04-20-2023, 12:16 PM | #1 |
Drives: Camaro Join Date: Jan 2013
Cooling/radiator
I have a base 4cyl car and it's starting to get hotter as I improve the power. Does the heavy duty cooling on the 1LE have a bigger radiator? Will the 6cylinder or V8 radiator fit and add capacity?
Kurt |
04-24-2023, 12:34 PM | #2 | |
Drives: 2016 M6 2.0T Join Date: Nov 2016
Mishimoto sells the 2 smaller ancillary radiators for the HD Cooling set up. https://www.mishimoto.com/chevy-cama...tors-2016.html Looks like you would have to order the "lower hoses" from GM though. I don't see any after market lower HD Cooling hoses for the 2.0T, just for the V6. I highly doubt they will match up to the 2.0T. I'm not sure if someone on here can confirm this? It looks like you already got the Mishimoto Intercooler. Maybe add their Oil Cooler as well for additional cooling. I posted the only picture I have of my car with the front bumper removed so you can see it all.
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, Ikon Motorsports Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
05-02-2023, 07:32 PM | #3 | |
So the factory side radiators feed directly into the factory radiator? My car has some small side ducts that are blocked off, maybe those opening are used when the side radiators are added? Is your car a 4 cylinder with HD cooling? Thanks for your help.
Kurt Quote:
05-03-2023, 11:04 AM | #4 | |
Yes, I have the HD Cooling package on my 4 cylinder. Yes, the side radiators connect to the main radiator. Also, I miss spoke about the hoses, Mishimoto dose sell the HD Cooling package hoses for the 2.0T 4 cylinder. It's the upper and lower hoses to connect all of it together. https://www.mishimoto.com/chevrolet-...-kit-2016.html
05-04-2023, 06:51 PM | #5 | |
Those Mishimoto parts look interesting, but the ducting looks confusing on the GM parts side. If your car is factory heavy duty cooling with 4 cylinder could i get the last 8 numbers of your vin? You have the same front fascia as the base car? Do your inner fender liners have vents in them? I think it might have been a ZL1 I seen with the vents, but I'm not sure. I'm thinking about adding this on my car for the added cooling.
Kurt Quote:
05-05-2023, 01:15 PM | #6 | |
My vin# is: 1G1FA1RX0G01609621LE *To funny! I always thought my car looked lower than others and how it handles like it's on rails. I also wondered about my gloss black suspension components and the beefy looking sway bars. I just ran the vin# for fun to see what it say, and sure enough, my car has the SPP TRACK PERFORMANCE PACKAGE on the build sheet! I guess my suspicions were correct this whole time. Yes, all of the 2.0T/V6's have the same base front fascia. I replaced the stock front fascia grill with the GM SEMA grill. The base front fascia has nothing to do with anything. Yes, my fender liner has the brake vents in them.
05-07-2023, 08:39 AM | #7 | |
Thanks for the vin, that will make getting parts easier!
You think those vents are for the brakes, I thought they might be exits for the air passing the small radiators. I'm changing pistons/rods in my engine now and adding a bigger turbo and likely a clutch upgrade. I run my car in a open road race in Texas where I basically hold it wide open for 24 minutes, the trans was overheating so I added a cooler for that and the engine has been running over 200 the whole run. I'm thinking the added power will increase my MPH and gain some heat! IAdding the two little radiators now might be a good thing. Kurt Quote:
05-14-2023, 12:36 AM | #8 |
Drives: i want a camaro Join Date: Aug 2019
may I chime in, when I ordered my car with the heavy duty cooling package with the 20 in wheels (without going into RS), it did not come with auxiliary radiators, I think only with the oil cooler(if that) and I heavily researched the vehicle, before I pulled the trigger, but when i saw it, it had a regular fender liner
also, here are the window stickers for 2021 and 2022 cars that I "ordered" |
05-16-2023, 08:25 AM | #9 |
Drives: 2022 Camaro 2SS A10 Join Date: Jul 2022
D.O.M.D1 doesn't even have a Camaro... waste of people's time. (been looking to buy one for over 5 years) Not even sure why he is even posting on this forum or trying to give advice
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods |
05-16-2023, 12:24 PM | #10 |
