Old 06-30-2015, 07:04 PM   #15
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Originally Posted by NC C7 View Post
I just took a look at your journal, Beautiful car. The next time you come to NC I'll take it for a test drive to see what that quirky changing is all about. It's probably nothing but maybe you should have the dealership check it out.
Deal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 07-01-2015, 02:31 PM   #16
dbevins
Drives: 2014 Corvette Vert
I guess my thread/question got a little hijacked. No biggie! Any input on my numbers will be appreciated.
dbevins is offline   Reply With Quote
Old 07-02-2015, 06:01 AM   #17
purpleRac3r
purpleRac3r's Avatar
Your numbers are mostly spot on with mine, also a 2014 Z51. The only one that's a little off is your voltage. You should be a little over 14 volts while the engine is running, and what you indicated with the engine off. You may want to check battery cable connections and the battery itself. These cars are very sensitive to having the correct operation voltage - if low, it can cause all kinds of little electrical gremlins.
purpleRac3r is offline   Reply With Quote
Old 07-02-2015, 07:37 AM   #18
GretchenGotGrowl
Sorry. I don't have a LT1, so it won't be an apples to apples comparison. First, like the poster above me said, your voltage is a little low. Mine runs a bit over 14V unless I've got some drain like running PDR and phones attached to the charger. Second, oil pressure looks fine and right in line with what mine reads. Comparing temps is probably not a good idea as mine has extra cooling. That said, yours looks like they are well within the expected range.
Old 07-25-2015, 01:04 PM   #19
NC C7
NC C7's Avatar
Drives: 2014 CRT C7
My car is the base model, not a Z51
Outside temp 90 degrees
60 MPH 1100 RPMs
Driving in 7th gear
Water Temp 220 degrees
Oil Temp just over 200 degrees
Oil Pressure 32
NC C7 is offline   Reply With Quote
Old 09-28-2015, 04:32 PM   #20
Flytrade
Drives: 2015 C7
My 2016 C7 in 4th gear (manual) at 80 mph turns 3300 rpm at 195 degrees engine temp. Sometimes on a longer trip I go into 5th gear and the revs drop to 2500 with no change in temp.
Flytrade is offline   Reply With Quote
