12-21-2017, 03:39 PM | #197 |
To make the interior a more pleasant place to be, they need to open up the windows and they aren’t gonna do that.
You can’t sell these cars with a “you’ll get used to it”. If you can’t see out of the fuxkin thing during the test drive you’re gonna lose sales. Common sense. I don’t care how good it made the car look. The styling didn’t do it for me anyway. As much as I love the overall quality, drivetrain, and chassis on these cars, I am eyeing up 2012 gt500s |
12-22-2017, 11:09 AM | #198 |
Drives: BMW M3 Join Date: Aug 2013
Did I see that the '19 will have 485hp, 6900 rpm redline and a optional 10 speed? fake news?
2013 e92 M3 Competition DCT
Past: 2015 Boxster S 6MT, 2014 Corvette Z51 7MT , 2010 e90 M3 DCT, 2006 M3 6MT |
12-22-2017, 11:12 AM | #199 |
Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
I received that photo last night with Camaro6 ghosted over it. Fake news
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
12-22-2017, 12:33 PM | #200 | |
Drives: 2017 Camaro SS 50th Join Date: Jun 2017
They are coming out with the C8 Corvette in 2019, right? That will be the Camaro refresh year. So while there might be a revised LT1 making more power.. who knows what is going in the C8. Will it be a more powerful smallblock 6.2L V8, updated with a new engine name? Possible right.. history has this pegged. LS1 > LS6 > LS2 > LT1. etc etc could be something following that tread, with marginal more horsepower. This would be the BEST case scenario. BUT.. another thing to consider is that C8 Corvette, as spy shots show, will be a mid-engine car. Will a 6.2L N/A V8 work for that mid-engine car? Or does a smaller, higher revving engine work better that application? If GM engineers decide on the latter, then that would make things interesting. Camaro could continue to use LT1 (and stay at 455HP or go to "460HP" like they did in the Corvette, for marketing sake). Orrrrr... they might throw in a smaller higher revving V8 from the C8? So yeah, to tie it up.. I think 2019 will be: 1. Same engine. 2. Evolution engine, with more power. 3. Smaller engine that revs more. My gut is going with #1. It's not like Camaro is "lacking" in power. Mustang was outselling Camaro, with LESS power. Adding more power isn't the sales solution for GM. Cost plays a big factor, and to keep the costs "down", #1 makes the most sense. |
12-22-2017, 01:49 PM | #201 |
I think at this point there is good evidence to say that the LT1 will go in the ME Corvette to start followed by two DOHC TT V8 powerplants. The LT1 will stop being put in Corvette's around 2021 or so.
That said, it would probably easy for GM to up the HP to 470-480 without a lot of work. Whether they want to or even need to is a good question.
12-22-2017, 02:16 PM | #202 | |
One reason to believe a power bump will come is the dual-injection system seen on the new LT5. Introducing that tech to the naturally asperated version would be reason enough for a power bump and LT2 name. A jump of the magnitude depicted here and I'd trade in my 16 rather than hold for gen7
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - Last edited by hotlap; 12-22-2017 at 02:34 PM. |
12-22-2017, 02:20 PM | #203 | |
Pizza & Wings Only $12.99
Drives: 2017 Camaro SS Join Date: Jan 2012
http://www.camaro6.com/forums/showthread.php?t=510612
H-Town Camaro Club
Past Rides: 2012 Camaro 2SS/RS M6 2012 Camaro ZL1 A6 2017 Camaro 2SS M6 |
12-23-2017, 01:10 AM | #204 | |
Drives: 2016 1ss m6 Camaro Join Date: Jul 2016
2016 camaro 1ss,m6-npp,tsp longtubes,no cats,e85,tuned by rpm motorsports(451hp/467tq),
17"race stars drag pack,bmr upper and lower trailing arms,bmr upper control arms,bmr front cradle brace,gforce outlaw axles/driveshaft,lnf 2step. Best 1/4 mile of 11.2@122mph |
12-23-2017, 01:15 AM | #205 | |
Drives: 1969 Mustang MaCh1 Join Date: Nov 2015
Sent from my SM-G955U using Tapatalk
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtqT56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear |
12-23-2017, 02:31 AM | #206 |
Drives: Nike Air Max Join Date: Jan 2016
You're right, OBD 2 but also dual catalytic converters over one single, they did the same thing with the L98s in '89, the N10 dual catalytic cars got a 10HP bump over the previous single cat cars.
'18 Camaro SS 1LE
'93 T/A l 398" Gen 2 LT1 l 24X l M6 l 12 Bolt 3.90 l Full suspension l Fikses '89 T/A GTA 48K mile hard top L98 car 12 F150 5.0 Lariat Super Crew - Stock daily |
12-23-2017, 04:40 AM | #207 |
Drives: C8 Corvette Join Date: Mar 2013
12-23-2017, 06:49 AM | #208 |
Drives: Gen 6 Camaro RS Join Date: Dec 2015
Facebook the "original" Fake News website
12-23-2017, 06:51 AM | #209 | |
12-23-2017, 10:12 AM | #210 |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
I'd be surprised if GM bumped HP significantly.
Go back to Gen5, the LS3 didn't get an increase in that period that I recall. GM's has a track record of not bumping HP within a model. 2019 will likely follow the cook book. Front and rear lamps, front and rear fascia and a center stack tweak to the IP. That is an MCE for GM. But GM doesn't typically add transmissions either and I suspect the 10 speed goes in for '19, it has to really just for the incremental FE bump. That being said, it's possible GM bumps the HP with the 10 speed. But it won't be in response to the Mustang. They would have had to made that decision 3 years ago.
