGP turbo thread this would be a good place to post your nitrous setups. This would also make a good informative for people just getting into nitrous as well
Motor (CI):
Brand:
Horsepower Shot:
Cam:
Trans/Clutch/Converter:
Fuel System (E85, dedicated fuel setup, etc.) :
Other Nitrous Extras:
Installed/ Tuned by:
Horsepower/Torque Numbers before and after spray:
1/4 mile time/speed/60ft:
And of course Pics of your setup would also be a nice addition.
Romans 5:8
But God demonstrates his own love for us in this: While we were still sinners, Christ died for us.
-Fastlane Cold Air Intake, NPP cat back exhaust, Stainless Works LT Headers, 2r max camshaft, Stage 3 Ported Heads (Manley Stainless steel values, titanium retainers, dual valve springs, bronze guides), Wiseco Forged Pistons, K1 Forged Rods, Clevite Bearings, Factory Crankshaft, Comp Cams rocker arm trunion kit, Morel 5315 lifters, JP performance single billet timing chain, Melling oil pump, Spec stage 3+ clutch and flywheel, BMR trailing arms, Nitto 555r 305/35/20.
booneSS13 is offline   Reply With Quote
Old 01-14-2017, 10:45 PM   #2
jman123
Drives: 2015 Camaro 2SS 1LE
When I did have nitrous...
Stock ls3
150 shot
Dedicated fuel cell (e85 in both tanks)
235/239 112 lsa stage 4 TSP N/A cam
Nitrous outlet 102 FAST Plate system
Stock clutch
Stock trans
474/434 before spray | 618/655 after
Installed by a friend
Tuned by DSM LIGHTS
Car ran great on this setup and hurt a lot of feelings
I love boost and my new found power but I'm glad I went the nitrous route first!!
AGP Twin turbo kit, base 54/57 Borg Warner turbos, TSP stage 4 N/A cam, AGP twin 430lph e85 pump fuel system w/ flex fuel sensor, 1000cc FIC injectors, Grimm speed manual boost controller. (830 rwhp 778 rwtq @ 15.5 psi)
jman123 is offline   Reply With Quote
Old 01-14-2017, 10:49 PM   #3
booneSS13
booneSS13's Avatar
Stock ls3
150 shot
Stock clutch
Stock trans
Tuned by DSM LIGHTS
I've never heard if running e85 in both tanks. Did you get away with pulling less timing?
Romans 5:8
Old 01-15-2017, 12:58 AM   #4
jman123
Well if you're referring to being able to pull more timing as if I was on 93 in the tank and e85 in the dedicated fuel cell then yes. I mostly did it out of convenience because I would also run n/a frequently and the car gained some good power on e85 through out the curve while n/a.
Old 01-15-2017, 09:09 PM   #5
booneSS13
booneSS13's Avatar
That wasn't a bad idea then. How much N/A horsepower did you gain on E85 though?
Sent from my VS990 using Tapatalk
Romans 5:8
Old 01-15-2017, 09:11 PM   #6
booneSS13
booneSS13's Avatar
No other 5th gen owners spraying? I know there's got to be more guys than that. Old setups count too btw.
Romans 5:8
Old 01-15-2017, 10:42 PM   #7
jman123
Not much. Gained about 8rwhp through out the curve but only 5rwhp peak. Torque was a lot more like 12rwtq peak and throughout the curve.
Old 02-08-2017, 06:25 AM   #8
PFL
PFL's Avatar
Drives: Camaro SS
Stock ls3
150 shot
Stock clutch
Stock trans
Tuned by DSM LIGHTS
This choice was incredible. Could you tell us more details?
PFL is offline   Reply With Quote
Old 02-14-2017, 11:06 AM   #9
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
I'm more interested in who melted pistons with NOS?
Moto-Mojo is offline   Reply With Quote
Old 08-02-2017, 10:15 PM   #10
Samirq12
Drives: camaro
If I have a Zl1 fuel pump, do I need a separate fuel pump for a 150 shot ? Its just a cam car.
Samirq12 is offline   Reply With Quote
Old 08-02-2017, 10:38 PM   #11
Warhorse
Warhorse's Avatar
Drives: 2011 Syn Green Camaro
430 cu, little TVS 2300 Blower maxed out but assisted somewhat by Nitrous Outlet Direct Port 250 shot, E85 main and E98 dedicated, 430 cu, ported Mast large bore heads, very healthy cam. Should have went F1X but still a very unique setup by 21st Century Muscle Cars
No dyno numbers, still working bugs out of new build.
New Build
5th Gen Camaro, 430ci LSx, Ported Mast 280's, E85 Flex fuel, ID1300's, Squash return, TVS 2300 w/Nitrous Outlet 250 Shot Direct Port, Nano, LPE 10/14 Rib, OD Crank, OD Rear, 2.8" upper, RDS Plate, NW102, 5" Intake, 2" ARH, PATC Built A6, BMR 15" Brake Conv. w/Drag Suspension, Front QA1 DA's, Weld S76 beadlocks & "V" Series fronts. STILL 1k too heavy!!!
Warhorse is offline   Reply With Quote
Old 08-02-2017, 11:20 PM   #12
booneSS13
booneSS13's Avatar
That's going to be killer. What's your compression?
Romans 5:8
Old 08-03-2017, 10:20 AM   #13
WoodBoss
"Old School"
Drives: 2010 2SS L99
Internally Stock 2010 L99 w/Boltons & 125 Shot
Motor (CI): 376 Internally Stock L99 with LT Headers, BW TB & Roto-Fab
Brand: ZEX Part #82380B
Horsepower Shot: 125
Cam:Stock
Trans/Clutch/Converter: Stock 6 Speed Automatic
Fuel System (E85, dedicated fuel setup, etc.) : Stock Fuel Pump
Other Nitrous Extras: NGK TR6IX1 spark plugs, Bottle Heater
Installed/ Tuned by: Installed By Me/Tuned By DynoSteve
Horsepower/Torque Numbers before and after spray: Unknown
ET: 11.838 sec
Speed: 117.79
60' 1.697
RT: .186
Coditions: 95* with a DA of 3000
The link below shows my Nitrous Installation:
WoodBoss is offline   Reply With Quote
Old 08-03-2017, 10:25 AM   #14
VASTREETRACER
Drives: 2023 Camaro SS 1LE on order
you wont "melt" your pistons with nitrous unless you are greedy or not tuned for it
2017 Camaro SS 50th anniversary, I sold it but 2010 Camaro SS, whipple, cam, full bolt ons and full exhaust made 739/656 RWHP/TQ on 93 pump gas
VASTREETRACER is offline   Reply With Quote
bottle, jetting, n20, nos, zex
