AWE Tuning
Old 12-30-2019, 07:36 PM   #1
Coded4SS
Drives: 2020 1SS 1le
3rd gear grind when cold new SS
Hey guys
Got 600 miles on a 1ss 1le.
Sometimes my third gear will get a grind sound going in. This has also happened to second gear. This morning specifically second was notchy and made more of a noise going into gear and then third had a grind like sound. I feel like I'm driving normal but open to the idea I'm driving it wrong or something. It's not all the time. I can swear the trans is butter sometimes and other times it's temperamental (when cold). Idk if this happens when warm because I usually drive the car much more spirited and probably wouldn't hear it.
Thoughts?
Coded4SS is offline   Reply With Quote
Old 12-31-2019, 07:30 AM   #2
jeffro355
Drives: 2019 Camaro SS
I also have same problem; the colder the temp the worse it is. I have a 2019 1ss with 2000 miles. I will be taking into dealer when i get some time to see what they say
jeffro355 is offline   Reply With Quote
Old 12-31-2019, 08:29 AM   #3
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
I have 25K on my M6 and it is still notchy and cranky on a 1-2 shift when cold. I switched the fluid to Royal Purple SynchroMax about 4k miles ago. It helped but did not eliminate the issue. I have found that this Tremec 6060 just has to be shifted using a firm and deliberate hand especially when cold. If I baby the 1-2 shift when cold - it will balk.
2010 Camaro 2SS Cam/Headers/CAI/3.91 gears
476 rwhp/440 rwtq (sold)
SSDan is offline   Reply With Quote
Old 12-31-2019, 12:30 PM   #4
Coded4SS
That's how I'm seeing it too. It dosnt like low power granny shifts lol. Alright fair enough I'll drive it like it should. Thanks for the follow up
Old 12-31-2019, 12:50 PM   #5
Mov Ov3r
What speed limit?
Mov Ov3r's Avatar
Drives: 2017 SS 1LE
It's known the 1LE trans is notchy especially in cold weather. I don't want to force the synchros when it's cold but like you guys have mentioned the trans does not like cold temps. Once it warms up the shifts should be smooth, I have 12,800 on my 1LE and it was silky smooth in July (consistent highs in the 90-100's / lows mid to upper 80s low 90s), now I let the trans warm up before I do any spirited driving / shifting.
Mov Ov3r is offline   Reply With Quote
Old 12-31-2019, 02:57 PM   #6
retmil
Drives: 2022 Wild Cherry SS
My '17SS has had rough shift issues 1st to 2nd since new and changing to Royal Purple has only helped a little. A GM tech who is familiar with these transmissions says the 2nd gear synchro is the culprit. Others on the forum have suggested shifting over 3k which helps some but it not practical in heavy traffic. Issue does seem to be a little better in warmer temps but not much.
retmil is offline   Reply With Quote
Old 12-31-2019, 03:03 PM   #7
Mov Ov3r
What speed limit?
Mov Ov3r's Avatar
Drives: 2017 SS 1LE
I heard it's the 2nd gear synchro as well. What I will say is when it's warm outside I have no problems with the transmission at all.
Old 01-01-2020, 05:24 AM   #8
VinnAY
Drives: 18 1SS/1LE
A notchy manual when cold is part of the experience; it's relatively normal.
VinnAY is offline   Reply With Quote
Old 01-01-2020, 09:59 PM   #9
MB1
Drives: BMW M3
Is it similar to this guy’s experience?
https://m.youtube.com/watch?v=Fxngwi...ature=youtu.be
2013 e92 M3 Competition DCT
Past:
2015 Boxster S 6MT, 2014 Corvette Z51 7MT , 2010 e90 M3 DCT, 2006 M3 6MT
MB1 is offline   Reply With Quote
Old 01-02-2020, 08:41 AM   #10
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
I don't have a manual right now, but in the past it has been my experience that manual transmissions need to be treated just like engines when they are cold: don't go all boy-racer on them until warm. The only difference is that the engine is getting damaged quietly, while the tranny will bark at you.
On a cold tranny, you can usually avoid grinding by double clutching.
Old 01-07-2020, 07:47 PM   #11
Camaro'd
Drives: 2018 Camaro 2SS
Normal for my '18 when cold. Seems to be a characteristic of this tranny.
Camaro'd is offline   Reply With Quote
Old 01-09-2020, 10:57 AM   #12
Canadian Steve
Canadian Steve's Avatar
Drives: 2019 Camaro SS Convertible
I have a '19 2SS 6M and although the gears don't grind, I do hit resistance periodically shifting up or down into 2 or 3, especially when it's cold. I really didn't experience this problem much at all until temperatures started falling in September/October and now that it's January I notice this every time I take it out. As most have said, letting it warm up before getting aggressive helps, but I've found it doesn't completely prevent this from happening. Backing off and taking another run at the gear usually works as well.
2019 Camaro 2SS Convertible
Shadow Grey Metallic with Adrenaline Red Interior
6MT, MRC, NPP, Carbon Flash wheels w/ SS wheel caps
Canadian Steve is offline   Reply With Quote
Old 01-10-2020, 11:00 PM   #13
Coded4SS
Nope. But that was a interesting video thanks for the link.
So I been letting the car warm up a bit longer before driving it and i haven't been seeing the issue. I'm keeping an eye on it though. Otherwise it's pretty dam good. So this might just be the case of a cold manual trans and it's been a while since ive driven a manual and need to re adjust
